Author Topic: [IC] JD40 keycap sets...  (Read 3699 times)
Offline 00zeRO
  • mechanicalkeyboards.com
  • * Commercial Vendor
  • The 00verseer of Vault 77
    • Mechanical Keyboards
« on: Fri, 31 October 2014, 13:18:11 »
I am curious, how many have JD40 and would be interested in a keycap set that would be specifically designed for the JD40/Small Fry keyboard?
I am looking to see what would the most common layouts be for those of you with them. I am speaking primarily of the odd shaped keys and their functions. I know what JDCarpe originally posted as possibilities, but those of you with them as Daily Drivers, what layouts are you using?
Is this worth doing as a separate GB?
« Last Edit: Thu, 06 November 2014, 13:39:53 by 00zeRO »
Daily Driver: Typist A w/Midnight Dawn | Kailh BOX Clicks
Junktown 2: Now on eBay!
Re: [IC] JD40 keycap sets...
« Reply #1 on: Fri, 31 October 2014, 13:32:56 »
I think it's more worth it to include JD40 kits in a larger GB, as opposed to selling JD40 sets on their own.
QFR | MJ2 TKL | "Bulgogiboard" (Keycon 104) | ctrl.alt x GON 60% | TGR Alice | Mira SE #29 | Mira SE #34 | Revo One | z | Keycult No. 1 | AIS65 | First CW87 prototype | Mech27v1 | Camp C225 | Duck Orion V1 | LZ CLS sxh | Geon Frog TKL | Hiney TKL One | Geon Glare TKL
Offline 00zeRO
« Reply #2 on: Fri, 31 October 2014, 13:46:24 »
You are right...hey, maybe I can do a GB for blank white PBT keycaps for the odd size and Crayolas for people to do custom legends...
Offline LechnerDE
« Reply #3 on: Fri, 31 October 2014, 13:51:41 »
I agree.
I'd rather buy a TKL set that includes all the keys I need to also use it on a JD40 than a set that I could only use on a specific board.
Offline rofelos
« Reply #4 on: Fri, 31 October 2014, 13:58:33 »
I would be very interested in a set specifically for the JD40 because i have two of them that i use very often and i really need a new keyset.
Offline 00zeRO
« Reply #5 on: Fri, 31 October 2014, 14:08:04 »
Ideal profile? Would you want PBT or ABS Doublshot?
Offline 00zeRO
« Reply #6 on: Fri, 31 October 2014, 14:09:00 »
Of course, all of this may have a monkey wrench since JDCarpe is coming out with the JD45...
« Reply #7 on: Fri, 31 October 2014, 14:11:21 »
ABS DS
Offline 00zeRO
« Reply #8 on: Fri, 31 October 2014, 14:17:39 »
ABS DS
DCS/OEM/Cherry, SA, or DSA?
« Reply #9 on: Fri, 31 October 2014, 14:19:33 »
ABS DS
Ideally Cherry profile from GMK, but that requires 250 MOQ, and I don't think there are 250 JD40s in the wild. :)
So DCS profile from SP? :)
Offline 00zeRO
« Reply #10 on: Fri, 31 October 2014, 14:29:41 »
ABS DS
It's the creator...
All jokes aside...have DCS Rows 2-5 essentially. Can they do 1x1.25 in any row but bottom?
