I've heard that after a while, much like the ABS plastic caps, they will wear and fade over time since it's only a zinc plating. Anyone have any info to support or refute this?
I've heard the same. I think there are some posts with the looks of it after a few months of usage. >< They looked awful, not sure if it is fixed in this iteration.
I really hate that reddit user for misinforming people. I've had a 37-key blank set that I used for over 5 months daily, and never had any wear. I also have an 87-key blank set, that also hasn't had signs of wear.
The legended zinc caps, as I've had to reiterate in other threads are problematic due to the legend itself. If one were to not take care of their hygiene, or have issues that wear away the coating/scratch it, once you wear to the legend, it's basically game over. Given my choice of blank caps, I've never had an issue, as even if I did wear the coating, which hasn't happened yet, there's no weakened part of the cap where water, oils, etc... would deteriorate the cap.
There's nothing wrong with zinc caps as long as you're taking care of your hands, and your nails. Outside of wearing the coating with oils, water, or eating at your desk, the only other way to get through the coating through normal use would be not taking care of your nails, or having choppy, unsmooth nails, which would scratch or chip away the coating.
