Author Topic: Can anyone confirm ABS has fixed the nkey issue?  (Read 9943 times)
Offline aarroo
« on: Wed, 17 June 2009, 01:29:19 »
I am about to pull the trigger here on an ABS m1 keyboard but I am concerned about the nkey rollover issue many people seem to be having.
On newegg, most of the customers that left bad reviews regarding this were left with a customer service response stating they could RMA it and receive a non-defective keyboard.. It also states that their keyboards do support 6key rollover.
I was curious if anyone can confirm this issue has been fixed or if this is still an problem.  I will be using this keyboard for heavy gaming so its fairly important.
Offline ch_123
« Reply #1 on: Wed, 17 June 2009, 05:46:27 »
I'm pretty sure this was a firmware problem that they have since fixed.
Offline itlnstln
« Reply #2 on: Wed, 17 June 2009, 07:57:53 »
I bought several months ago, and the issue had already been fixed.  It shouldn't be a problem anymore.
Offline IBI
« Reply #3 on: Wed, 17 June 2009, 09:49:04 »
They've fixed the issue where you can only press one key at once.
They've removed any claims that it'll handle 6 keys now. I don't know whether they were just ignorant, whether they had issues with their supplier or whether it was marketing that backfired with too many complains but there's no longer any 6-key claims made. (they never actually claimed it was n-key rollover, just that it'd handle six keys at once).
As far as I know it's a normal matrix that'll block on some combinations of three keys, if you want n-key rollover look elsewhere.
Owned: Raptor-Gaming K1 (linear MX)(Broken), IBM Model M UK, Dell AT102W, Left-handed keyboard with Type 1 Simplified Alps.
Offline Stevie Wonder
    • http://www.steviewonder.net/
« Reply #4 on: Wed, 17 June 2009, 09:50:47 »
Then why this post on Newegg as of 6-4-2009 by Crazymodder?
By the way, 4 keypress at the same time is the max on one row whereas 6 keypresses at the same time is the max across 2 rows
Could someone test a CTRL-WAEX type combo?  4 keys on the same row is no biggie but that one is somewhat real life.
Offline itlnstln
« Reply #5 on: Wed, 17 June 2009, 09:51:31 »
Quote from: IBI;97024
It would handle 6-keys on quite a few combinations.  Unfortunately, it failed on a few others.  QWAS would only give you 2 keys.
Offline aarroo
« Reply #6 on: Wed, 17 June 2009, 10:20:16 »
They actually are still claiming it can do 6 keys at once in the details section on their website for this keyboard.  You can check it out here. http://www.abs.com/app/Keyboard_M1_details.asp
I was really hoping this issue was remedied..seems as though it may have been but everywhere I read i get mixed reviews.  I really want to get a mechanical keyboard but im not about to drop <100$ bucks on one.
« Last Edit: Wed, 17 June 2009, 10:24:03 by aarroo »
Offline Special K
« Reply #7 on: Wed, 17 June 2009, 10:28:30 »
Quote from: itlnstln;97026
That particular combination seems like a pretty serious oversight for a keyboard being marketed to gamers.
Compaq MX-11800
Dell AT101W
IBM Model M 1391401 (11/13/87)
Ione Scorpius M10
Filco FKBN104MC/EB
Quote from: ripster;91740
LOL - we\'re on post #163 of this mega-thread and you\'ve gone from"keyboard n00b" to "keyboard sn0b".  We\'ve done our job.
Offline aarroo
« Reply #8 on: Wed, 17 June 2009, 10:36:23 »
as far as "qwas" key combination.  I don't ever see myself using this combination with more than 2 keys pressed anyways, would be extremely awkward. (unless I am to assume WAS would only allow 2 key press as well, in which case yes that would be an issue)
« Last Edit: Wed, 17 June 2009, 10:38:42 by aarroo »
Offline itlnstln
« Reply #9 on: Wed, 17 June 2009, 10:36:46 »
Quote from: Special K;97044
I don't game, and when I did, I used a Belkin Nostromo N50/52, but I am not too sure how often you would press more than two of the QWAS keys at the same time.  I would think this isn't as big of a problem as it appears.
Offline itlnstln
« Reply #10 on: Wed, 17 June 2009, 10:59:39 »
Quote from: ripster;97058
Well, it would be nice for someone to check something a little more realistic.
CTRL-WEAZX if you play FPS style games maybe. Crouching while throwing grenades and sending distress calls.
This would be a much better test, IMO.
Offline IBI
« Reply #11 on: Wed, 17 June 2009, 11:20:15 »
Quote from: aarroo;97038
Sorry, I did check but I'm not sure how I missed it.
Well it's not going to be generally any worse than any other keyboard under that price so I'd not let the bad advertising put you off unless you know of a keyboard of a similar price that doesn't block with any combination of six keys.
