Just for the record, I wasn't asking you to change anything. Just wanted to be sure the mock-up matched the final design of the key caps, within reason. I don't think I've seen that font used before.
Me neither, but I believe that Fried is another typical example of a keyset that manages to become a group buy, because it looks very good, but has some issues with the legends/presentation. I'm not sure if Krizie was intended to run Fried with this custom font or if this font is from some sort of layout generator.
Apollo GT10 and Lunar are the most recent ones in the same situation.
However, we've got plenty of time to fix any mistakes (if there are any, maybe Fried is meant to be what is being advertised on the mockups).
Let's hope for the best and make sure everything tips.
