Author Topic: TEX 80% TKL case compatible to MIT keyboards  (Read 30114 times)
Offline sdiearly
« on: Sun, 13 July 2014, 10:34:54 »
Maybe some guys saw my pictures from someone's forwarding post.
And I delete the imgur source.
http://mechanicalkeyboards.com/shop/index.php?l=product_list&c=44
The price contains shipping is $148, I think it's very cheap after comparing to others.
This case is compatible to TKL keyboards made in Taiwan, A.K.A. Filco/Ducky/CM QFR/Leopold/CODE
You can find these keyboards are assembled by Costar, excepted Ducky.
I have got this case information in May, there are four color this batch.
Grey/Red/Blue/Black
Overview on top and bottom case. and feets
My gift is red, I test it with CM QFR due to this keyboard is easiest to assemble.
The size is very close to plate.
Completed
Compare to original CM QFR, the profile is higher.
I like the KBT keycaps in R5
notice, this case's source is different from 60% case. The quality isn't the same.
« Last Edit: Sun, 13 July 2014, 11:28:28 by sdiearly »
My favorite 60%:  TEX-Beetle
                 80%:  KBtalKing Race
                100%: Cherry G80-3494, Zowie Celeritas
Offline Soulpyre
Re: TEX 80% TKL case compatible to MIT keyboards
« Reply #1 on: Sun, 13 July 2014, 11:01:01 »
I'm curious, would this case be compatible with a Phantom pcb+plate? I believe Phantoms were designed to be able to fit into Filco cases and it looks like these work with Filcos.
TX 1800 - 62g Clears
KMAC LE - GON's Nerd PCB 62g Clears
KPAD - 62g Clears
KBT Race - Browns, Ducky Shine 4 - Browns
Offline sdiearly
« Reply #2 on: Sun, 13 July 2014, 11:35:51 »
Maybe asking mechanicalkeyboards.com is faster if you need this case.
I don't have phantom, Is phantom designed with plate?
This case need plate to keep in place
« Last Edit: Sun, 13 July 2014, 11:42:20 by sdiearly »
                 80%:  KBtalKing Race
Offline Vanilla
  • 110% Snuggable
« Reply #3 on: Sun, 13 July 2014, 11:37:59 »
I like what I'm seeing.
Anyone think I'll be able to squeeze a slightly wider filco MJT1 tkl into this?
Offline sdiearly
« Reply #4 on: Sun, 13 July 2014, 11:40:15 »
Filco is no problem.
TEX guys come from Costar, they know how to fit their design.
                 80%:  KBtalKing Race
Offline gameaholic
« Reply #5 on: Sun, 13 July 2014, 13:37:12 »
I hate you WalletHack. :(
IBM Model M SSK, Filco MJ2 Ninja TKL with Reds ergo-clears, CM Storm QFR 55g Whites, Poker II with Reds
Offline MigZm
« Reply #6 on: Sun, 13 July 2014, 17:25:54 »
Thinking of getting one to go along my CODE. Hope it fits.  :thumb:
« Reply #7 on: Sun, 13 July 2014, 18:26:07 »
will this work with a KUL?
I guess if the KUL works with Filco...
I'll have to take mine apart sometime.
QFR | MJ2 TKL | "Bulgogiboard" (Keycon 104) | ctrl.alt x GON 60% | TGR Alice | Mira SE #29 | Mira SE #34 | Revo One | z | Keycult No. 1 | AIS65 | First CW87 prototype | Mech27v1 | Camp C225 | Duck Orion V1 | LZ CLS sxh | Geon Frog TKL | Hiney TKL One | Geon Glare TKL
Offline koalapear
  • Actually hates koalas.
« Reply #8 on: Sun, 13 July 2014, 18:56:34 »
Noooo! My wallet can't handle anymore! It look so good!
'91 Model M SSK | NerD 60 (MX Greens) | Realforce 87U 55g | Winkeyless B.87 (MX Greens) | Monarch Matias Custom | HHKB | Duck Octagon (67g Zealios)
Offline Vanilla
  • 110% Snuggable
« Reply #9 on: Sun, 13 July 2014, 19:30:06 »
Wait, weren't these out for awhile back?
