Author Topic: PCB mount options with MX Browns  (Read 1050 times)
Offline Lengradde
« on: Tue, 22 July 2014, 18:35:39 »
Just wondering what PCB mount options with MX Browns are out there.
60%, 75%, either
Having finger pain issues...so I'm wanting to try various lighter springs and krytox without needing to solder things.
« Last Edit: Tue, 22 July 2014, 18:41:46 by Lengradde »
Offline dante
Re: PCB mount options with MX Browns
« Reply #1 on: Tue, 22 July 2014, 19:05:50 »
Cherry G80-1800/1865
KBC Poker 1/X (Not 2)
Cherry G80-3000
Some PLUM MX96 boards - they switched to plate sometime during production
Some Neo KB87 - believe some of these switched to plate also
Offline Flyersfan1
  • Hi!
Quote from: Photekq
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #3 on: Wed, 23 July 2014, 10:57:14 »
MX 8000 series like this is a good choice. It's cheap and comes with nice doubleshot keycap too.
Offline Lengradde
« Reply #4 on: Wed, 23 July 2014, 12:42:21 »
I need smaller than fullsize, that Cherry board wouldn't fit on my desk!  :))
« Reply #5 on: Wed, 23 July 2014, 13:45:51 »
Ah I see. Well in that case I would second the Neo if you need something ready made. But you might have some issues getting a hold of one and will probably need to deal with sourcing from TaoBao. There really are way too few PCB mount keyboard options.
Offline jameslr
« Reply #6 on: Wed, 23 July 2014, 14:15:26 »
Could also try a Topre variable board. They're fairly light and tactile like brown. Just throwing that out there. I have zero fatigue issues on a 55g Topre, but I know others with more sensitive hands may have trouble with them. The 45g uniform Topre is very light to me.
CM Novatouch | Filco MJ2 TKL w/ HID Lib | REΛLFORCE 87U 55g | CM QFR
Offline davkol
  •  Post Editing Timeout
« Reply #7 on: Wed, 23 July 2014, 14:26:36 »
Compaq G80-11800, about as wide as tenkeyless and supposedly easy to mod to tenkeyless.
« Reply #8 on: Wed, 23 July 2014, 19:42:38 »
Oh yeah that's another option. Those 11800 are often cheap on ebay and aren't too wide. Easy to cut off the numpad/trackball section and keep them working yes... easy to make that look nice afterwards... not without some serious skill.
