Author Topic: Replacement Buckling Spring Keycaps  (Read 3388 times)
Offline xybre
  • clickityclackclickityclack
    • Music and Stuff
« on: Wed, 13 August 2014, 17:15:22 »
The "notched" caps lock key is really annoying, especially I use it as a control key.
I own a Unicomp Ultra Classic with unlabeled black keycaps and a black case.
Unicomp has ctrl-labeled keycaps, but they're still notched: http://pckeyboard.com/page/Buttons/CTCL
All I need is a single black unlabeled key for this purpose.
Where would I be able to pick up a replacement?
GON NerD 60 & Duck Eagle & Unicomp Ultra Classic & Das Keyboard Ultimate
Offline 0100010
  • Not Sure
Re: Replacement Buckling Spring Keycaps
« Reply #1 on: Sat, 16 August 2014, 09:28:09 »
I'm not aware of of any non stepped 1.75 width buckling spring keys.
Offline 0100010
  • Not Sure
« Reply #2 on: Sat, 16 August 2014, 09:59:06 »
But I just remember this thread on the same topic, where a right Shift was cut down for use as a unstepped Caps Lock.
http://geekhack.org/index.php?topic=13466.0;nowap.
Offline xybre
    • Music and Stuff
« Reply #3 on: Sat, 16 August 2014, 10:40:25 »
Wow, I didn't realize I was looking for the holy grail. It seems it'd be easy enough to do a few hand-poured or injection molded keys.
Hmm. I guess if I can rent, borrow, steal, or buy an injection molder I know what I'll do with it.
Thanks for the info, I guess I'll mod a key with Sugru or invade Japan for their keyboards.
Offline xybre
    • Music and Stuff
« Reply #4 on: Sat, 16 August 2014, 10:40:46 »
[EDIT] Double post.
Getting some weird error from the forum about incorrect types, expect array of integers for quoteids.
« Reply #5 on: Sat, 16 August 2014, 21:05:40 »
I loved stepped keys and wish that they were more plentiful.
However, the easy answer is to get a spare and infill it with epoxy and/or chopped donor caps.
"The Trump campaign announced in a letter that Republican candidates and committees are now expected to pay “a minimum of 5% of all fundraising solicitations to Trump National Committee JFC” for using his “name, image, and likeness in fundraising solicitations.”
“Any split that is higher than 5%,” the letter states, “will be seen favorably by the RNC and President Trump's campaign and is routinely reported to the highest levels of leadership within both organizations.”"
Offline pr0ximity
« Reply #6 on: Sun, 17 August 2014, 18:49:17 »
Ditto, specifically center-stemmed MX stepped keys. I've no idea why they're not more popular, its a pretty neat look and functionally nice as well.
| Flickr | KMAC 1.2 | Koala | GSKT-00-Z | GSKT-00-AEK | GON NerD60 | Jane V2 CE | Whale | J80S | Ibis | Pro2 | Pro1 | 356mini | 356CL DGE | G80-5000 HAMDE | IBM 1390120 | IBM F AT | IBM F122 | IBM 3101 | Zenith Z-150
Offline xybre
    • Music and Stuff
« Reply #7 on: Sun, 17 August 2014, 19:24:29 »
I've seen some neat stepped modifier keys where they're stepped on both left and right side. However, I use the left control (caps) key constantly and with the stepping strongly on the right I often have to take an additional second to ensure I'm hitting the key head on. It essentially moves the key to the left. Hmm. I wonder if I can just flip it upside down?
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #8 on: Sun, 17 August 2014, 19:51:08 »
other than the obvious "enter" key on a 122........are the ctrl, alt, cap, etc. keycaps interchangeable with a regular M?
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline xybre
    • Music and Stuff
« Reply #9 on: Sun, 17 August 2014, 21:24:06 »
The caps lock is 1.75, the others are 1.5. So, no, unfortunately.
Offline Techno Trousers
  • ʘ_ಠ
« Reply #10 on: Sun, 17 August 2014, 21:28:49 »
If you're asking about exchanging like-for-like caps (e.g. M-122 ctrl to M-101 ctrl), then yes, they are interchangeable. The only exceptions are the modern Unicomp 104 boards, which have odd size modifiers.
