Author Topic: Cherry Stabilizers + MX blacks PCB  (Read 112973 times)
Offline lewi
Re: Cherry Stabilizers + 1800 PCB
« Reply #150 on: Mon, 04 August 2014, 01:04:40 »
i want to know quality of black mx switch.
do you know its crunch sound is noisy like new black switch or, quiet like vintage cherry switch.
Offline byker
  • Literally Canada
« Reply #151 on: Mon, 04 August 2014, 01:08:26 »
In for some stabs!  :)
Offline clacktalk
  • circa 2015
« Reply #152 on: Mon, 04 August 2014, 02:25:30 »
Updated my order by submitting another respond. Thanks again Ivan :]
diary of a clacktalk
radio_killah: too much frank
Offline GeorgeK
« Reply #153 on: Mon, 04 August 2014, 04:18:22 »
What will the payment deadline be on these?
Offline redskull
« Reply #154 on: Mon, 04 August 2014, 13:20:41 »
ivan, is the 6.25u stab bar is as shown in the picture? as in there's a curve in the middle or is it straight like 7u's?
THIS Ivan. need clarification please.
Offline quake4mhg
« Reply #155 on: Mon, 04 August 2014, 21:19:31 »
 "curve in the middle" means something?  ^-^ <--- noob
Offline whiskytango
  • Don't touch the trim
« Reply #156 on: Mon, 04 August 2014, 22:42:27 »
If it's got that offset bend in the middle it won't work with a plate. It will still work on a pcb without a plate though.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #157 on: Mon, 04 August 2014, 23:11:05 »
I just added a PCB to my order.  There was mention that there might be a way for me to improve the 2KRO to more than that without having to add diodes and traces from the jumper holes.  Does anyone have anymore info on this?  What am I trying to do to do this?  I only need 3KRO to be comfortable, but 4KRO would be ideal...
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #158 on: Tue, 05 August 2014, 13:10:02 »
Payment deadline... lets make it 20th.
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
Re: Cherry Stabilizers + MX blacks PCB
« Reply #159 on: Tue, 05 August 2014, 13:17:27 »
Any more information regarding the screw down PCB stabs?
Offline quake4mhg
« Reply #160 on: Tue, 05 August 2014, 13:39:10 »
Could you explain why it's not work? :D Thanks
Offline xavierblak
« Reply #161 on: Tue, 05 August 2014, 13:42:49 »
The bend is too tall and doesn't fit between the pcb and the plate.
« Reply #162 on: Tue, 05 August 2014, 15:23:17 »
Second this.  I haven't put an order in yet because I'm.waiting.on that answer.
« Reply #163 on: Tue, 05 August 2014, 16:05:58 »
No. But if they do have the bolt on ones for us, would it be a problem if all the PCB mounts got those? I don't really want the hassle of dealing with both kinds.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #164 on: Tue, 05 August 2014, 16:14:16 »
Are the bolt ones 100% compatible with PCB mount PCBs?  If yes, then maybe, but if not then I don't see how that would work.  Can we get more details on the bolt ones and how they are expected to work?  I know for my PCBs I am not sure how the bolt one would work...
Offline Grendel
« Reply #165 on: Tue, 05 August 2014, 16:23:23 »
Physically I believe they are compatible. Keep in mind that when using the screw mounted ones traces and groundplanes need to be further away from the holes to clear the screw heads. I would prefer the clip-in's for this reason.
« Last Edit: Tue, 05 August 2014, 17:54:33 by Grendel »
- I'm game !
« Reply #166 on: Tue, 05 August 2014, 16:27:58 »
Besides Cherry G80 models, the only other thing I ever used bolt ons is the GH60 rev A I have. The only real difference I think they have now is they use a bolt instead of the clip in (obviously) which makes them much harder to unseat but maybe more likely to damage the PCB? The original ones like i have didn't have those little shocks under the stem insert pieces either which made them feel better but I don't think this is the case anymore. So, I think they are all the same really. As far as the ones I have, the base that makes contact with the PCB seem to be the same dimensions so it shouldn't really matter.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #167 on: Tue, 05 August 2014, 17:03:40 »
Cool. Thanks for the detail. I think it is probably fine to replace the PCB mount ones with the PCB bolt mount ones then (if they are available).
