Hello! I am currently in the process of bolt modding my two full sized Model Ms but I have run into a snag. The '87 model appears to have a dead column on the membrane and I have to idea why. The column in question is the one responsible for "9","0","p","[",";","'", and "/". I have tried the membrane assembly from the '91 with the controller from the '87 and it works flawlessly. I have also checked the continuity between the pads and the contact at the top where the membrane plugs into the controller and there is none. However, there is no visible damage to the trace at all. Any ideas as to what could be causing this or how to fix it? I'm guessing a new membrane assembly from Unicomp is my best bet at this point but I would love if I could keep it all original! Thanks!
