Author Topic: Need help compiling the software for my keyboard.  (Read 3356 times)
Offline Moralless
« on: Wed, 01 October 2014, 08:37:40 »
Hello so I'm currently trying to make the firmware for a custom keyboard that I'm building with this layout by using Haku's firmware code and following matt3o's guide on DT.
But when I go into Windows Powersaver and type in:
cd ~/Desktop/tmk_keyboard-master/keyboard/gh60
and then type in make -f Makefile, I get the error:
make: *** [sizebefore] Error -1073741515
I've spent a good 2 hours reading through the code and google searching what I could do/what could've caused this but to no avail. If anyone could point me to what I can do to fix this would be great.
Here are the pastebins of each file that I've modified:
Makefile: http://pastebin.com/T1LT0Y1Q
Matrix.c: http://pastebin.com/8kqrNBQQ
keymap_common.h: http://pastebin.com/yG2c6jV7
keymap_poker: http://pastebin.com/efQ6RRGs
Also I have winavr installed and my OS is windows 8 64 bit.
« Last Edit: Thu, 02 October 2014, 12:04:01 by moralles »
Offline Moralless
Re: Need help compiling the software for my keyboard.
« Reply #1 on: Thu, 02 October 2014, 11:03:04 »
Update, I attempted to redo the whole thing on another computer where I haven't loaded any of the required programs on it before, but now I have a different problem. When I go to Windows powershell and do the same process:
make -f Makefile
I get an error in my keymap_common.h where it says:
keymap_common.h:46:1: error: parameter name missing
and then a whole bunch of errors in my keymap_poker.c file where it states basically every every key except 1,2,3,4,5,6,7,8,9,0 as undeclared and not in a function
and then another error where it states:
keymap_poker.c:13: error: initializer element is not constant
keymap_common file: http://pastebin.com/yG2c6jV7
« Last Edit: Thu, 02 October 2014, 11:22:37 by moralles »
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #2 on: Thu, 02 October 2014, 11:20:04 »
I'll have a look at the code when I get 2 minutes, but if I were you I would quickly put an ubuntu virtual machine and try from there.
Offline tlem
« Reply #3 on: Thu, 02 October 2014, 12:16:45 »
try removing the comma at the end
keymap_common line 45
    K40, K41,      K43,      K45,      K47,      K49, K4A,  \
Offline Moralless
« Reply #4 on: Thu, 02 October 2014, 13:22:47 »
Thanks for that, after doing that a few syntax errors showed up but ended up fixing but now when I compile it it shows an error where I couldn't find the file for:
../..common/debug.c:7: error: unknown fileld 'enable' specified in initializer
../..common/debug.c:7: error: unknown fileld 'matrix' specified in initializer
../..common/debug.c:7: error: unknown fileld 'keyboard' specified in initializer
../..common/debug.c:7: error: unknown fileld 'mouse' specified in initializer
and then a few warnings about excess elements in the union initializer.
EDIT: I found the debug.c file inside a different folder named common within tmk_keyboard-master and the code for it is here: http://pastebin.com/kyVGA4MY
« Last Edit: Thu, 02 October 2014, 13:31:05 by moralles »
Offline hasu
  • @tmk
« Reply #5 on: Thu, 02 October 2014, 13:51:07 »
Not clear where your error occured, post full gcc error message.
Could you build original codes before you edited them?
Offline Moralless
« Reply #6 on: Thu, 02 October 2014, 14:04:23 »
Here is what it said after I removed the comma after being pointed out by tlem:
78676-0
To get rid of the first error just added 2 random keys even though my matrix doesn't support those 2 extra keys (probably a bad move) and then the second one I just added a TRNS.
After doing the above when I tried to compile it again this popped up:
78678-1
And now I've no idea on what happened, but suspect this has something to do with me adding those two random extra keys.
Also I have no idea what you mean by building the original code.
Offline hasu
  • @tmk
« Reply #7 on: Thu, 02 October 2014, 14:20:13 »
hmm, second error at debug.c doesn't seem to be your error, perhaps my code includes any error.
I meant intact downloaded source codes without your edit with the word 'original code'.  You'll need to confirm 'original code' can be built without errors before edit.
Offline Moralless
« Reply #8 on: Thu, 02 October 2014, 14:47:56 »
So I finally got my VM w/ ubuntu set up as matt3o suggested and with the same code posted in the OP, I was able to make a hex file but the keys aren't in the right places. However I tried making a hex file with the original code on my main OS - windows 8 64 bit and I got this error :
78686-0
Offline strict
  • TKL Zealot
« Reply #9 on: Thu, 02 October 2014, 14:57:09 »
Are you sure PowerShell is able to compile this? I've been using Cygwin without issue.
Offline Moralless
« Reply #10 on: Thu, 02 October 2014, 15:00:43 »
Yeah I'm starting to think it's that aswell. Haven't really researched the capabilities of powershell now that I think of it.
Offline hasu
  • @tmk
« Reply #11 on: Thu, 02 October 2014, 15:02:58 »
congrat.
Very tedious to install tools on windows 8, forget it.
Oh, PowerShell? I didn't know that at all.
As strict said, you need unix like shell like Cygwin bash to build tmk.
Offline Moralless
« Reply #12 on: Thu, 02 October 2014, 15:52:17 »
congrat.
Thanks, just need to figure out how to fix the layout since it seems all the keys are jumbled up everywhere haha
Offline strict
  • TKL Zealot
« Reply #13 on: Thu, 02 October 2014, 16:40:11 »
Also, I wouldn't recommend using WinAVR. Its way out of date. I've been using MHV AVR Tools with great success.
Offline domoaligato
« Reply #14 on: Fri, 03 October 2014, 00:57:21 »
you should not use powershell.
you should use a command prompt "cmd.exe" . they are very different.
also you need to patch your winavr using this download.
This is the modified msys-1.0.dll that fixes most compile issues.
http://www.madwizard.org/electronics/articles/winavrvista
extract msys-1.0.dll to C:\WinAVR-20100110\utils\bin and overwrite the existing one.
also please try to compile the gh60 firmware with
make KEYMAP=poker
sometimes that works better then make -f Makefile
one last thing. try compiling the gh60 firmware from a fresh download after all the stuff above to validate that your build environment is working before editing the layout files.