Offline justnits
« Reply #168 on: Tue, 05 August 2014, 19:46:36 »
ivan, do you know anything about the 6.25u metal bar being straight or does it has that bend in the middle?
Ducky DK9008 Shine 2 Gateron Red w/ Korean 55g gold lubed spring & custom LED | Ergodox with Aluminium top plate | IBM Model M SSK | GHPad | GON's Nerd TKL | Filco Majestouch 2 TKL MX Blue
[Sold]Keycool 87 PBT White Cherry MX Blue | [Sold]ikbc F-104 Cherry MX Brown
« Reply #169 on: Wed, 06 August 2014, 11:48:31 »
PCB mount has the bend in it, Plate won't.
Offline justnits
« Reply #170 on: Wed, 06 August 2014, 21:30:58 »
which means to say,
the PCB 6.25u has the bend.
PCB 7u, plate 6.25u, plate 7u is straight?
Offline korrelate
  • iubeo stultum esse libenter
« Reply #171 on: Wed, 06 August 2014, 23:49:50 »
bolt stabs sound very interesting though: and couldn't you just use some sort of soft washer to protect the traces on the pcb?
Ordered! Thanks again Ivan
Cheers,
K
Topre REALFORCE
« Reply #172 on: Thu, 07 August 2014, 01:39:37 »
Bolt is small, shouldn't even be a concern.
Yes, only the pcb mount 6.25 has a bend.
Offline Lubed Up Slug
« Reply #173 on: Thu, 07 August 2014, 21:43:48 »
So what is the consensus? Will these fit on a Massdrop Ergodox or should I get the costar ones from WASD?
Offline ninjadoc
« Reply #174 on: Sat, 09 August 2014, 13:54:19 »
I'm stupid when it comes to building a board so I have to ask if besides building a board without a plate is there any instance I will need a 6.25 PCB mounted wire/stab set with the curved offset in the middle?
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #175 on: Sat, 09 August 2014, 15:53:14 »
Here is a picture of the bolted ones:
(Click for high res)
Those tiny screws you see on there are the bolts.
Compare it to the Backspace stabilizers which are regular PCB-mounted ones.
« Last Edit: Sat, 09 August 2014, 15:55:53 by JaccoW »
|||My other keyboards :
x
Offline user 18
« Reply #176 on: Mon, 11 August 2014, 14:05:10 »
Ordered. Do I need to do anything else to have it combined with my PBT caps order, or does that happen automatically?
Avatar by ashdenej
« Reply #177 on: Mon, 11 August 2014, 15:13:18 »
Nope shipping will be combined on anything from previous (current) groupbuy that haven't shipped.
Offline mashby
    • Mashby
« Reply #178 on: Mon, 11 August 2014, 17:36:20 »
Has there been a decision on wether the PCB mount stabs will/can be the bolt-on version?
Offline korrelate
« Reply #179 on: Mon, 11 August 2014, 21:50:03 »
Every time I read this thread I get more interested in the answer to this question^^^^.
Cheers,
K
Topre REALFORCE
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #180 on: Mon, 11 August 2014, 22:38:28 »
Ya, I would be interested in the bolt stabs as well.  Mainly because I have never seen them before, so that makes me want to try them.  Oh and because pcb mount stabs always come out on me when I pull tight keycaps, which is annoying...
« Reply #181 on: Tue, 12 August 2014, 07:09:08 »
Not to be dense but these bolt mount stabs work with any PCB that accepts regular PCB mount stabs? I thought the PCB had to have a different hole for the bolt?
« Reply #182 on: Tue, 12 August 2014, 10:14:36 »
That's what I thought too, which is why I'm confused as to where this demand is coming from.  AFAIK there are few boards that will accept them and they usually come with them.
Offline BunnyLake
  • The OG HHKB Master
  • X
« Reply #183 on: Tue, 12 August 2014, 10:19:10 »
submitted a new order if you could cancel my old one
Offline mashby
    • Mashby
« Reply #184 on: Tue, 12 August 2014, 10:21:38 »
My understanding is that the bolt uses the same hole on the pcb. Instead of the expansion tabs fitting down into the hole, the screw mounts into the plastic from the bottom of the pcb.
