Author Topic: Where can I get an Ergodox?  (Read 2074 times)
Offline cksa361
« on: Sat, 18 October 2014, 04:09:28 »
Just found out about the ergodox/mechanical keyboards a few days back!!! VERY keen to get one. I am good at soldering and assembling from parts in general so just acquiring the parts isn't an issue (electronics engineer by profession). However, I don't want to get a PCB fabbed up just for this and spend time laser cutting out a case for it....would be nice if I could just get the parts ready to be assembled....sort of like the massdrop runs.....but it doesn't seem to be an active group buy at the moment :(
Are there any available sources out there?
Offline jackalope
  • Now with 20% more soul.
eh o well
Offline frosty
  • jukebox hero
Re: Where can I get an Ergodox?
« Reply #2 on: Sat, 18 October 2014, 06:01:44 »
https://www.massdrop.com/ext/ergodox/assembly.php
Isn't that just the installation instructions lol.
afaik, I think you'll have to wait for a drop or buy it off geekhack classifieds.
Offline jackalope
« Reply #3 on: Sat, 18 October 2014, 11:46:46 »
It also has the parts list.
2 x PCB
10 x Acrylic case Plates (see this image for layer ordering)
1 x Teensy USB Board, Version 2
1 x MCP23018 I/O expander
1 x 3.5mm TRRS connector
1 x USB mini B plug
1 x 0.1uF ceramic capacitor
76 x 1N4148W-7-F diode (surface-mount)
1 x 2.2k ohm resistor
3 x 3mm T1 LED
2 x 220 ohm resistor
76 x Cherry MX switch
2 x USB cable Male A to male mini B
1 x TRRS cable
14 x Case screws/nuts (16 for Full cases)
pcb can be found ( http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=537 )
eh o well
Offline frosty
  • jukebox hero
« Reply #4 on: Sat, 18 October 2014, 12:07:43 »
2 x PCB
1 x USB mini B plug
3 x 3mm T1 LED
1 x TRRS cable
Ah, I see :)
Op would need to source a case, which I feel is the hardest if he wants to build one using parts he can find
« Reply #6 on: Sat, 18 October 2014, 20:55:26 »
Welcome to Geekhack!
A flood of Ergo Dox replies already.  I knew it was popular, but not THAT popular ;)  Where's tp4 these days?
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #7 on: Sat, 18 October 2014, 22:12:05 »
Busy promoting.
« Reply #8 on: Sat, 18 October 2014, 22:55:29 »
Busy promoting.
LOL I guess he doesn't need to preach to the converted!
Offline snowe
« Reply #9 on: Tue, 21 October 2014, 02:00:23 »
A list of all of the parts can be found on ergodox.org with links to the respective parts on DigiKey. The rest can be found on falbatech and mechanicalkeyboards.com
Offline micceo
« Reply #10 on: Thu, 23 October 2014, 02:51:51 »
For the case you can also source the acrylic sheets and cut a case out, if you have access to a cheap laser printer.
