Greetings everyone,
I usually read this forums but I never had the chance to make myself an account and post regularly on it. I've spended tons of hours reading guides here and reviews about keyboards and such.
After saving enouth cash and having the chance of knowing someone that is going to the USA and is able to bring me a mechanical keyboard, my time is up to get my very first and probably only mechanical keyboard I'll ever have. I live in south america, so having a warranty from the keyboard brand does not mean anything for me, since I'll not be able to ship the keyboard all the way to USA to have it check-fix/exchanged, so I must make a really good selection.
My native language is Spanish, and I like writing without any mistakes so I do use the ´ key that allows me to make áéíóú, and ¿? and ¡!, so I did a massive research on keyboards at sale with the 105 key layout, and I found none.
So the main problem about switching to the 104 key layout is that the missing key is one between the left shift and the 'z' key, that allows me to do: '<' and '>' that for me is very important since I program a lot. So I did some research and I wanted to know your thoughts on remapping '<' and '>' to the right control key and the menu key on its left; is this possible?
Going to the main point now (sorry this is getting long):
I have decided that the most suitable switch for me is the brown, since I do a lot of gaming, and I do lots and lots of tapping, so I'm afraid of the blue switches won't make it, and also cause my coworkers and family will complain if I get a blue one, due the noise.
My budget is 150$ for it (including shipment), and only if its worth it up to 200$.
I see a lot of people talking so much and making so many comparisons to the FILCOs that it seems like it's the best brand of keyboards(although they are a bit overpriced), and I wish there was a way to get a brown switches one with the full layout, but since the tenkeyless are the only ones at sale now, I won't be getting a FILCO.
My initials thoughts were going for a
DAS Keyboard Model S Ultimate Silent 135$, since having blank keys would look better than having the wrong layout on the keyprints, and cause I read its a good keyboard brand. The cons on it are that the shinny material of it. I'm not scared about having a lot of fingerprints on it, or the dust that it might attract but if its easy or not to get scratched. Since you can always clean the keyboard when you want it.
Also, I was having on consideration the XArmor with brown switches, and I found like 3 different versions of it at sale right now:
The U9 at 64$The U9W at 80$and
The U9BL-S at 108$They all are cheaper and if both were to be the quality build and such, I would go for a XArmor, but if the Das is way better in this, I would not have a problem on paying that extra for it.
I like the backlight on the XArmor, although it's not a must, also that it has 2 usb ports and jacks for the headset I can make use of them. What really makes me think not to pick them, is that it seems like this got renamed a lot and sold by different brands, on different places, some people reported problems on previous models and that does not provide me any confidence on the durability on those. Also, the con on the keyprints is that I don't like how they moved all the signs up for better lighting, good for the lighting but looks awkward.
So please guys, I want your personal advices on this, which one should I go for, the Das, the XArmor or which one else? I would love to know if you have one or both of them, which one you like better?
I will really really appreciate all the feedback and advices I get on this!
Kind regards, from all the way down to Bolivia,
Esteban / Steve
PS: PS:also posted this on OCN to get as much advices/feedback as possible, I read both forums! >_<
