Author Topic: Das Keyboard III vs FILCO  (Read 10854 times)
Offline joneslee85
« on: Tue, 15 December 2009, 05:47:24 »
The question is why FILCO is better than Das? I read that Das has some controller problems, but is there any other things that Filco surpass Das?
⌨Realforce 87U ⌨HHKB Lite 2 (JAP) ⌨HHKB Pro 2 ⌨Filco Tenkeyless (Black MX) ⌨DAS III Ultimate
Calvin Harris is the Pineapple Legend!!! Check out new site twitter.com/pineapplelegend
Offline leos
« Reply #1 on: Tue, 15 December 2009, 06:00:01 »
its your opinion if you forget the controller issues.The das case looks better for me and the filco keys are far better then the das keys. Also the klicky sound is differed for me.
das
filco
« Last Edit: Tue, 15 December 2009, 06:11:58 by leos »
HHKB 2 Pro Black in use :typing:
Offline ch_123
« Reply #2 on: Tue, 15 December 2009, 06:11:48 »
Build quality is meant to be better on the Filcos. Ive seen more than one bashed up Das
Offline leos
« Reply #3 on: Tue, 15 December 2009, 07:03:19 »
Quote from: ch_123;142540
meant??? i have the most of the filcos and all the das until version 3 without S.
So i can compare. Just i say each one has a differed opinion.
I am not a das funboy but it is not so bad as you think.
If i chose between das or filco then i take TOPRE.
I know this going to flame war............................
Offline timw4mail
    • https://timshomepage.net
« Reply #4 on: Tue, 15 December 2009, 07:16:03 »
The Das is designed by a marketing company, the Filco is designed by a keyboard company, therein lies the issues of quality control on the Das side.
Pointing devices- CH Products DT255 (With Lapis Lazuli ball), Razer Salmosa, Logitech MX400
Buckling Springs - IBM Model M 1391401 (1987) & IBM Model F AT
Cherry MX Blue Switches - iOne Scorpius M10 "otaku"(2009) & OCN-branded Ducky keyboard
Cherry MX Brown Switches - Compaq MX11800 & Cherry G80-8963LUBUS-2 (MX8100) & Filco FKBN91M/JB (Japanese Tenkeyless)
Cherry MX Black Switches -  US Micro Products Metal Keyboard USMP-KX065-TB-USB-A
Fake Cherry MX White Switches - Qtronix Scorpius 32 keypad &  Chicony KB-5191
White round SMK Switches - Gold VTech label keyboard
SMK blue Monterrey Switches - Chicony KB-5181
Damped tactile ALPS - Apple AEKII
Blue NEC Switches - NEC APC-H412
Quote from: bigpook;129625
: ) life is like a box of webwit. you never know what you are going to get.
Offline ch_123
« Reply #5 on: Tue, 15 December 2009, 07:32:23 »
Quote from: leos;142542
Based my opinion on a number of bashed up Das 3s I have seen. Filcos don't have that problem.
Also, are you saying that you have all of them up to and including the Das 3, or do you not have one?
Topres are well built alright, but that doesn't have much to do with what the OP asked.
« Last Edit: Tue, 15 December 2009, 07:40:10 by ch_123 »
Offline AndrewZorn
« Reply #6 on: Tue, 15 December 2009, 07:38:33 »
if the people behind the Das admit problems, how can you say it is better than a filco
NOPPOO CHOC MINI FILCO TENKEYLESS KBC POKER CHERRY MX11900
In order of preference, I\'m afraid.
Offline leos
« Reply #7 on: Tue, 15 December 2009, 08:15:03 »
Quote from: ch_123;142548
yea i know the das3 has the controler issue. and yes i have all the das except the das "s". I just say that the build quality is not so bad as you think.
Offline leos
« Reply #8 on: Tue, 15 December 2009, 08:19:35 »
Quote from: timw4mail;142543
dont think so, because both of them they are come from a real keyboard company...
both are oem boards
costar
Offline timw4mail
« Reply #9 on: Tue, 15 December 2009, 08:22:12 »
Quote from: leos;142556
both are oem boards
costar
There's a difference between design and manufacturing. I almost think Diatech designed their own controllers, considering how almost every other branded costar keyboard seems to have some issue or another.
Offline leos
« Reply #10 on: Tue, 15 December 2009, 08:25:20 »
Quote from: AndrewZorn;142551
i dont say its better i say that some things on das like better then on the filco.
1, the case
2, the leds
due the controller issues its no comperable to a filco.
i would like to have one keyboard with the look of das and the keys of a filco. Without controller problems.
