Author Topic: JD40 Keycaps  (Read 2288 times)
Offline crimsonTofu
JD40 Keycaps
« on: Sun, 19 October 2014, 21:22:44 »
Hi everyone, I was considering buying a JD40 from [ctrl]Alt and was wondering where everyone gets their keycaps from.
« Last Edit: Sun, 19 October 2014, 21:30:14 by crimsonTofu »
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
Re: JD40 Keycaps
« Reply #1 on: Sun, 19 October 2014, 21:27:04 »
Well there isn't really anything about the layout that makes it incompatible with any set, some of the caps are just in different places
Offline Sent
  • Simplistic Serenity
  • ¯\_(ツ)_/¯
Re: JD40 Keycaps
« Reply #2 on: Sun, 19 October 2014, 21:28:18 »
I prefer using DSA sets for my JD40.  They're all the same profile so it doesn't really matter where I place the caps.  I won't have any issues with certain caps restricted to certain rows due to different heights/profiles.  There's a ton of DSA sets floating around now and even some GB's in progress (like Valentine) that use the profile.
Offline hwood34
  • underwater squad
  • #1 CL stan
Re: JD40 Keycaps
« Reply #3 on: Sun, 19 October 2014, 21:29:01 »
Yeah DSA is your best bet so the row heights don't get all messed up
Offline NeedAFix
  • Ten Seconds until Midnight
Re: JD40 Keycaps
« Reply #4 on: Sun, 19 October 2014, 21:33:50 »
-Maniacal laugh- You can always just grind them to the desired height you want! -revs 35k rpm dremel with sandpaper bit-  >:D
The Bird of the Hermes is my name,
eating my wings to make me tame.
Re: JD40 Keycaps
« Reply #5 on: Sun, 19 October 2014, 22:03:01 »
There have been rumors of a group buy 'coming soon' for a jd40 only set.
For one of mine I will probably use my Round 5 jd40 set.
Offline Oobly
Re: JD40 Keycaps
« Reply #6 on: Wed, 22 October 2014, 14:09:38 »
This set had a Smallfry (JD40) kit: http://www.pimpmykeyboard.com/deals/greentea-base-kit/
I'm sure there will be more later.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline Skuloth
Re: JD40 Keycaps
« Reply #7 on: Thu, 23 October 2014, 07:50:30 »
http://geekhack.org/index.php?topic=63768.0
This is a set that will be starting within a month or two with JD40 support.
Planck w/ Zealios
