Well, I've been touch typing for 35 years, and for typing in randomly generated passwords with symbols I still need to look at the keys. Wallpaper wouldn't help, as my windows are always maximized on one of my monitors. If you can touch type random strings of symbols in a password field when all you're seeing is asterisks more power to you; I need labels.
No, you don't. ^_~
Not only these passwords are difficult to both type and remember, they have lower entropy than longer strings consisting of only letters as well. Rant over.
If you have to look where asterisk/hash/whatever is, you aren't *touch* typing (as in "capable of typing blindfolded"). The finger ought to know, where it should go. I look for confirmation though too. Distinction in colors/profiles helps.
The ErgoDox doesn't have enough keys for brackets, tilde, backslash, etc. anyway. Or rather, it does, but at the cost of moving useful special keys to other layers. Keycap printing won't help you in that case, unless you go with a custom set from WASD (which would end up expensive and kinda meh quality from the durability/feel standpoint).
On-screen keyboard or image can be a keystroke or two away in any modern desktop environment (at least KDE Plasma and newer MS Windows have some kind of a dashboard with widgets for sure, I don't use the rest regularly), and you can always print (or redraw) the picture and put it on your desk, next to the screen or somewhere.
How does mixing profiles work for you? Particularly cherry/oem/DSA? I considered going that route as it makes it easy to get the modifiers for the ergodox if I use DSA since the row doesn't matter. I worried that the profile difference would be too weird.
OK, let me start with this: DSA and DCS suck. DCS is ridiculously thin and has some sharp edges on more angled rows IME. DSA on the other hand has a different problem, i.e. it's uniform profile, which doesn't help on a flat keyboard; moreover, if you have MX Clear switches, DSA fits *tight* on the stems and you risk damaging the keyboard (switches) when removing keycaps (e.g., for cleaning). However, you might end up using them, because they're readily available at okay price.
The ideal setup would be more or less (well, take a look at jacobolus' experiments) similar to what Kinesis has done on the Kinesis Contoured/Advantage, but with higher quality keycaps. Higher quality means thick and made of PBT or better POM IMHO. Currently available options are Cherry/GMK/PLUM/Leopold for shorter angled, OEM (Vortex?) for taller angled and SP SA for tall angled/uniform, "dish" DSA might be worth consideration too.
My WIP setup consists of
- Cherry alphas ("dish" F&J) and numrow,
- DSA outer columns and bottom rows (this is temporary until I find some angled 1.5x/1.25x keycaps that wouldn't drive me mad for asymmetry),
- vintage OEM 1.5x bottom-row modifiers for the vertical 1.5x keys in inner columns, because they're angled inwards this way,
- vintage OEM extra tall F-row caps for the upper thumb keys, this is important,
- Cherry bottom-row keys turned upside down for the front thumb keys, because they're facing my palms like this.
