Author Topic: Miami-like blank PBT set  (Read 1982 times)
Offline kaje
« on: Mon, 28 July 2014, 23:17:42 »
Pardon me if this has been discussed before (I'm a noob and tried searching for a similar topic), but does anyone know where I can get blank PBT in colors similar to the Miami set?
I found these pinks on pimpmykeyboard, which may work, but they're a little lighter.
Haven't been able to find neon blue caps, though.
Offline aicrono
    • A Touching Experience
Re: Miami-like blank PBT set
« Reply #1 on: Thu, 31 July 2014, 17:53:35 »
There is this listing on TaoBao but they are not blank. I have seen blank Miami colors on there but I can't find it again for the life of me. I don't think it was a set like this is, it was two sets that had the Miami colors. I remember the pictures also had them with back-lighting enable/disabled on they keyboard they were being shown off on.
http://item.taobao.com/item.htm?spm=a230r.1.14.106.zbjzI0&id=40164497955&ns=1#detail
Edit: Did a bit more searching and found these. I have no idea if they are actually PBT or not, I am assuming no but they are Miami-ish colors and are blank(if you leave the backlight off I guess).
http://detail.tmall.com/item.htm?spm=a230r.1.0.0.ff9FSA&id=16035424620
http://item.taobao.com/item.htm?spm=a230r.1.0.0.ff9FSA&id=38245798613&ns=1#detail
« Last Edit: Thu, 31 July 2014, 18:12:10 by aicrono »
Offline kaje
« Reply #2 on: Sun, 03 August 2014, 11:09:33 »
Ohhhh, I really like those. Thanks for finding those! I don't mind so much about them being blank, I just didn't think there would be any other options out there other than that. Would those be considered quality PBT?
Is there some proper way to order things from Taobao or should I look for some middleman service?
