All prices DO NOT include shipping or PP fees. Please contact me and I will quote you the total price. If you feel my pricing is too high, I will consider all reasonable offers. Lowballers will just be ignored now due to prior experience. Preference given to CONUS buyers, please contact me if international. Unless otherwise specified capsets on most boards are for display only and are not included.
Built with 67g MX Greens, tactile MX Gray on the spacebar. Sandwich style case using ps2avr PCB. Custom USB to PS/2 cable included.
Pretty beat up. Missing some stabs, rust on plate, but the switch is quite unique. I've already cleaned it a fair amount, but it's not the prettiest board regardless. Clicky NEC blue ovals, one with broken stem (see pictures). Tested working using a soarers. Best used as a part donor.
Simplified clicky white alps. If you really want a serial/fcc number I'll tear it down, but its pretty standard as far as these kinds of boards go. Switch feel is ok but the build quality is questionable at best. Good as a parts donor. AT Plug, tested working using a soarer's.
Spring over membrane. Fairly clicky regardless. Case is fairly high quality (better than my Model M, I'd say).
Includes original box, inserts, and plastic cover. AT/XT switchable and tested working via Soarer.
Bought off of EVGA's B-stock site. Used lightly for about a year. Never overclocked, very good condition.
Don't even know how many are in here, but probably 80 work. Mix of new/desoldered alps from my various projects that I've long abandoned.
Depth Black CC - $275
P1 Purple CC - $225
Self explanatory.
Leading Edge DC-2014 - $130
Blue Alps, clicky. You probably know what this is if you're considering it. Very good condition, full texture on all the caps, clean plate. This is untested but I have no reason to believe it doesn't work.
BSP 102 Thick PBT Keyset - $130
Includes PBT spacebar. Lightly used with no visible shine with exception of spacebar, which I would conservatively rate as 8/10 (light scuff marks).
Note: This is for Winkeyless boards only, with 1.5x modifiers and a 7x spacebar. If you have questions about whether or not this will work with your board feel free to PM.
B/R/B Cheat - $425 SOLD
60g lubed reds, stickered, etc. Sleeved USB cable. Small nick in the upper right hand corner, but very good cosmetic condition otherwise.
Caps not included.
DSA Dolch - $90 $80 SOLD
Got this from SP a while back after getting burned in the original LZ buy. I think I have the base 87, tsangan, and 16x windowed caps, but check the pictures for what's there. Box not included. Pretty much brand new, used once and put back in box.
PBT DSA Blanks -$30 PENDING SOLD
I have no idea where I got these. I'm pretty sure they're PBT because the upper left magenta caps are dyed, probably with Rit.
There are 42 1x caps in the upper left hand pile; for the rest, what you see is what you get.
Spacebar is 6.25x
Siig Suntouch Jr with Box - $50
Box has water damage, but the keyboard looks and feels brand new. Funky layout, doubleshot keys. Complicated white alps.
PULSE SA - $100
SP SA profile - again, what you see is what you get. Used for about a month, then put the board back into storage, so it's in pretty good condition.
Board not included.
ANSI Blue Realforce Set - $110
Self-explanatory. Pretty much unused, was put on a HHKB for a week and then thrown back in a box. Display case not included, don't have the original box since it was proxied for me by a friend.
Alps Infinity -
$140 $130
Long story short, this board has caused me more trouble than it's worth and I really hate looking at it. It actually functions and feels pretty good. You can probably guess what the story is based on some of the other stuff I'm selling.
Uses Matias quiet click switches, pbt DSA caps.
Missing one cap cause Massdrop swapped one of the DSA caps for a MX one for who knows why. Didn't completely finish this build till about a week ago so I doubt I can get any sort of coverage for it.
Package includes: Assembled board, caps, 2nd broken PCB (usb port not soldered down correctly, you might be able to fix it if you're good at smd soldering).
Hyperfuse DCS -
$165 $155
SP DCS profile - what you see is what you get. Mint condition, I'm the second owner iirc but haven't really used it since I got it. Has full texture and so on.
Board not included.
Duck Eagle -
$390 $365
65g springs, mx clears, red switch stickers. Mx gray on the spacebar. Krytox GPL 103/205 mix on the sliders/stabs. Stabs are also clipped. No leds except for the side ones, which are red.
Bottom row is 1.5 1x 1.5x 7x 1.5x 1x 1.5x, with short right shift (1.75x - 1x).
Only board is included, no caps, cables, etc.
Desko Keyboard + PCB Combo -
$50$45 $40 $35
MX Blacks all around. Doesn't feel too used but was pretty grungy when I got it. There was some discussion of this PCB from Ivan's GMK buy being pin compatible with this model of Desko board but I never got around to swapping them. PCB has no controller, just header pins. Connector is PS/2
~100 Gateron Blacks - $18
Self explanatory. From original Shadovved GB. 1 pack sold, one left.
Red Scarf 84 - $190
Purchased from the original Ivan GB. Built with Gateron Whites. Short bezel version. Feet came with screws that didn't fit the holes in the bottom of the casing so I have the feet stuck on with double sided tape. It's stuck on pretty well so it should be fine unless you're planning to use this as a travel board.
See this thread for more details
https://geekhack.org/index.php?topic=69064.0More
LZ-FE - $750
Built with 65g MX Clears lubed with 103/205 Krytox mix. Switch feel is very slightly stiffer than ergo clears. Tactile MX Gray on the spacebar. Clipped stabs, yellow switch stickers. Immaculate condition, no scratches, dings, etc.
NCR Cherry G80-0427 - $45
Fun board, only for collectors probably - layout is just impractical for everyday use. XT connector and tested working over a Soarer. All LEDs work and the switches feel great. Vintage MX Blacks. Overall good condition, with some shine on the alphas.
