Hi Everyone,
We appreciate everyone's feedback and concerns.
If it is okay, I can provide some input on these "Newer" Kailh switches.
During the product development phase, we have tested several different MX Compatible switches from different manufacturers and we decided to go with these "newer" Kailh switches for our first mechanical keyboard due to better quality/durability than the others.
We are confident enough in these switches that we are backing them up with a three year warranty, which is equal to or more than most other mechanical switch keyboard brands.
Not to sound rude, but the three year warranty doesn't mean that you have confidence in the switch. A warranty is a rational analysis of product life and costs of the product. It means that you have confidence that any increase in defectiveness and servicing of the product will be below the difference in money saved by switching from Cherry to Kaihl. Since your Moda is identical to the Zalman ZM-K500 and Genius M1 and is just an OEM board with different brands, odds are the costs are much lower than going with a Cherry based board.
I'm not bashing the rational business choice that was made, but to say that it's quality and you can tell because of the warranty isn't exactly honest.
Also, you stated that Kaihl had better quality and durability than other knock offs. That doesn't tell us how they stand up against Cherry brand switches. If you could show they stand up to Cherry quality, I would buy some in a heartbeat.
If you stand behind the quality, tell us the kind of testing you did, the failure rates, and so on that made you decide to back the knock off instead of the original. That helps us make informed decisions and really see how the switches have progressed. Currently, I have some Kaihl switches to test, but so far I have not been impressed.
