The Ergodox is a staggered column layout. If you want that layout, you will need to create a new barrel frame. If I were doing that, I would use XT barrels with a custom laser cut top plate. You would also need custom membranes for contact switches or PCB for capacitive switches. There is not much of a price difference between the two if you are making less than a lot. Finally, you will need a custom case - I find this to be the most problematic. You might look for someone in the forums that is interested in the project and good with CNC.
I would be happy to help with PCB or membrane design.
Ah, WCass, you’re the man!
I’m starting this thread to build and inspire a discussion. I’m technically far from able to embark on this ambitious project now (have yet to cut my first metal plate even).
But I believe that if we’re scaling a huge mountain there are many lower base camps where we must stop and acclimatize. So let’s start on a much lower mountain for now, making use of extant (pun intended) material. Long before I get my ideal keyboard I will build less than perfect but usable and good keyboards.
Let’s start at the Model F XT and Xtant project levels then. I have heaps of XT barrels and materials and I am sure many geekhackers have the same.
Let’s say I wanted to turn my miserable F XT layout into a matrix keyboard. There is a 2x5 space on the left side that I’ll leave alone, and a 20x5 space on the right side that could be turned into a big matrix. That’s enough space for a matrix-type ergodox and maybe I can put a numpad in the center between the hands where there are unused keys.
So what I’ll need would be a custom metal top plate, and custom capacitative membrane, with bolt holes for bolt modding. The bottom plate and casing will be extant, of course.
Can this be handled within the confines of your Xtant project?
Also, is the metal top plate relevant towards the capacitative sensing? Can it be replaced by another material eg a nonconductive one? I ask this because I’ve not been able to find people who can do custom metal work here in Singapore so I’m thinking of looking for people who can do acrylic instead.
