So do we have any 1.25x modifier key width options with Cherry Profile?
Imsto PBT, GMK, any Cherry G80 with 1.25 bottom row (e.g 8200HPBUS, 3000HRMUS), also the 1.25x short left shift on any Cherry ISO set. All of these will be Cherry profile.
Worth noting that any Cherry G81 with 1.25 mods won't work, as they have off-center stems. G80s are fine though.
Thanks for the reply, makes sense that all of those would be Cherry profile.
I actually have a new G80 (came with POM laser-engraved keycaps in Cherry profile) that I want to change to Dolch vintage and the GMK RGBY set keycaps. The GMK RGBY means that I'll have the Alt, Ctrl, Shift, Win covered, but I will need a Menu keycap.
The OG Dolch keycaps don't have the menu key, and the GMK RGBY don't include it. Do you have any suggestions? I would not want to use the original keycaps that came with the G80, which are laser engraved POM keycaps, and would look out of place with the new doubleshot ABS caps from the Dolch + GMK RGBY.
Are there any single novelty/whatever keycaps that would go nicely in the Menu key slot (so just one key) that is available, and most importantly in cherry profile?
Thanks for reading! I tried to be specific because I'm having trouble figuring out what to do to finish this "design". So close to my dream keyboard, yet one key away!
