In the spirit of geekhack, if you can swing it you might want to consider getting two of the three. A lightly used 55g 87u has a very strong resell value in the classified section, and I have no doubts that a white FC660C will as well. Of course reselling is a bit of a hassle, so it might only be worth it to go down this road if you are truly torn.
