Can I buy a gon universal plate and hand wire matias quiet click switches to it or am I limited to cherry mx's ? Are torpre switches buyable without keyboards?
For a 60% build if I have to maintain the switches it would be nice to pop the top without desoldering. Do any of the plates allow for this and still allow for hand wiring or is an either/or kind of decision?
Is there an easy way to cut acrylic or something else findable at home depot etc for prototyping?
.... Is the a newb link I should be reading?
you cannot use a cherry plate with ALPS or matias switches.
Topre switches are not buyable outside the keyboard, except in the case of a non-functional keychain.
Lots of cherry plates support switch top removal without desoldering. It is not recommended for hand wiring unless you glue the switches to the plate (or you will pull the switch out when changing keycaps, etc.)
Acrylic does not make a very good plate material, but is excellent for prototyping.
There are some newbie guides, but I will have to dig up the links.
