Author Topic: Problem with iphone login, please help  (Read 2747 times)
Offline qtan5370
« on: Tue, 19 August 2014, 19:11:59 »
When I try to use the forum in safari, it tell me that I was banned from using the forum. I turn on the private, which clear out all my information, try again, it come up something like "Gust you are banned from using the forum..."
clearly, it is a system error since I am can till use my account on my computer.
Look for Keyboard? Check my offers. I have most major keyboard and some caps for you, if you don\'t see it there, ask me. I am Top rated seller on eBay now, and have retail store in China selling keyboard and other gaming staffs.
My eBay store http://stores.ebay.com/E-sports-Gaming-equipments?_rdc=1
My store(lower price than eBay): http://www.keyboardwow.com
Offline osi
Re: Problem with iphone login, please help
« Reply #1 on: Tue, 19 August 2014, 19:39:49 »
Is it happening on your cell network, WiFi, or both?
« Reply #2 on: Tue, 19 August 2014, 20:37:07 »
Some VPNs are blocked and will do this (most common cause).  Make sure you're not using a VPN, then clear your cookies and cache (in settings), then try again.
Also, check this thread for more information:
http://geekhack.org/index.php?topic=57803.0
Offline qtan5370
« Reply #3 on: Tue, 19 August 2014, 23:45:40 »
I am using data, haven't try with wifi yet.