Offline leos
« Reply #11 on: Tue, 15 December 2009, 08:31:13 »
Quote from: timw4mail;142557
any proof that Diatec designed their own controllers? they have also problems.
filco test
filco another test
filco again
nobody is perfect even diatec!!!!!
« Last Edit: Tue, 15 December 2009, 08:37:36 by leos »
Offline AndrewZorn
« Reply #12 on: Tue, 15 December 2009, 08:56:12 »
yes but das is a lot less perfect!!!!!!
EDIT arent those all Zero boards?  filco = majestouch around here
Offline 1839cc
« Reply #13 on: Tue, 15 December 2009, 08:59:21 »
Wasn't it the ALPS based Filcos that had that issue, and not the ones with Cherry switches?
i have seen unix admins with john deere trucker hats, and even seen a man in a nascar shirt correct a passerby's klingon.
Offline bigpook
« Reply #14 on: Tue, 15 December 2009, 09:07:02 »
I have both but would go with the filco.
The filco has better keys, the letters are wearing  off on the Das after about a year of use.The filco is still going strong.
The Das is all shiny which may be a plus for some users. For me it looks cheap and shows smudges and finger prints to easily.
I  don't have the issue with the controller that some do, but maybe thats because I don't type over 100 wpm.
Offline leos
« Reply #15 on: Tue, 15 December 2009, 09:12:43 »
Quote from: AndrewZorn;142564
onother filco link
not all of them
youtube user is wellington1869....maybe a geekhack member??
Offline ch_123
« Reply #16 on: Tue, 15 December 2009, 09:19:13 »
Quote from: leos;142572
onother filco link
not all of them
Yes, that's a Filco Zero he's using. The Majestouch ones don't have those problems.
Offline leos
« Reply #17 on: Tue, 15 December 2009, 09:21:27 »
Quote from: bigpook;142569
yes the keys are superior
its your point of view. i like shiny. Like the ps3
btw, i can reproduce the issues on das because i write lot in bursts.
words like.... the , das, data, klären, nockenwelle, and many others.
Offline bigpook
« Reply #18 on: Tue, 15 December 2009, 09:30:02 »
Sounds like you may like the Das then, but the controller issue will hose you.
Filco?
I have a PS3 too. Its on the shelf and I  don't actually touch the shiny parts. I dust it occasionaly.
Shiny is personal pref., its all good.
All in all, I like the filco better mostly because its not shiny. The letters wearing off of the keys can be a show stopper for some people, I don't really care so much.
The filco is also cleaner looking to me. But all of that is just my personal opinion.
« Last Edit: Tue, 15 December 2009, 09:32:45 by bigpook »
Offline leos
« Reply #19 on: Tue, 15 December 2009, 09:30:05 »
Quote from: ch_123;142575
you are right, i found this link
geekhack
i asume because i collect the boards and dont use them, going to this mistake.
seems only the fukka filco has this problems.
Offline leos
« Reply #20 on: Tue, 15 December 2009, 09:36:54 »
Quote from: bigpook;142581
Filco?
like the das shiny look ....yes alot, not the errors.
btw, here in germany we have only the choice to go das, because we dont have a distri company for filco or topre.
i use @work and @home only topre. I collect every mechanical keyboard i found on ebay or lokal markts here.
Offline leos
« Reply #21 on: Tue, 15 December 2009, 09:42:09 »
Quote from: ripster;142573
Old Das versus Filco review here.  In terms of the most important thing, key feel, the two are almost identical.   Haven't seen the new one yet.  They are taking preorders (again.)
we must wait until early 2010 to take a look to the new das ssss.
http://www.getdigital.de/products/Das_Keyboard_Model_S
Offline leos
« Reply #22 on: Tue, 15 December 2009, 09:46:35 »
Quote from: ripster;142585
And remember even on that Fukka Filco the problem was not felt to be as bad as the Das's.   So in other words, plenty of people have used the Filco Fukka and never seen the problem.
same with the das if you dont write above 100WPM
how much is 100 wpm in charakters per min???
---edit---
google helps us wikipedia
i think i am under 100wpm. if i use this open source trainer i ll make 470+ keystrokes per min. If i use tprx i make 132 wpm.
who has right?
Das has superior distribution and (usually) marketing.   The stupid Japanese keep cranking out keyboards like this.
Not in europe
look at the big shops and you find nothing about a "das"
« Last Edit: Tue, 15 December 2009, 10:09:55 by leos »
Offline erricrice
« Reply #23 on: Tue, 15 December 2009, 10:02:18 »
Quote from: leos;142588
Not in europe
100 wpm is 500 cpm.
