Author Topic: Build me an itx rig!  (Read 9917 times)
Offline absyrd
  • CPT HYPE PADAWAN
« on: Sat, 26 July 2014, 07:25:52 »
I stopped reading/participating in PC forums a couple of years ago, and I have no energy to get back into it. I figured many of you are knowledgeable and could throw together a list of parts for me.
I need:
-itx form factor
-smallest case possible that is not flashy
-speedy yet ability to undervolt (I enjoy getting highest clocks while undervolting as much as possible)
-QUIET!!!!!! It needs to be pretty much silent as I have problems with white noise. I currently use a seasonic PSU that the fan never runs unless I'm doing something intensive.
-very light gaming ability (TF2, Torchlight, etc)
-cheap
Thanks in advance for all advice, help, builds!  :thumb:
Re: Build me an itx rig!
« Reply #1 on: Sat, 26 July 2014, 10:20:27 »
I need:
-itx form factor
-cheap
it's impossible to build a  M-itx that's quiet inside a "small case",   if you're worried about white noise..
Unless it's the really slow kind of M-itx that doesn't require much cooling..
What's ur budget..
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #2 on: Sat, 26 July 2014, 11:04:57 »
This build fits most of your requirements...
mobo w/quad core
memory
ssd
psu
case
it is cheap with a total of $386, and built based on silence rather than powerful... though it should still have enough power to do typical browsing, multimedia, office tasks and light gaming on medium setting.
« Last Edit: Sat, 26 July 2014, 11:09:34 by IvanIvanovich »
« Reply #3 on: Sat, 26 July 2014, 11:08:02 »
mobo
memory
ssd
psu
case
it is cheap, and built based on silence rather than powerful... though it should still have enough power to do typical browsing, multimedia, office tasks and light gaming on medium setting.
That would be so epic slow... you wouldn't want to use it..
« Reply #4 on: Sat, 26 July 2014, 11:15:39 »
Actually those Bay Trails have very good performance for the price and are no worse than a faster clocked dual core Pentium when you get down to it.
« Reply #5 on: Sat, 26 July 2014, 13:47:17 »
Look at HTPC cases for small and quiet. They are often like old-time's desktop cases. Much smaller than a cube case. Most are not made to fit a graphics card, others are able to do so with a riser card.
The quietest cases are fanless with the case being the CPU's heatsink, but those are somewhat flashy because they indeed look like large finned heatsinks. Others have a large fan right over the CPU cooling everything.
I use an EeeBox as my daily home machine. I choose it because I found it feasible to modify it to be completely fanless but then I found the fan to be quiet enough. Those are not very powerful for gaming, though and I notice the fan noise more now a few years after I got it.
Offline jalaj
« Reply #6 on: Sat, 26 July 2014, 14:05:51 »
how about the NUCs? They're even smaller than iTX builds.
Intel, Gigabyte, Zotac and few others make them.
The additional hardware you need to add is just RAM, HDD/SSD, and/or a WIFI card.
Here's an example:
http://www.newegg.com/Product/Product.aspx?Item=N82E16856164011
« Reply #7 on: Sat, 26 July 2014, 14:22:14 »
Here's an example:
yea these are small..
but for $500... you could do 4670k + mini ITX board.. + mini itx case..  and that @ 4.8ghz would pwn the **** out of a 4570R,
I haven't owned a computer under 4.5ghz for a LONG time...   All I can remember is them being quite unpleasant..
Offline blackbox
« Last Edit: Sun, 27 July 2014, 08:25:32 by blackbox »
The LAN table!
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #9 on: Sun, 27 July 2014, 07:25:35 »
Thanks for the builds so far. Saved me tons of time digging through other sites. Geekhack is my one-stop-shopping experience.
Offline TacticalCoder
« Reply #10 on: Sun, 27 July 2014, 08:03:20 »
Quiet is the most important thing for me... Back in the early days of the PCs I was modding alims so that the fan speed would lower when the temperature was low (back then alims had a fixed-speed fan).
Nowadays I'm always checking the lowest max TDP I can find for the CPUs I'm after, before the ability to underclock. Currently I'm running a 16 GB of Ram / Core i5 3450s.  The 's' has a max TDP of 65W if I'm not mistaken, which, for desktop, is lower than what one can typically find.
My alim is a "Be Quiet!": it's very quiet indeed!
At 65W max TDP you don't even need a fan for your CPU. I'm still putting in a Panaflo fan (ultra-quiet but not that easy to find in Europe) but I don't think it's mandatory.
