Author Topic: Good source for practice PCB  (Read 1910 times)
Offline Distilled
« on: Sat, 23 August 2014, 19:12:02 »
So I am on the search for a practice PCB. I have ordered some Duck keyboards and will be putting them together my self. However, I have never really soldered a PCB before and it seems like a bad idea for my first to be the duck one.
I am asking what other people have used as practice. Something that will help me learn where everything should go. Hopefully with some LEDs as well if possible.
As an option:
http://www.ebay.com.au/itm/Deck-Cherry-MX-Red-Blue-Brown-Black-Sampler-kit-w-LED-for-Mechanical-Keyboards-/291058465282?pt=AU_Input_Peripherals&hash=item43c46fba02&_uhb=1
Any help is much appreciated.
Offline Lastpilot
  • Power stance
Re: Good source for practice PCB
« Reply #1 on: Sat, 23 August 2014, 19:20:55 »
You can try taking apart an old alarm clock or even an outdated television remote. :]
« Reply #2 on: Sat, 23 August 2014, 23:58:44 »
ming has some cool soldering practise kits for TH and SMD.
http://www.geekhackers.org/collections/electronics-kits
here's a review of it:
http://geekhack.org/index.php?topic=59038.0
« Last Edit: Sun, 24 August 2014, 00:02:53 by dorkvader »
Offline berserkfan
« Reply #3 on: Sun, 24 August 2014, 15:37:53 »
As an option:
Duck keyboards?
You mean Ducky or Deck?
« Reply #4 on: Sun, 24 August 2014, 15:43:44 »
Duck keyboards?
No, he means Duck keyboards, as in custom keyboards made by Duck.
« Reply #5 on: Mon, 25 August 2014, 00:22:47 »
Somewhere there is a guy wearing a t-shirt from Qwertees, typing on a Qwerkywriter with novelty caps from Qwerkeys ...
Offline qwack
« Reply #6 on: Mon, 25 August 2014, 10:36:11 »
When I was learning to solder, I used cheap components (diodes/resistors) and perfboard. Working on a quality PCB will be easier than perfboard (the pads/plated holes are harder to damage), but practicing on perfboard will make you learn to apply just the right amount of heat to avoic damaging the pads.
Pure Pro w/MX Red - [review]
Offline phoenix1234
« Reply #7 on: Mon, 25 August 2014, 10:48:21 »
As an option:
If you want to practice SMD soldering, my recommendation is to go with this cheap practice kit:
http://www.ebay.com/itm/121320560517
It is only $3.78 for 2 sets
You can do a lot of soldering practices on them without concerning about damaging PCB.
I like linear switches
Offline phoenix1234
« Reply #8 on: Mon, 01 September 2014, 12:07:45 »
Just added the picture that I test on the kit that I mentioned above.
76152-0
This kit is good for practicing with SMD resisters and diodes because it has a big number of them. To be honest, SMD is not supposed for hand soldering, it may require a bit of patience, especially when it comes to very small ones.
« Last Edit: Mon, 01 September 2014, 12:09:25 by phoenix1234 »
