Author Topic: How to choose material or color for saving cost on case custom  (Read 657 times)
Offline Gaojie Zamol
  • CNC keyboard manufacturer -help you with GB
Welcome to ask us for quote ,we are regular factory can provide you many surface treatment like :Anodize,PVD,E-coating,Sandblasting ,Brushed, high polish,mirror effect,etc. ;)
Mainly do CNC machining keyboard custom works
Welcome to ask me for quote :p
Located in China,MOQ 1 .
Anodize color, please ask me when you are ready to order.
Material we usually do for keyboard is Aluminum,Brass ,SS,PC,POM ,PMMA etc.
Anodize cost :
If you choose one for each color ,that will cost $15 extra/set
If you have 10-20 sets one color ,that will be the same cost,without premium.(Depends on quantity)
Material cost :
The kb case cost depends on the size .As for material :Aluminum=PC<POM <Brass=SS
Surface cost :
As for surface: Anodize <PVD=E-coating , normally the E-coting and PVD are higher $15 than Anodize when you have GB quantity like more than 20 sets.
My email:zamol3dprinting@gj-prototype.com
Discord:Zamol-Keyboard custom#6647
I will be online on Chinese time :9:00 AM~18:00 PM there .
Geekhack will be less to logined in
Cheers
Zamol
Guangzhou Gaojie Model Design And Manufacturing Co., Ltd.
