Author Topic: Ractiv Touch+, new motion tracking pointing device  (Read 6398 times)
Offline argcargv
  • tempting the banhammer
« on: Wed, 06 August 2014, 08:53:02 »
Has anyone seen this: https://www.ractiv.com/
I am going to do a short review on how well it works after I get my unit.
It seems my hand can finally never leave the home row.
One problem is that currently it does not support convex or concave surfaces so I can't use it with my Kinesis Advantage
But I will be using it on an ergodox.
Offline daerid
    • Rossipedia
Re: Ractiv Touch+, new motion tracking pointing device
« Reply #1 on: Wed, 06 August 2014, 11:11:59 »
That looks really, really cool.
My biggest gripe with many of the hand-tracking systems is that they require moving your hands so far away from the keyboard, or holding them up in an unnatural and tiring position, not to mention then having to wave them around like a mad man. Being able to treat the space just above your keyboard as a touchpad is very appealing.
Offline argcargv
« Reply #2 on: Wed, 06 August 2014, 13:08:44 »
yes, leap motion was a big disappointment because of having to wave like a mad men
Offline argcargv
« Reply #3 on: Wed, 06 August 2014, 13:11:04 »
the technology tracks the depth of each finger, so convex or concave surfaces can be made to work in a software updatw, in the future.
Offline engicoder
« Reply #4 on: Wed, 06 August 2014, 13:34:26 »
I've tried a few different devices of this sort and the problem with all of them, and gesture enabled track pads to a degree, is predictability. If I use a mouse or a trackpoint, the behavior I get is predictable and consistent. These devices are a crap shoot. Even if they correctly interpret the gesture 99 times out of 100, you have to be vigilant against that one error. That interferes with the normal speed and efficiency boost you get from muscle memory and disrupts your thought process.
My other beef with them is the lack of tactile feedback. If I click a button, I feel the click. That does not exist with all this hand waving.
Offline SonOfSonOfSpock
« Reply #5 on: Wed, 06 August 2014, 19:13:25 »
I'm skeptical about this knowing whether you were typing or not and misinterpreting your typing as the mouse movements. All they show in the promotional video is people doing the mouse movements with no typing.
Offline islisis
« Reply #6 on: Thu, 07 August 2014, 02:38:54 »
what gestures are you hoping to implement with this? will it cover both sides of the ergodox, or at different tilt angles?
in an ideal world i think a solution like this would be more consistent
http://www.cnet.com.au/microsoft-keyboard-prototype-integrates-gesture-control-339347151.htm
Offline argcargv
« Reply #7 on: Fri, 08 August 2014, 13:30:23 »
This is a good point
Offline argcargv
« Reply #8 on: Fri, 08 August 2014, 13:31:14 »
Found a few more videos online
https://www.youtube.com/user/ractivtech
Offline argcargv
« Reply #9 on: Fri, 08 August 2014, 13:36:02 »
I think my ideal setup would be to make the pointing device as modular as possible, instead of hardwired into a keyboard.
The only motions I need is to be able to point, click, and scroll documents. For any precise movement when using a graphical tool, I would always use a mouse.
I want to use it with my left hand(I use my mouse with my right hand). Some my right hand can have a rest when I am just browsing the internet.
this is my current setup
Offline jacobolus
« Reply #10 on: Fri, 08 August 2014, 15:43:03 »
There's one other big problem: latency.
The input lag on the devices like this that I’ve seen is much higher than e.g. a mouse, trackpad, or iPad surface.
Offline islisis
« Reply #11 on: Sat, 09 August 2014, 04:06:14 »
i see, thanks!
the one gesture i would like that couldn't be achievable with a trackpoint mod is one-handed use detection. it would be great to be able to automatically activate a layer whenever the other hand is away using the mouse etc.
Offline argcargv
« Reply #12 on: Sat, 09 August 2014, 15:58:24 »
It would be great to be able to automatically activate a layer whenever the other hand is away using the mouse etc.
[/quote]
I think this is a great idea!
I think currently the Touch+ is disabled as soon as you start typing. So maybe it can be easy to program the reverse into the software so as soon as you start "mousing", the keyboard layer changes.
Offline berserkfan
« Reply #13 on: Sat, 09 August 2014, 21:58:44 »
what does that thing on top of your kinesis do? is that a platform for your mouse?
Offline Input Nirvana
« Reply #14 on: Sat, 09 August 2014, 23:57:20 »
Look forward to your review, seems to be the best incarnation of that type of technology I've seen. The latency on the video didn't seem like much, but in actual use it may be much more noticeable.
Of course none of this applies to me being a Kinesis user (curved key well).
Offline jacobolus
« Reply #15 on: Sun, 10 August 2014, 00:16:00 »
Really? To me the video looks like it has about a half second of latency. (Which for me personally is way too much. I want like 50 milliseconds tops, ideally more like 10-20 ms.)
« Reply #16 on: Sun, 10 August 2014, 00:20:46 »
I saw a point at which there may have been more noticeable latency, but honestly I probably wouldn't notice much on the video until I had my meat hooks in action. I've had too much latency on a bluetooth keyboard, so I'm as picky as the next geek.
The review will be a "tell-all tale" fa sho.
« Last Edit: Mon, 11 August 2014, 00:47:02 by Input Nirvana »
Offline argcargv
« Reply #17 on: Sun, 10 August 2014, 16:20:01 »
It is the apple magic trackpad on top of a plastic platform on top of the keyboard
