Author Topic: [IC] - G80-3700 Plates  (Read 3910 times)
Offline The_Beast
  • I like wood ಠ_๏
« on: Thu, 28 August 2014, 09:21:31 »
Should be getting a 3700 soon so I'll need a plate. Anyone else interested?
Re: [IC] - G80-3700 Plates
« Reply #1 on: Thu, 28 August 2014, 10:01:45 »
Yes x3
Offline Lurch
« Reply #2 on: Thu, 28 August 2014, 13:32:00 »
+1
Quote from: Flyersfan1
Offline cphead
« Reply #3 on: Thu, 28 August 2014, 13:42:24 »
Interest
Offline AKmalamute
  • HHKB Scrub
« Reply #4 on: Thu, 28 August 2014, 13:47:17 »
Can it be made to work with the other number pad that's about to start floating around?
Barring that, Could using this plate let me build a smaller, slimmer 3700 that takes up less desk space than what it takes up now?
...in which case, yes I'm interested. Anodized 7075 if you want to go exotic -- but 304SS would be fine too.
HHKB-lite2, Dvorak user
Offline kalrand
« Reply #5 on: Thu, 28 August 2014, 14:32:32 »
Forgive my ignorance, but how would a plate work on these units?
My 122 key Model M was born on July 25th, 1988.
Offline JinDesu
« Reply #6 on: Thu, 28 August 2014, 14:35:21 »
I would like to understand too, as I recently got myself a G80-3700.
Someday somebody will best me, but it won't be today, and it won't be you.
Proud owner of a Filco Majestouch Cherry MX Blue Tenkeyless, KBT Race S, & Realforce 101
« Reply #7 on: Thu, 28 August 2014, 14:38:17 »
This thread shows it pretty well
http://geekhack.org/index.php?topic=50768.0
And The_Beast can comment on this as well but some modding may be required per this post
http://geekhack.org/index.php?topic=42063.msg853659#msg853659
« Last Edit: Thu, 28 August 2014, 14:41:51 by SpAmRaY »
Offline kalrand
« Reply #8 on: Thu, 28 August 2014, 15:11:51 »
I mean, there's no flex on these units. Aside from being able to use plate-mount switches, whats the advantage?
Or is this a "because we can!" kind of thing. Which I fully support.
« Reply #9 on: Thu, 28 August 2014, 15:12:47 »
For me personally it would simply be a because you can thing :P :D :thumb:
Offline kalrand
« Reply #10 on: Thu, 28 August 2014, 15:14:55 »
Carry on.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #11 on: Thu, 28 August 2014, 16:51:08 »
Since it's a small board, the flex isn't too too noticeable. But the feel of the plate is nice IMO
Case modding is required. It's two 1/2" slots you have to cut. You can see it here in the plastic that separates the esc and the numberpad
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #12 on: Thu, 28 August 2014, 17:13:38 »
count me in for 1
« Reply #13 on: Thu, 28 August 2014, 18:07:24 »
I'm in for 2.  As long as they have the switch top removal notches.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #14 on: Thu, 28 August 2014, 18:17:54 »
Do I do it any other way?
#cptlevelnew
Offline Karura
  • Professional Canadian
  • SKidata life.
« Reply #15 on: Thu, 28 August 2014, 18:54:01 »
I'm interested, as long as I can get the numpad! Waiting for it
« Reply #16 on: Thu, 28 August 2014, 19:14:51 »
#cptlevelnew
I'm just saying.
Offline Synjin
« Reply #17 on: Thu, 28 August 2014, 19:30:33 »
What woudl the price for these be?
Offline The_Beast
  • I like wood ಠ_๏
« Reply #18 on: Fri, 29 August 2014, 14:06:52 »
Price depends on quantity, but my guess would be somewhere around $15-$20 without shipping
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
« Reply #19 on: Fri, 29 August 2014, 21:39:04 »
Bah, I should start an appreciation thread for plateless blacks D: though if you put something like clears or green then the plate is probably worth it
Offline The_Beast
  • I like wood ಠ_๏
« Reply #20 on: Mon, 01 September 2014, 12:19:00 »
I found an extra 3700 plate when I was looking through my keyboard stuff. But it seems like there is still enough interest in this to run.
Offline Karura
  • SKidata life.
« Reply #21 on: Wed, 01 October 2014, 18:05:16 »
I would buy two of these, as long as they're notched and made for easy-switch mods :)
Thanks for running the IC, hope it becomes reality.