I kind of remember seeing these out of stock @ MK while I was buying my tex machined alu case for my poker.
Yes, I am eyeing that blue one.  ;D
Offline Permeability
« Reply #10 on: Sun, 13 July 2014, 20:19:23 »
You are probably thinking of the ones made by Vortex, not Tex
Keyboards:
'The Cheat' - lubed 62g Clears
Ducky Shine 3 TKL lubed 45g Reds (Work)
« Reply #11 on: Sun, 13 July 2014, 20:22:07 »
Ooo maybe I'll have to pick up a blue one ;)
Offline Vanilla
  • 110% Snuggable
« Reply #12 on: Sun, 13 July 2014, 20:51:03 »
Hmm I don't think so, there's a review for the red one from 3 months ago.
« Reply #13 on: Sun, 13 July 2014, 20:55:08 »
For some reason they reused the SKU for the Vortex ones, that review was actually one I wrote.. haha and it was a Vortex one I purchased. They are not the same product
Keyboards:
Offline Vanilla
  • 110% Snuggable
« Reply #14 on: Sun, 13 July 2014, 20:57:34 »
Ooooooh gotcha!
I keep thinking they're the same company for some reason....
Offline sdiearly
« Reply #15 on: Sun, 13 July 2014, 21:27:02 »
You mentioned my notice, this 80% case's quality is worse than 60% ones.
I like Lian-Li level anodizing. but they are expensive.
                 80%:  KBtalKing Race
« Reply #16 on: Sun, 13 July 2014, 21:34:56 »
I'm not sure it would.  Someone correct me if I'm wrong, but isn't the Filco plate like the QFR plate in that it's bent over on the edges?  It seems like the case might need that slightly bigger plate with the bent over lip.  You may need something like these that were made for the Vortex case.
« Reply #17 on: Sun, 13 July 2014, 21:41:08 »
Yeah, I think you will need to put some spacer around the edge so the non-bent-over plate will fit on the phantom. Also it wont work at all if you have a more "full" layout. Then there's the chance that it'll not fit the teensy at all. Finally, you will hav to mod the connector to plug into the USB of the teensy.
« Reply #18 on: Sun, 13 July 2014, 21:43:11 »
That's probably the easiest part of all.  You'll just need the female end of the connector from Mouser, the right crimps, then solder those onto the Teensy.  The plate and making sure the Teensy fits is the tricky part.
Offline okwchin
« Reply #19 on: Sun, 13 July 2014, 22:45:07 »
Will there ever be a 100% version of this case?
I know of someone who would need a 100% case in red!
Offline Vanilla
  • 110% Snuggable
« Reply #20 on: Mon, 14 July 2014, 03:40:05 »
Hmm it doesn't seem like there have been any takers for the cases yet as I've been keeping an eye on their stock levels for each color and they havent seem to have moved one bit.
As it stands I'm pretty tempted to get one myself.  :rolleyes:
Haha likewise. My desktop chassis just so happens to be an armorsuit P80.  ;D
« Last Edit: Mon, 14 July 2014, 03:44:15 by Vanilla »
Offline Battou62
« Reply #21 on: Mon, 14 July 2014, 07:05:50 »
I have been searching for a custom, but it is tempting to pick up one of these and drop a tkl into it.
Offline pr0ximity
« Reply #22 on: Mon, 14 July 2014, 09:54:05 »
Worse how? Anodizing, thickness, fit?
I'm kind of torn between putting my Filco in this or sticking to my guns and going with a 55g RF. These look very tempting given TEX's reputation.
| Flickr | KMAC 1.2 | Koala | GSKT-00-Z | GSKT-00-AEK | GON NerD60 | Jane V2 CE | Whale | J80S | Ibis | Pro2 | Pro1 | 356mini | 356CL DGE | G80-5000 HAMDE | IBM 1390120 | IBM F AT | IBM F122 | IBM 3101 | Zenith Z-150
Offline sdiearly
« Reply #23 on: Mon, 14 July 2014, 12:05:12 »
The cost shows you the quality.  :)
TEX 60% case comes from a factory which taking order from Lian-Li. Anodizing is very beautiful and flawless.
