Are your eyes bleeding? You can always change your theme.
Just asking, has anyone actually tried changing their Kensington trackball mice LEDs? I am bored with my standard red LEDs but have no idea if changing these LEDs will have any effect on the working of the optical trackball.
Logitech trackballs heavily depend on the color and texture of the ball AFAIK, it could have some (undesired) consequences.
Quote from: davkol on Fri, 03 October 2014, 06:17:21Logitech trackballs heavily depend on the color and texture of the ball AFAIK, it could have some (undesired) consequences.Does this have to do with the color of the light and the wavelength that the sensor is able to read? I wouldn't want my trackball to die just because I changed the LED color.
Quote from: berserkfan on Fri, 03 October 2014, 08:20:38Quote from: davkol on Fri, 03 October 2014, 06:17:21Logitech trackballs heavily depend on the color and texture of the ball AFAIK, it could have some (undesired) consequences.Does this have to do with the color of the light and the wavelength that the sensor is able to read? I wouldn't want my trackball to die just because I changed the LED color.I believe this has to do with the sensor being able to pick up the light. At one point I was chatting with Mkawa about building a switch for my PC that I would use a laser pointer to turn it on. He told me if I did that to use a green laser because 1, they are most sensitive to those wavelengths, and 2, those things are just bright as hell. Granted these are not the same sensors but I would believe the same principle still applies.
Quote from: Melvang on Fri, 03 October 2014, 08:26:01Quote from: berserkfan on Fri, 03 October 2014, 08:20:38Quote from: davkol on Fri, 03 October 2014, 06:17:21Logitech trackballs heavily depend on the color and texture of the ball AFAIK, it could have some (undesired) consequences.Does this have to do with the color of the light and the wavelength that the sensor is able to read? I wouldn't want my trackball to die just because I changed the LED color.I believe this has to do with the sensor being able to pick up the light. At one point I was chatting with Mkawa about building a switch for my PC that I would use a laser pointer to turn it on. He told me if I did that to use a green laser because 1, they are most sensitive to those wavelengths, and 2, those things are just bright as hell. Granted these are not the same sensors but I would believe the same principle still applies.But doesn't that mean that any bright LED would work? The Kensingtons all use red LEDs which don't look as bright as clear LEDs or light green or yellow LEDs. If I stay away from 'dim' colors like purple and blue, what do you think?
