Have you read the geekhack TOS lately?
Was it lowpoly that did the amazing rebuild on an M0110?
Got it, thanks! Gonna retrobrite and teensy it if the switches feel decent.
how are you liking the locking capslock?You can direct wire like lowpoly or I think TMK_firmware has a converter module for this so you can keep it all original if you want.
These aren't conventional Alps switches, as in later models like AEK or AEK2, are they?
The IBM "pingmaster" keyboards came with green tee-mount switches, so you can probably get some out of one of those pretty cheap.