So I'd suggest something like what blackbox suggested but I'd replace the Core i5 4690K / max 88 W TDP with a Core i5 4690s / max 65 W TDP... Then you'll probably not even need to underclock it nor use fancy cooling.
Offline blackbox
« Reply #11 on: Sun, 27 July 2014, 08:23:37 »
My alim is a "Be Quiet!": it's very quiet indeed.
Reason for my cooler is that it is more optimal with water cooling when you have the space constraints of a mini-itx case. But shure, the 4690 is good :)
The LAN table!
Offline FrostyToast
  • Litshoard
« Reply #12 on: Sun, 27 July 2014, 08:27:36 »
I would go for a Noctua cooler. Be Quiet is also great, but Noctua fans are just so much better. Although, I don't know how a Dark Rock with Noctua fans would perform if you want to go that extra mile.
Quote from: elton5354
Offline blackbox
« Reply #13 on: Sun, 27 July 2014, 08:49:41 »
Dark rock and noctuas are very good, the "problem" is that you need a bigger case for a dark rock pro or a noctua similar sized cooler. A noctua L9a is good choice for a small build.
The LAN table!
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #14 on: Sun, 27 July 2014, 09:31:05 »
It is crazy how the itx market has expanded since I last built a PC. So many options rather than just 2 boards and like 3 cases a few years ago.
I am so torn between building a little powerhouse rig like blackbox made (minus the case as I can't stand windowed cases) or a truly minimalist one like Ivan posted (so inexpensive and still fun to build).
« Reply #15 on: Sun, 27 July 2014, 10:40:08 »
ivan's post is not inexpensive..
it's about performance/ price ratio..   ivan's build is LOW on that.. even though total cost is also lower.
4690 is a good place.. but for itx  you'd want to delid the chip, and use a 120mm tower cooler, and use a 240mm water cooler for the GPU..
CPU does not need water...that'd just be wasting money
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #16 on: Sun, 27 July 2014, 10:43:07 »
Water cooling is too noisy for me. Been down that road with many setups, from custom loops to AIOs.
Offline divito
« Reply #17 on: Sun, 27 July 2014, 10:47:06 »
Have to head out, will reply when I'm back on my ITX system and what may work for you.
Varmilo (MX Grey) KeyCool 87 (MX Clear) Quickfire Stealth (MX Green)
« Reply #18 on: Sun, 27 July 2014, 10:48:00 »
what's ur budget..
Offline The Nude Wizard
« Reply #19 on: Sun, 27 July 2014, 12:19:25 »
You said you werent interested in watercooled so I wont detail the lenghts i went to to get a near silent OC'd 4770k & 780GTX setup recently but I would recommend Bit Fenix cases regardless (I got a prodigy, but would probably get a phenom as linked if I were to do it over)
They may not be the smallest footprint in mini ITX cases but are quite versatile with what they will accommodate.
« Reply #20 on: Sun, 27 July 2014, 12:29:59 »
Yes the one I spec'd up is not a powerhouse... but the whole thing only has one fan in it which is in the PSU. That could be gotten rid of as well if wanted to spend more on the fanless version of the Seasonic. Or, you could go with a pico psu and much smaller case size. With that CPU TDP of 10w cooling is something you don't even need to care about at all. The only real big con with the Bay Trail boards is that they only have a 1x PCI-E slot which make them a very poor choice for adding GPU card. Some of them do have a 16x physical slot, or an open back 1x slot so it is technically possible to run a GPU on it, but it will be fairly hampered. Though, it still might end up being better than intel HD graphics with a discrete gpu running even at only 1x.
As for performance there is more than enough to run source games and other games with similar requirements. Having more power might be handy if decide wants to play more demanding things at a later time of course, but for what was said it is wholly unnecessary. While my main PC was down for a little while, I had to use my server as my main PC which runs a Pentium G620 and I found that fine performance wise with only the hdgraphics coming from an i5 with a proper gpu.
Watercooling can be near silent if you get the right pump which are typically the loudest part. But that usually comes with a high price to do so since the quiet pumps are quite a lot more expensive plus along with additional accessories like vibration killing mounts. My water set up is pretty quiet as long as I take the considerable amount of time and effort to make sure all the air bubbles are cleared or otherwise it makes a terrible racket. My 'case' is all open too more like a test bench so there is nothing to insulate the pump noises from my ear as it sits about a foot and half away from my head. My radiator fans are some lower powered pwm which I have set to stay on low until CPU reaches 50c which doesn't happen too much. When they do spin up during gaming I generally have my sound up loud enough I can't hear the fans anyway. I don't bother to water cool my gpu since full cover blocks are too expensive and generally can't be moved from card to card. By the time you are ready to sell them on they have depreciated 90% or more so are a terrible investment. So with the gpu I spent some good amount of time determining where thermal downclock occurs then adjusting the fan curve to prevent that while still staying on the lower side the rest of the time as to not be noisy.