Offline Special K
« Reply #12 on: Wed, 17 June 2009, 11:25:00 »
Quote from: itlnstln;97052
Well most people leave the default WASD keys for movement, so I guess it depends what you have mapped to Q.  I guess I could see a scenario in which you were circle-strafing using W and D, while tapping on Q to activate some weapon, item, feature, etc.
It's certainly not the most common key combination for gamers, but I tend to map the most frequently used functions as close to WASD as possible, so I was just thinking that not being able to press 3 of QWAS could be a problem in certain situations.
Compaq MX-11800
Dell AT101W
Ione Scorpius M10
Filco FKBN104MC/EB
Offline aarroo
« Reply #13 on: Wed, 17 June 2009, 21:20:59 »
hmm... ok so basically 2 people are saying its fixed and 2 aren't.  This is the main reason I started this thread, I really wanna get to the bottom of this before I buy.
Offline Special K
« Reply #14 on: Wed, 17 June 2009, 22:19:40 »
Quote from: ripster;97260
I think ItlnStln answered your question.  The lastest review on Newegg ALSO indicates keyblocking on one row.
It is not technically a 6-key rollover board.
If I were a heavy gamer I'd keep looking.
I just tried the n-key rollover test posted in the keyboard forums with my Dell AT101W.  Pressing QWAS simultaneously only registers AQ.
I guess black alps aren't your best bet if gaming is a major point for you.
EDIT: My MX-11800 can't handle QWAS either - it just gives AQ.
« Last Edit: Wed, 17 June 2009, 22:22:30 by Special K »
Compaq MX-11800
Dell AT101W
Ione Scorpius M10
Filco FKBN104MC/EB
Offline Special K
« Reply #15 on: Wed, 17 June 2009, 22:23:56 »
Quote from: aarroo;97051
Your assumption is correct - pressing more than 2 keys of QWAS at the same time will only result in two keypresses being registered.
Compaq MX-11800
Dell AT101W
Ione Scorpius M10
Filco FKBN104MC/EB
Offline Special K
« Reply #16 on: Wed, 17 June 2009, 22:41:46 »
Quote from: ripster;97270
Not surprised with the ABS results but am with the Compaq. Do you have it plugged into PS/2 or USB through a dongle?
It's plugged straight into the PS/2 port.
Compaq MX-11800
Dell AT101W
Ione Scorpius M10
Filco FKBN104MC/EB
Offline Special K
« Reply #17 on: Wed, 17 June 2009, 23:56:34 »
Quote from: ripster;97276
Well, Wat got a different result.
Also, I believe Cchan said the 8100 and 11800 were part of the Cherry Premium Series (whatever that was) and were N-key.
Not sure what's going on here but shows how difficult it is to nail this down.
For the record - everyone that has tested them have found the Filco N-key models and the Topres to be fully 6-key at least.  Also my Das handled CTRL-QWAZX no problem.  (Teh (sic) key transposition thing is a different issue.)  Under $100 remains a vast wasteland for currently shipping 6-key boards.  Except the Filco Zero and I haven't seen a review on that one yet (worried the keys are too stiff for a gaming board).
In that link you posted, it says:
yep the mx11800 passes the test! If I was to imitate playing cs using the 1,2,3,4 and wasd + shift, ctrl and space, they all register when I press them all down. (only up to 8 keys though)
That doesn't look like they tested QWAS, which the combination I mentioned that would only register 2 keys on both my AT101W and MX11800.
Compaq MX-11800
Dell AT101W
Ione Scorpius M10
Filco FKBN104MC/EB
Offline IBI
« Reply #18 on: Thu, 18 June 2009, 09:39:34 »
Quote from: aarroo;97256
They fixed the initial bad batch where only a single key would register but as far as I know they haven't changed the design so it'll accept any combination of six keys.
Quote from: Special K;97281
On most matrixes WAS will give the same results as QWAS.
Offline cchan
« Reply #19 on: Thu, 18 June 2009, 11:13:37 »
Advanced Performance Line. The 8100 is part of it, whereas the 11800 is not. The 11800 is not NKRO. The 8100 is.
Incidentally, my Laser IFS80-2269-1 board (I believe that's what bhtooefr called it) passes qwas though blocks qwd. It's having some chattering problems though.
HP Envy17: Core i7-2760QM, 8GB DDR3, 128GB Crucial m4 + 750GB Hitachi, Windows 7 Home Premium x64, Cherry ML4100, Logitech M500, HP zr22w
IBM Thinkpad X60: Core Duo T2400, 2GB DDR2, 128GB Samsung 830, Xubuntu 12.04 x86, Cherry ML4100, Logitech M205, HP zr22w
Raspberry Pi Model B: BCM2835, 0.25GB DDR2, 8GB Samsung SD card, Raspbian Wheezy, human interaction devices as above
Offline Special K
« Reply #20 on: Thu, 18 June 2009, 11:28:58 »
Quote from: ripster;97370
Well, so much for recommending the Compaq 11800 to heavy gamers then.
