Author Topic: Ducky Shine4 duel-color backlit  (Read 8409 times)
Offline sdiearly
« on: Mon, 13 October 2014, 22:17:18 »
Hello GHers,
I am lucky to be invited to join Ducky Shine 4 Product Launch Event last week.
https://www.facebook.com/117547488320354/photos/a.657835394291558.1073741838.117547488320354/727858637289233/?type=1&theater
In the end of this party, Ducky give us a gift and I can share to you.
=== Shine 4 unboxing ===
Box size is same as Shine3
The box art is changed into colorful theme.
Contents:
Besides manual and warranty license, we have USB cable/WASD key caps/key puller.
Front view of keyboard, the height and angle of inclination are lower now.
We have a picture about engineering sample, there are two buttons in function.
I think it's pity that Ducky cancel this design and back to 108 keys layout.
Art of space bar of this year, it is horse according to lunar calendar.
Case in plastic with Hair-Line Surface. Bring Shine4 to be high quality.
In the bottom side, Ducky add their product line icon.
(mini/premier/zero/legend are different logo)
USB port connection: set in the middle position.
New design in bumpers, two assemble rubber feet can change the height.
Power on!
The backlit function is like Ducky-Mini, too complexity to describe.
Check manual is better to understand their design.
Here is something special, CM1/CM2 mode will have the highest priority to show backlit function.
So shine4 can combine two modes on backlit now.
Another great point.
To prevent user trigger wrong setting of USB delay and repeat rate,
Shine4 add FN+ESC to call function layer, then user can change the setting.
This feature is like Ducky Advisior which is implemented on Ducky-Mini.
« Last Edit: Mon, 13 October 2014, 22:24:52 by sdiearly »
My favorite 60%:  TEX-Beetle
                 80%:  KBtalKing Race
                100%: Cherry G80-3494, Zowie Celeritas
Offline Flyersfan1
  • Hi!
Re: Ducky Shine4 duel-color backlit
« Reply #1 on: Mon, 13 October 2014, 22:18:35 »
I like the brushed finish of the case. Thanks for sharing the pictures!
Quote from: Photekq
Offline dante
« Reply #2 on: Mon, 13 October 2014, 22:20:35 »
Is this lower profile than the Ducky Shine 3?  Not a fan of the huge waste of space around the keyboard.
Offline sdiearly
« Reply #3 on: Mon, 13 October 2014, 22:27:19 »
Yes, Shine4 is lower than Ducky others.
If remove the feet, Shine4 is like Cherry MX2.0 but with OEM profile keycaps.
                 80%:  KBtalKing Race
Offline Hyde
  • White Tofu Extraordinaire
« Reply #4 on: Mon, 13 October 2014, 22:37:34 »
I know it's the year of horse and all but, I still prefer a simple spacebar.  Like a dash or something.
Also I find it odd how they added the circular dot on the caps lock key, but it still doesn't use 2 separate LED.  Reason being it is still unlit (assuming caps lock off).  I like how they implemented in Poker 2 that it has 1 LED for legend and 1 for indication.
Although the rest is not bad, but I feel like at this point Das has better implementation on this style of design.
Offline vestigev2
« Reply #5 on: Tue, 14 October 2014, 02:20:26 »
Thanks for sharing. Does it come with a plain spacebar like previous Shines or is it stuck with the YotH spacebar?
Offline Oobly
« Reply #6 on: Tue, 14 October 2014, 03:08:41 »
Thank you very much for sharing this with us! I like it a lot!
Low profile, dual colour LED's with complex lighting modes, premium case design. And they finally made a good USB connection position, although I'm not a fan of the bend. Is the USB still Mini or have they switched to Micro yet?
Very nice. I hope the TKL version looks as good and that they release a version with MX Clears :)
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline Master of the Ocean
« Reply #7 on: Tue, 14 October 2014, 03:29:24 »
It looks ok
Offline tbc
« Reply #8 on: Tue, 14 October 2014, 03:40:51 »
lol.
i like the originality of their new features.
i was really curious how they were going to differentiate.
Offline _PixelNinja
  • C=Q/V=ε(A/t)
« Reply #9 on: Tue, 14 October 2014, 04:56:05 »
A part from the gigantic bezels, I quite like how this ended up. Thank you for sharing.
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #10 on: Tue, 14 October 2014, 05:02:26 »
Ooohhh the packaging. :D it looks really nice!
Hopefully their tkl model would have some difference as well.
Offline C5Allroad
  • Formerly HUNTERANGEL121
« Reply #11 on: Tue, 14 October 2014, 16:37:25 »
I'm not really digging the ginormous space around the board....
« Reply #12 on: Tue, 14 October 2014, 22:06:12 »
One thing that turns me off is how reflective the keyboard is.
Maybe I'm biased, using HHKB (with almost no visible bezel) and QFS (with matte black rubberised case).
Offline Oobly
« Reply #13 on: Wed, 15 October 2014, 05:56:01 »
Also a bit concerned about that stuff on the enter key.... Is that an undocumented feature or just something that happens when you REALLY like your new keyboard.
Offline sdiearly
« Reply #14 on: Wed, 15 October 2014, 06:22:13 »
That's reflection of some liquid drop
                 80%:  KBtalKing Race
Offline Lpwl
  • lpwl.bigcartel.com
    • My O-ring Store
« Reply #15 on: Wed, 15 October 2014, 08:48:00 »
I agree with you but "new Ducky Shine 4 keyboard" is expected to be shiny !
« Last Edit: Wed, 15 October 2014, 08:53:55 by Lpwl »
Offline 00zeRO
  • mechanicalkeyboards.com
  • * Commercial Vendor
  • The 00verseer of Vault 77
    • Mechanical Keyboards
« Reply #16 on: Wed, 15 October 2014, 18:02:07 »
The dot on the Caps Lock is for indicating when it is recording keycap illumination and color...but I agree. My problem so far is that it seems that the Scroll, Caps, and Num Lock are only one color and cannot be programmed to be a different color. If someone figures it out, please let me know...
Daily Driver: Typist A w/Midnight Dawn | Kailh BOX Clicks
Junktown 2: Now on eBay!
« Reply #17 on: Wed, 15 October 2014, 21:50:09 »
Oh, the colors fight each other?  I wasn't super keen on the board, but since the colors duel, it could be awesome.