Offline Heezy
  • Formerly trynds
« Reply #21 on: Sun, 27 July 2014, 12:51:36 »
I just built mine early this year/around december
Bitfenix Prodigy
8gb ram (reused this from my old pc)
Asus mobo (don't remember the model but it's one of the cheap ones, and very crappy. will probably change to another one next year, there's only 2 fan available on it, i had to wire fans to the psu instead)
520w antec hcg
i5 4570
770 2gb
120gb ssd
1tb hd
it serves me well, and can play any games i want. i'll probably be changing the casing and mobo near the end of this year/next year. looking to get a smaller casing.
i'm looking at this one
http://www.pccasegear.com/index.php?main_page=product_info&cPath=25_1290_608&products_id=26861
Rig - i3 6300, 240GB SSD, 500GB SSD, Gigabyte H170N Wifi, 16GB DDR4, Zotac 1060 Mini, 650w SuperFlower
Monitor - HKC144hz Mouse/Mousepad/Keyboard - Zowie EC1A - Zowie GS-R - Zowie Camade - Filco TKL MX Pink
« Reply #22 on: Sun, 27 July 2014, 13:04:47 »
Have you considered using fan splitter cable? I use a 2 way pwm splitter so I can run both my rad fans off the cpu fan header so they are both controlled the same. I also use one in my itx server build as it also only has 2 fan headers one for cpu and one for case for both the case fans on my PCQ08. As long as you mind the wattage being pulled they work great.
« Reply #23 on: Sun, 27 July 2014, 13:08:27 »
itx server build?  what is going on with the world...  this is insane
Offline Heezy
  • Formerly trynds
« Reply #24 on: Sun, 27 July 2014, 13:22:22 »
Yeah, that's what I'm doing right now. Had to get 3 extra fans.
« Reply #25 on: Sun, 27 July 2014, 13:48:39 »
I actually have 2 itx servers. My main one is a Zotac H67 with Pentium G620 and 8GB memory. The board has 6x sata ports all of which are populated with 3x 2TB and 3x 4TB with each of those groups in a parity refs pool. Then I have a pci-e msata card with a mushkin atlas for the OS drive all in a Lian Li PCQ08 with an Antec basic 500w PSU. Then I have the other one, which is a partial back up server currently as I only have single 2TB disk in there for storage along with ancient intel 80gb SSD for the OS... which is a prebuilt thing, an Iocell netdisk 400t, that I got new dead stock for like $20 off ebay. It's case is really nice with a solid aluminum 1 piece rectangle and 4 hotswap bays and integrated 150w PSU board. It's very small, but it only has a Core2 E4500 with 4GB DDR2. Though really it's fine for it's purposes. The biggest con is the motherboard has a bios bug which makes it hang on post if you have any disks in gpt which ruins it's ability to use storage spaces which I find somewhat annoying. I've been considering replacing the board for one of the newer Atom 8core ITX server boards.
« Reply #26 on: Sun, 27 July 2014, 14:02:45 »
.......... ..............................................   why was the itx form factor "necesssary" for this...
harddrives touching so closely is very bad..
and for data purposes,, the matx atx h6,7,8 boards would've been cheaper.. and work just as well , there's also much less crosstalk and electrical noise on larger boards.
« Reply #27 on: Sun, 27 July 2014, 14:15:54 »
The HDD are no closer together than they would have been in anything else. All cases have the hdd cages in stacked arrangement pretty much and having them run at moderate warmth is actually good for hdd for longevity as this has been proven in data centers. As far as cost, it was no more expensive than matx boards with the same feature set when I bought it. It was an upgrade from an original era Atom so I stuck with ITX so I could use the case and etc that I already had. Originally the build was more of an htpc but I changed it to a straight up server when I got rid of my television when I moved up to my 27" display on my main pc.
Offline divito
« Reply #28 on: Sun, 27 July 2014, 14:42:59 »
Some context before I post this: I'm 28 years old and like some of the other nerds on here, I've been building my own computers, as well as part of my business, for over 15 years. I've gone through the super budget overclockers, gigantic cases with a ton of drives and fans, servers, etc...