Getting pretty lean there in the sub $100 6-key rollover keyboard choices.
What choices do we have for < $100?
Compaq MX-11800
Dell AT101W
Ione Scorpius M10
Filco FKBN104MC/EB
Offline Special K
« Reply #21 on: Thu, 18 June 2009, 11:42:03 »
Quote from: ripster;97378
In the new shipping boards I can't think of one other than the Filco Zero.  And I betcha that's a pretty stiff and loud keyboard.  Might be worth the tradeoff for some people.
Stupid keyboard manufacturers.  This one is easy.  Save money by using scissor switches, no LEDs and cheap case.  Put the money into some penny diodes and electronics.  Market the hell out of it.  Easy.
You also have the SteelSeries 7g, although the cherry blacks don't seem to be too popular on here.  I've never used them myself, I just don't see them mentioned much.
Compaq MX-11800
Dell AT101W
Ione Scorpius M10
Filco FKBN104MC/EB
Offline Special K
« Reply #22 on: Thu, 18 June 2009, 11:53:11 »
Quote from: ripster;97384
$111 at Amazon.
Some people have it here.  Another pretty stiff keyboard for gaming IMHO.
Wow, I didn't realize it was that expensive.  For some reason I thought it was only $60-70, that's why I mentioned it.
The funny thing about the keys being too stiff for gaming is that the keyboard is actually marketed towards gamers.  I'm not sure how they came to choose cherry blacks for that keyboard.  The Deck Legend, another keyboard marketed towards gamers, also uses the cherry black switches (although Deck recently released a tactile keyboard).
« Last Edit: Thu, 18 June 2009, 12:00:14 by Special K »
Compaq MX-11800
Dell AT101W
Ione Scorpius M10
Filco FKBN104MC/EB
Offline itlnstln
« Reply #23 on: Thu, 18 June 2009, 11:55:09 »
Cherry blacks are pretty stiff, more so than BS, IIRC.  Between the stiffness and the lack of tactility, most people around here don't like them too much.  Basically what ripster just said.
I'm trying to up my post count.
Not really.
Offline aarroo
« Reply #24 on: Thu, 18 June 2009, 14:39:08 »
some great responses here, beginning to really enjoy this forum.  I REALLY don't want to leap over the 100$ mark but if I must then.. well.. I'm sure you know how that goes.
I do tend to keep things for a VERY long time, so this would probably be a good investment.  Ive had a logitech elite keyboard (membrane eewWW)  for 5+ years now and the keys are just now starting to stick, plus the keyboard isn't recognized half the time when i boot up.  Time for a new one, thought I'd give this mechanical thing a try.
I guess the next question is, what switches are best for gaming.  I see much praise for the blue cherrys.  Ill do some searching as I'm sure this has been asked before.
Thanks again!
Offline wellington1869
« Reply #25 on: Thu, 18 June 2009, 14:46:46 »
yea, thats how we all started out ;-\
using: ms 7000/Das 3
Offline itlnstln
« Reply #26 on: Thu, 18 June 2009, 14:48:09 »
Quote from: aarroo;97457
If that's what you think, then don't read any of my posts.
Offline Special K
« Reply #27 on: Thu, 18 June 2009, 15:09:31 »
The Filco Zero uses white alps copies, correct?
I guess for gamers who don't want to take any chances with key blocking issues, the only option is to spend > $100 on a Filco.
Maybe in time, elitekeyboards will carry a Filco model using every major keyswitch type.  We already have cherry brown, blue, and black, along with white alps (I think, see my question about the Filco Zero above).
If Filco/elitekeyboards makes a board with black alps, won't that pretty much cover the spectrum, aside from buckling springs?
Compaq MX-11800
Dell AT101W
Ione Scorpius M10
Filco FKBN104MC/EB
Offline IBI
« Reply #28 on: Thu, 18 June 2009, 15:29:26 »
Rubber dome! The membrane is just the bit that registers the keys, it makes no difference to anyone.
I don't think the forum has reached a consensus on them. Personally, I feel that the typing feedback makes sod all difference for gaming and as long as the keys will reliably go down and register when you press them then nothing else is needed feedback-wise. I tend to play typical PC games though, if you like something more niche like beat em ups with lots of button bashing then maybe some are better than others.
Offline pex
« Reply #29 on: Sat, 20 June 2009, 08:26:07 »
Saying your keyboard offers 6-key rollover (or in whatever similar Engrish rendition), when it doesn't, is not mismarketing; it's fraud.  This is no inexact science.
Ж®Cherry G80-8113 (someday I hope to have one that reads magstripes, rfid cards, and smartcards), broken \'98 42H1292 Model M, some other Model M from a decade before that, 30 more keyboards in a box, 4 more lying here or there
Destroying Sanctity: my Model M project. Status: Dead.