Another factory handle the 80% case, which is cheaper and some flaw points in the case.
                 80%:  KBtalKing Race
Offline Vanilla
  • 110% Snuggable
« Reply #24 on: Mon, 14 July 2014, 12:51:26 »
What's a better alternative that's available at the moment/ in the not so distant future?
To be honest, although it's lower quality, it's quality is plenty acceptable IMHO and as mentioned before, with a price that's fair.
Yeahhhh I'm in the market for a 80% case hehe.
Offline t2russo
« Reply #25 on: Mon, 14 July 2014, 12:53:30 »
Remember you can always get a case reanodized at a later date...
I'm probably going to swap the KBDMod aluminum case I have on one of my filcos for one of these.  I don't like the beveled front edge on it and this case is flat like my KMACs.  Matches better than my black vortex case which is wedge shaped.
vortex on top kbdmod on bottom
or maybe I buy a KUL or Code and shoehorn it in...
« Last Edit: Mon, 14 July 2014, 12:56:31 by t2russo »
Offline Hucifer
« Reply #26 on: Mon, 14 July 2014, 13:15:38 »
Would anyone know if it is possible to have one of these shipped directly from Taiwan? I'm currently living in Bangkok and it seems crazy for me to pay for shipping all the way from the U.S. when I'm so close to the source.
I have Googled and tried looking on Taobao, but no joy yet. It also doesn't help that I can't speak or read a word of Chinese  :'(
              Waiting on / GMK LED Keycaps
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #27 on: Mon, 14 July 2014, 13:53:53 »
I would love a blue or a red one but I just swapped my KeyCool to a stainless universal plate.
|||My other keyboards :
x
Offline sdiearly
« Reply #28 on: Mon, 14 July 2014, 20:59:43 »
I don't know the reason.
But re-anodizing will make the surface be coarse.
                 80%:  KBtalKing Race
Offline sdiearly
« Reply #29 on: Mon, 14 July 2014, 21:04:43 »
This product is ordered by MK.com, even Taiwan is no distributor.
It's hard to buy TEX case in Taiwan  :-[
I can have one just because personal friendship.
I can't sure TEX would like to handle direct shipping in single or not, you should mail to them first.
their web site leaves the contact message.
                 80%:  KBtalKing Race
Offline combataran
« Reply #30 on: Thu, 24 July 2014, 23:01:21 »
How heavy is your case(fully assembled), and what's the pitch with the feet attached?
Cherry G80-1000HFD | CM Storm Spawn | Keypuller.com - Key Caps News & Database
Offline Johan
« Reply #31 on: Sat, 26 July 2014, 13:06:13 »
I'm considering ordering one of these cases, the price with shipping to Sweden wasn't as bad I would expect. Would anyone recommend this case, or would you get something else?
Uh, stuff.
Offline Dreamre
    • kbdlife
« Reply #32 on: Sun, 27 July 2014, 19:43:36 »
Does anyone have a better picture of the grey one? :D
Offline zennasyndroxx
  • It's good to be back!
« Reply #33 on: Fri, 01 August 2014, 09:40:35 »
Since you said that this fits code keyboards, is it very safe to assume that this actually fits WASD?
Offline sdiearly
« Reply #34 on: Sun, 03 August 2014, 21:50:58 »
Costar's OEM are the same.
                 80%:  KBtalKing Race
« Reply #35 on: Sun, 03 August 2014, 23:45:54 »
So I guess dip switches won't be an issue? Cause the dip switch placement for code and wasd keyboards are not the same as the dip switch cutout in the case
Offline LechnerDE
« Reply #36 on: Mon, 11 August 2014, 00:43:14 »
Just found this thread thanks to Combataran :)
So, has anybody besides OP bought the case? Any compatibility and/or quality issues?
Offline xavierblak
« Reply #37 on: Mon, 11 August 2014, 08:49:15 »
The quality of the case is nice. But I did notice it did not work well with DSA caps on the edges. Keys like F1 and F4 which are against multiple edges would rub and not depress smoothly. I need to play with it more but I had to pack it up since I'm in the middle of moving.