In my most recent build, I decided to go for something relatively small, cheap, quiet and capable; no fuss. While I don't keep up with all the latest games as I used to, I still wanted something to could do the job if I wanted to, as well as take care of all my Photoshop, media center and other tasks with ease. As I read this thread, it's actually quite similar to trynds.
Note these prices are in Canadian as of when I bought them (February...not sure what they are now).
BitFenix Prodigy - $90
MSI H81I - $80
i5-4670 - $240
G.SKILL Ripjaws 8GB 1600 - $86
Samsung 840 EV0 240GB - $200
EVGA 760 FTW 4GB - $284
Silverstone SS-ST45SF 450W - $80
Total with tax = $1197
Now you never mentioned your actual budget, so you can easily save money with a cheaper motherboard, an 120GB SSD, and a lower graphics card; and since you talk about undervolting, you'd be moving to the 4670k if interested in that tier of performance.
This thing is basically silent. The only time you can sort of hear something (assuming you're not using headphones or don't have sound a decent level through speakers), is when you're pushing it with a certain game and the graphics card fan is going hard. I also had two hard drives that I migrated into this system as well. Full build and pic
It acts as my regular computer with two monitors and a TV hooked up to it, as well as a media center for XBMC on my Nexus 7 and other computers on the network.
« Last Edit: Sun, 27 July 2014, 14:50:46 by divito »
Offline blackbox
« Reply #29 on: Sun, 27 July 2014, 15:09:55 »
MSI H81I - $80
i5-4670 - $240
Looks like a a nice build, which cpu cooler do you use? I had very good experience with noctuas.
The LAN table!
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #30 on: Sun, 27 July 2014, 16:19:08 »
Yeah. Solid build, divito.
Right now I'm just not gaming, but since all these mobos are "H" branded these days, I can do just fine with the cpgpu until I NEED to buy a graphics card.
And I actually like that Silverstone case linked above. I'd just be concerned about how loud the sfx PSU gets.
« Reply #31 on: Sun, 27 July 2014, 17:39:39 »
MSI H81I - $80
i5-4670 - $240
This is ridiculous...
for $1200..
no 4670k, no z87 / z97  ?
those 2 parts nearly double CPU performance.. and relative to the whole build, only increases the cost by 10% at most..
the 240 evos are $100 in the usa.. so  if we look at that alone,  you can price in the 4670k and z97
$80 PSU,  they often sell 600watt seasonic builds for $50..
$85 gskills 1600,  just last week i got $75 2400mhz kingston
Offline divito
« Reply #32 on: Sun, 27 July 2014, 21:53:37 »
Stock cooler. If I were still overclocking and got a 4670k, I'd probably be using Noctua NH-U14S.
for $1200..
1. Those prices were from February, as I stated (and Canada, so subtract a decent amount for US equivalent).
2. I'm done with overclocking, so I didn't need a z motherboard or k CPU. The extra money for smaller benefit of overclocking isn't worth the time. I'd be interested to see a benchmark where you get double the performance.
3. Like I said, February Canadian prices; I also mentioned that he could move to a k processor.
4. The case requires a smaller PSU than most. I went with the cheapest one that would fit because the one I wanted was out of stock.
5. Again, Canada sucks.
That one doesn't seem terrible. Other than the Prodigy that I bought, I was considering the Fractal Design Node 304:
« Last Edit: Sun, 27 July 2014, 22:00:00 by divito »
Offline tbc
« Reply #33 on: Sun, 27 July 2014, 22:39:59 »
http://www.coolermaster.com/case/mini-itx-elite-series/elite110/
http://www.anandtech.com/show/8193/silverstone-nightjar-nj520-power-supply-review  - if you're good with cable management
gtx 750 or 760 if you need more power
  alternatively, wait from the ASUS STRIX lineup to come out
SSD - w/e you want, not relevant to compactness or silence
ram - w/e you want, not relevant to compactness or silence
CPU cooler - any 120/140mm AIO
fans - f12 (kinda loud still, but it's a pretty good balance)
NOTE:
that SS PSU could be used for wind tunnel sound effects and completely fails to meet any non-compromise standard on SPCR.
source: I have it
that said, if you DON'T need to be SPCR quiet, then it's okay, but there are noticably quieter options out there.
« Last Edit: Sun, 27 July 2014, 22:43:34 by tbc »
« Reply #34 on: Sun, 27 July 2014, 22:55:38 »
NOTE:
source: I have it
I thought about completely fanless..  but I just couldn't find a fanless gfx card powerful enough to drive madvr scaling..
the most powerful fanless gfx card still says it requires minimal case flow on the box...   i think nightjar is the same.. don't remember from the review.