Offline domoaligato
« Reply #185 on: Tue, 12 August 2014, 10:31:21 »
I have some from my wey hk2000 and that is what I noticed. Some of mine are rusty and I would be very interested in ordering with bolt mount. I originally placed a order before I remembered that I had some coming with the gh60 groupbuy. in for bolt mounts if available.
« Reply #186 on: Tue, 12 August 2014, 11:48:32 »
PCB mount have the same mounting dimension whether it is clip in or bolt. The bolt is the only difference, and does go in the same place as the expansion tab. They will work just the same on any PCB that can fit PCB mount Cherry stabilizer.
« Reply #187 on: Tue, 12 August 2014, 12:01:31 »
Good to know, thanks clarifying.
Offline nathairtras
« Reply #188 on: Tue, 12 August 2014, 12:22:26 »
I am dumb.  Can you confirm for me that my order (just submitted) contains only plate-mount stabs?
CM QFR Green
Offline domoaligato
« Reply #189 on: Tue, 12 August 2014, 12:37:37 »
  :thumb:
Can we order bolt mounted?
« Reply #190 on: Tue, 12 August 2014, 13:23:59 »
It depends what they have available. I still don't know yet.
Offline yicaoyimu
« Reply #191 on: Tue, 12 August 2014, 13:53:04 »
Shall we wait for GMK's response before collecting payment?
Offline domoaligato
« Reply #192 on: Tue, 12 August 2014, 14:50:51 »
thanks!
Offline korrelate
« Reply #193 on: Tue, 12 August 2014, 16:18:46 »
My interest in this GB stems from exactly the same problem. When I built my TrikX I used the stabs and wires that Team Redline include with the PCB, Case, etc. To be fair, they included way more wires than I needed but now I'm thinking it's because they were manufactured by a third party (the wires, at least, if not the Stabs also).
Most of them are working very well (and they are much, much better than the Plate Mounts that came on my Leopold .. my first mech... back when EK first swapped over from Filco) with one exception: my numpad zero: the wire on that stab always pops out when I pull that key off. Fortunately, I've settled on my favorite colorway (WoB) and they have stayed put from some time. Also fortunately, this stab wire has to be the best stab wire to have this problem with: I can just take the PCB and that stab wire is right down there are the edge of the board and I can pop it back in with precision screwdriver.
That said... I am hoping that my problem is merely that the OD of the stab wires that Trik provided is (however slightly) too small and that swapping this out with a (hopefully) closer-to-spec stab wire from Cherry sorts this all out.
Cheers,
K
Topre REALFORCE
Offline damorgue
    • Personal portfolio
« Reply #194 on: Wed, 13 August 2014, 15:48:03 »
If they are the bolt version, I'll get some of those instead.
A second question, I assume everything will ship from the US, and that the PCBs will add a significant amount to the shipping costs, correct?
Offline jevvix
« Reply #195 on: Wed, 13 August 2014, 20:09:55 »
Submitted mine. 7 2x plate and a 6.25 plate. Think that's all that's needed for a standard full size kb right?
Offline strict
  • TKL Zealot
« Reply #196 on: Wed, 13 August 2014, 20:21:52 »
Order submitted. I ordered some PCB stabs hoping the bolt mount ones are an option.
Offline Oobly
« Reply #197 on: Thu, 14 August 2014, 06:56:01 »
Ordered. I have ordered black on black sets, Dolch sets and now 2x PCB. I'd like these to ship with whichever is sent first of the keycap sets, please Ivan (unless of course the sets and PCBs can all be shipped together?).
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #198 on: Thu, 14 August 2014, 07:56:31 »
I will be buying more stabs if I can get the bolt stabs.
Would like to know if the bolt stabs are possible.
Offline strict
  • TKL Zealot
« Reply #199 on: Thu, 14 August 2014, 08:20:14 »
Same here. If it's confirmed we can get bolt mount I will almost certainly double my order for pcb stabs.