But it is not the sustained speed that is the problem it is the bursts, like you said before on words like the, and , .com stuff like that it might cause a problem.  The first review I saw of the zero fukka the problem was with notepad becoming ntoepad because he bursts that word very very quickly.
But I'm typing on a zero fukka right now, and have been for about a week and have only had it transpose a few times, and it was on very very fast roll.  I type regularly at about 80 wpm and get up to 100 if I'm trying to type for speed.
I\'m selling all my Shizz! Please buy it!
White ALPS: Northgate Omnikey 101-NCS(Real-Complicated)****Filco Zero FKBN87Z/EB(Fukka Simplifieds)****Siig MiniTouch(XM Simplifieds)
Black ALPS: Black Dell AT-101W(Real-Complicated)****ABS M1(Modded Black ALPS, Linear)
Buckling Spring: Model M 1391401(1988 & 1993)
Cherry Blues: DAS III Pro
Cherry Blacks: Cherry G80-11900
Cherry Browns: 3X Cherry G80-8113LRCUS-2
Cherry MY: G81-7000HPBUS-2****G81-3000LANUS-0****Modded to 20g
Rubber Dome: HHKB Lite 2 (White & Black)
Logitech G5[/FONT]
Erricrice\'s Song of the Day: Gorillaz - El Maņana
Yup, Blatantly stealing this from you Kishy, hope you don\'t mind, it\'s a great idea.
Offline bigpook
« Reply #24 on: Tue, 15 December 2009, 10:28:20 »
FWIW, I have the fukka filco and don't have a problem with transposition errors.
It's a nice keyboard too.
Offline erricrice
« Reply #25 on: Tue, 15 December 2009, 10:45:54 »
Quote from: bigpook;142594
Yeah I'm loving it!  Definitely a good purchase.
Logitech G5[/FONT]
Offline elbowglue
« Reply #26 on: Tue, 15 December 2009, 11:03:11 »
I find the das great for typing, I never hit the transposition problem, although I have had to modify my pattern of typing just for this keyboard.
This is how I type now:
http://www.youtube.com/watch?v=Ik5MgEas3VY
It's awesome because I never transpose letters anymore.  Thank you das keyboard you have changed my life.
My keyboards: Filco Cherry Blue Tenkeyless(daily home), Compaq MX11800 (modded to blacks), Compaq "MX 84u",  Wellington\'s Dampened Endurapro, Pinkalicious Filco Blue Cherry, Chicony KB-5191, Chicony KB-5181, Desko MOS 5023 UP "elbowglue" spos (modded to blues), Siig Minitouch (monterey blue), SMK-88 (blue cherries), Ricercar SPOS
Smallest to biggest keyboards in inches (Length X Height) - Length is most important for a midline mouse position
KBC Poker: 11.6 x 3.9 - HHKB: 11.6 x 4.3 - Siig Minitouch (Geekhack Space Saver): 11.6 x 6 - Deck/Tg3 82: 12 x 6 - Noppoo Choc Mini 12.4 x 5.3 - Compaq "MX 84u": 13.1 x 7.5 - Filco Tenkeyless: 14 x 5.3 - Cherry "ricercar spos" G86-62410EUAGSA: 14 x 7.75 - Topre Realforce 86u: 14.4 x 6.65 - Desko "elbowglue spos" MOS 5023 UP: 14.5 x 8.4 - IBM Model M Spacesaver: 15.3 x 7 - G80-1800: 15.9 x 7.1 - Adesso MKB-125B: 16 x 7.3 - Compaq Mx11800, Cherry G80-11900: 16.25 x 7.5 - Filco Standard: 17.3 x 5.4 - Unicomp Endurapro: 17.9 x 7.1 - Adesso MKB-135B: 18.3 x 6.0 - Cherry G80-3000: 18.5 x 7.6 - IBM Model M, Unicomp Customizer: 19.3 x 8.27
Offline ch_123
« Reply #27 on: Tue, 15 December 2009, 12:11:18 »
Quote from: leos;142584
There's a company in the UK that sells them. They ship to Europe too. Some company in Finland sells Topres too.
Offline leos
« Reply #28 on: Tue, 15 December 2009, 12:18:31 »
Quote from: ch_123;142610
keyboardco.com??? ...they dont have differed filcos until mid Januar.
and www.verkkokauppa.com in finland ....sells only the 105keys Realforce.
if you know another company who sells the HHKB and the realfonce ansi layout plz tell us.
Offline ch_123
« Reply #29 on: Tue, 15 December 2009, 12:20:06 »
Keyboardco sells the ANSI Filcos already.
