I did exactly nothing but pick the keyboard up to play fallout:NV. When I did so, I noticed the omnipresent numlock LED was off. Also, I soon discovered the keyboard didn't type. I tested it a bit, and found that if I disconnected the left half, the right half would be noticed (windows "hardware added sound" -- plus, it would type) but if the two halves were connected, Windows would not notice that a thing was plugged in.
Some of you may know I'm using a phone cord instead of a TRRS cable, and its true the cable was a bit squished by the stainless steel case. So I desoldered the too-short jack, and cut a longer cord and soldered it into place, and using an inline coupler, found that nothing had changed.
There hadn't been any trouble with the it before, but I redid the not-great I/O expander pins, tried again, and got nothing unless that half was unplugged.
I'm new to electrical work at this level. What do I even test for / look at? Why did it die suddenly, and how do I resurrect my full ergodox keyboard?