Offline LechnerDE
« Reply #38 on: Mon, 11 August 2014, 11:37:27 »
Thanks for the feedback!
I am mostly interested in the compatibility with GMK keys. Can you check please if those have the same problems?
I guess Filcos and QFR will definitely fit. Has anyone tried Duckys as well?
« Reply #39 on: Mon, 11 August 2014, 11:46:48 »
judging based on the pictures and the location for the dip switches, it looks like it'll fit the ducky g2 pro tkl  - DK 9087
Offline xavierblak
« Reply #40 on: Tue, 12 August 2014, 20:55:26 »
I got a chance to do a bit more testing with this case. The problem locations are f4, f8, f12, pause/break and the right arrow keys. I tested with the DSA caps from the retro keyset and those keys would actually get stuck in the down position after being pressed.
I tried some gmk and original cherry caps and they both rub against the corners in those same locations. Not as bad as the DSA keys but still noticeable. SA profile also had a slight rubbing problem. I tried out OEM profile and DSC profile and they were fine.
Edit:
BTW the keyboard guts I used to test with was from a filco. So I suppose a different keyboard could be slightly different.
« Last Edit: Tue, 12 August 2014, 20:58:00 by xavierblak »
Offline t2russo
« Reply #41 on: Tue, 12 August 2014, 22:40:04 »
Slide your plate to the left? Sounds like the inner assembly is too far to the right relative to the cutouts.
Offline xavierblak
« Reply #42 on: Tue, 12 August 2014, 23:59:29 »
I tried that I wasn't able to get it move enough to the left to make any difference. I even tried loosening all the screws, putting the keyboard on it's left side and pulling down on the keys. Doing this the best I was able to do was make the DSA keys not stick but even still they were rubbing on the edges. Once I tightened up the screws it was back to the keys sticking down.
Offline Johan
« Reply #43 on: Thu, 14 August 2014, 08:00:44 »
I got my case today! There are some blemishes on the bottom half, while it's not an issue for me, it might bother some of you.
Pictures of the scratches; http://i.imgur.com/XwmMtBX.jpg http://i.imgur.com/D7MSRlf.jpg Sorry for the potato pictures. I can try to take new ones if someone wants me to.
Uh, stuff.
Offline LechnerDE
« Reply #44 on: Thu, 14 August 2014, 09:44:02 »
As long as you can't see these scratches if you look at your board from above it's no problem I guess ;)
Which board will you put into the case?
Offline Johan
« Reply #45 on: Thu, 14 August 2014, 10:17:41 »
Just a regular old brown switch filco, I got a little bit scared when dsa apparently didn't' fit well. Hopefully there won't be any issues with a thick ducky set.
Uh, stuff.
Offline Johan
« Reply #46 on: Thu, 14 August 2014, 15:44:10 »
I'm already having issues with assembly, I can't seem to get the original filco cable out, do I just use a screwdriver with a super small flat-head?
FIXED IT!
Now all I need is for my pexon cable to arrive  :'( It feels like the left ctrl is sticky though, I'll have to do something about that.
« Last Edit: Thu, 14 August 2014, 16:54:45 by Johan »
Uh, stuff.
Offline swornxin
    • Nailed Down Custom Pins
« Reply #47 on: Fri, 15 August 2014, 12:14:31 »
I should have searched through this forum before posting a new thread.
Does anyone have any idea if this case would be compatible with the KUL ES-87 keyboard?  Looking for a TKL with clears that I can customize, because I don't feel comfortable enough building my own and soldering.
Octagon - 62g Cherry tactile greys
Phantom - 65g Cherry tactile greys
FC660M - Cherry blues
KC60 - Gateron browns
Offline Johan
« Reply #48 on: Mon, 18 August 2014, 04:27:06 »
For anyone curious, This case with feet is slighty less tilted  than a stock filco. It was also very easy to assemble.
Uh, stuff.
Offline mapple
« Reply #49 on: Mon, 18 August 2014, 10:03:42 »
would that case work also with ducky shine 3 tkl? anyone tried before?
In God We Trust