Offline tbc
« Reply #35 on: Sun, 27 July 2014, 23:08:49 »
you're still getting airflow from the radiator fan.
it doesn't need cold air, it needs air movement.  it can take care of itself, but it will do nothing to help other components.  eg, it will NOT generate any airflow that a fanless GPU would need.
especially consider this case, this is an air vent RIGHT above the PSU.
« Reply #36 on: Sun, 27 July 2014, 23:20:56 »
I'm just saying.. completely fanless has been a dream for me.. but it can't really be realized without sacrificing 80% performance.. haha..
Offline blackbox
« Reply #37 on: Sun, 27 July 2014, 23:39:32 »
If fanless is a dream, a gpu/psu that has a fan that only turns on when its needed is an good option IMO.
The LAN table!
« Reply #38 on: Mon, 28 July 2014, 00:18:11 »
then it's not really fanless..
If I need fans AT ALL..  I might as well stick with low rpm..
Offline blackbox
« Reply #39 on: Mon, 28 July 2014, 00:35:58 »
I see, the point i was trying to make was that the fans would not spin under regular load and therefore be as silent as a fanless. But low rpm works too ofc. :)
The LAN table!
Offline Heezy
  • Formerly trynds
« Reply #40 on: Mon, 28 July 2014, 01:12:36 »
And then all of a sudden, it sounds like as if it was tp4 who was looking for itx.
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #41 on: Mon, 28 July 2014, 06:01:11 »
Hmmm... I do NOT want an AIO water cooler. Is scythe or anyone still making really low profile coolers that fit the mounting holes for these new mobos? I think I still have one for LGA 1155 maybe?
Offline blackbox
« Reply #42 on: Mon, 28 July 2014, 06:27:44 »
As mentioned Noctua has some low profile coolers that works on new sockets like the NH-L(XX) 9a/91/12.
The LAN table!
« Reply #43 on: Mon, 28 July 2014, 11:29:40 »
I've done the whole itx thing before.. that's why generally I'm against it, because it's so much trouble to clean,  heats up mechanical drives at least 15 Celcius greater than big cases, and because of the tight space,  you need m0ar rpms to keep things cool..
so.. in the end   Itx= looks smaller, but is louder, and uses more power to do the same damn thing.
« Reply #44 on: Mon, 28 July 2014, 11:31:34 »
Low profile cpu coolers are bad for the same reason why Graphics card coolers generally suck.
because they have the fan blowing hot air ONTO the board itself..
The board then insulates and absorbs heat..  making the whole thing hot..
This is the reason tower coolers came into popularity because it pulls heat AWAY from the system..
I also have a tower cooler mounted on a 7870myst downstairs.. it is by far the coolest running card in the house relative to power use.  and it can handle up to 70% load @ 600rpm, which is whisper silent.
Offline blackbox
« Reply #45 on: Tue, 29 July 2014, 03:30:03 »
You can reverse the fan so that it blows air away from the cpu too. But low profile coolers will always sacrifice performance for size. I mentioned low profile coolers purely because of the size since OP wanted the smallest possible case size. :)
The LAN table!
Offline byker
  • Literally Canada
« Reply #46 on: Tue, 29 July 2014, 03:44:01 »
A few months ago, I built this: http://pcpartpicker.com/user/mtnbkyer/saved/PD4NnQ
Here are some pics:
My favourite computer to date. It packs a punch with an I5 and gtx 770 and I love this case. The evga Hadron Air is small, but it fits everything i need and looks amazing. Sorry for the bad quality photos.. Let me know if you have any questions about building itx or anything.
Offline Heezy
  • Formerly trynds
« Reply #47 on: Tue, 29 July 2014, 03:49:46 »
Honestly, my GPU never made much sound. I'm using x2 24' monitor, and a 27' main monitor. 1 of the 24' monitor always has a movie/drama on, and the other one has browsers and skype/chats/spotify. the 27' always has dota 2 on, and then i play bf4/other games while dota 2 is on. Never had any lag or loud noise from the GPU.
« Reply #48 on: Tue, 29 July 2014, 09:50:37 »
« Reply #49 on: Tue, 29 July 2014, 09:53:52 »
Here are some pics:
I really like the slim profile psu..
whussup with people n0 get Overclock
40% increase in cpu ipc performance is pretty seriously up there
delidding is free
and the haswell and ivy chips can do 4.8 on 212+ 212evo  which cost between free to $20 on sale.
