Author Topic: business cards  (Read 154534 times)
Offline domoaligato
Re: business cards
« Reply #100 on: Tue, 07 January 2014, 12:44:29 »
that is exactly what I was thinking of doing. there is already code for some hacker tools that this business card may be useful running :D
Offline domoaligato
Re: business cards
« Reply #101 on: Tue, 07 January 2014, 16:12:51 »
has it been stated what chipset is in these?
Re: business cards
« Reply #102 on: Tue, 07 January 2014, 16:16:11 »
atmega16u2
Offline Grendel
Re: business cards
« Reply #103 on: Thu, 09 January 2014, 22:32:40 »
Ordered. Assuming it uses the default Atmel DFU bootloader, I should have my CM Storm Demo firmware ported w/in a day of the card arriving :)
- I'm game !
Offline Grendel
Re: business cards
« Reply #104 on: Fri, 10 January 2014, 02:21:49 »
Wow, that was quick -- while I was porting over the firmware I received a tracking number. Just two hours after ordering ! :) I'm impressed. Port is done as far as it goes w/o the physical hardware, let the waiting for the package begin...
- I'm game !
Re: business cards
« Reply #105 on: Fri, 10 January 2014, 11:48:11 »
^ Let me know how it goes ^_^
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
Re: business cards
« Reply #106 on: Fri, 10 January 2014, 11:53:56 »
Yeah, if anyone knows how to reprogram with guided pics or something would be great :D
Offline heedpantsnow
  • Old enough to know better
Re: business cards
« Reply #107 on: Fri, 10 January 2014, 15:46:05 »
Ordered 4!  Would love some guidance on where I can find reprogramming tools.
I'm back.
Offline i3oilermaker
  • * Moderator
  • techkeys.us
    • TechKeys
Re: business cards
« Reply #108 on: Fri, 10 January 2014, 15:48:23 »
Re: business cards
« Reply #109 on: Mon, 13 January 2014, 08:30:01 »
ukbdc seems unnecessarily complex for this board, don't you think?  Couldn't you just tell us what you used to program them and let us see your code??
I'm back.
Re: business cards
« Reply #110 on: Mon, 13 January 2014, 08:32:57 »
well maybe he can get together with someone and they can make a programmer with a GUI and he could charge a few dollars for it
Re: business cards
« Reply #111 on: Mon, 13 January 2014, 08:48:17 »
This is a programmable keyboard controller, and you can make it the controller for a keyboard (ex. IBM Model M).  Why would you want a firmware lacking in capability?  Just curious
Offline komar007
    • komar's blog
Re: business cards
« Reply #112 on: Mon, 13 January 2014, 11:16:31 »
Yes, it is. But it should be simple to use once it's finished. If Brad wants to release the source for what's on the board originally, he will, parts of it are based on ukbdc anyway, which I don't mind. But I won't release it since I wrote in on commission.
  • * Moderator
  • techkeys.us
    • TechKeys
Re: business cards
« Reply #113 on: Mon, 13 January 2014, 11:20:26 »
Komar - I'm ok with you opening up the source if you want to put together a quick how-to on compiling and deploying the code.
Feel free to create a new thread in the TechKeys Vendor forum.
Offline komar007
    • komar's blog
Re: business cards
« Reply #114 on: Mon, 13 January 2014, 11:28:16 »
Okay, no problem. The thing is, the current code is totally based on ukbdc and it won't help very much, because of being rather messy. It wasn't designed to be changed, if you know what I mean:D
ukbdc is slowly getting easier to use and more modular, but also larger, so I thought I'd write new support for the card using it. But in this case, maybe I'll just provide the working code for techkeys as it is, and finish ukbdc support later.
EDIT: done - http://geekhack.org/index.php?topic=53378
« Last Edit: Mon, 13 January 2014, 11:54:04 by komar007 »
Re: business cards
« Reply #115 on: Mon, 13 January 2014, 13:09:43 »
Thanks so much!
I'm back.
Offline Grendel
Re: business cards
« Reply #116 on: Fri, 17 January 2014, 12:40:25 »
Got mine in the mail yesterday, loaded switches & LED's, and hacked it -- trinket w/ the most utile ever ! ;D
I do have one remark tho -- if there ever will be another batch made, I would strongly suggest to change the LED resistors to 1 kOhm (102). Right now they are 100 Ohm (101), driving most LED's betw. 14mA (3.6V LED) and 31mA (1.9V LED). I got a bunch of different LED's from maxkeyboard and digikey and all are fine w/ currents 1-5mA. The lowest resistor I'm using w/ those is 1k (blue, orange), the highest 3.8k (white, pink, green). I replaced the 101 resistors w/ 102 on my two cards, works well.
BTW, if someone is looking for bright LED's -- try this green one if you dare. Do not look directly into them while on ! I am serious. Nasty little buggers.
- I'm game !
  • * Moderator
  • techkeys.us
    • TechKeys
Re: business cards
« Reply #117 on: Fri, 17 January 2014, 13:13:04 »
Well done Grendel - do appreciate your input and hope to make a run 2 at some point.
Offline reziak
  • Topre/60% Enthusiast
Re: business cards
« Reply #118 on: Wed, 22 January 2014, 02:50:28 »
I'd love to make a volume controller out of this for my PC. Volume up, down, and mute. Would that be easy to do? I'm a total newb when it comes to programming....
HHKB Pro 2 | FC660C | HHKB Pro 2 Type-S
Re: business cards
« Reply #119 on: Wed, 22 January 2014, 03:19:07 »
That's a good idea!
Or ... prev track, next track and play/pause!
Re: business cards
« Reply #120 on: Wed, 22 January 2014, 08:53:49 »
I like that idea! My original idea was that I was going to do Geekhack Spy, Page Up, and Page Down. But that volume control is cool.
Offline snoopy
  • The Flying Ace
  • Gone with the Wind
Re: business cards
« Reply #121 on: Wed, 22 January 2014, 08:54:52 »
Mine arrived today :)
Offline reziak
Re: business cards
« Reply #122 on: Wed, 22 January 2014, 18:25:51 »
Yeah! I have access to a laser cutter for acrylic work -- could maybe even make a case for it. Clear acrylic so you can still see the techkeys logo, of course  :thumb:
Re: business cards
« Reply #123 on: Wed, 22 January 2014, 19:03:29 »
That would be cool!
Re: business cards
« Reply #124 on: Wed, 22 January 2014, 19:37:27 »
Group buy?
Offline snoopy
  • The Flying Ace
Re: business cards
« Reply #125 on: Thu, 23 January 2014, 04:46:59 »
Group buy?
I would buy one...
  • * Moderator
  • techkeys.us
    • TechKeys
Re: business cards
« Reply #126 on: Thu, 23 January 2014, 09:04:27 »
I would buy one :)
Re: business cards
« Reply #127 on: Thu, 23 January 2014, 09:20:46 »
I'd buy one or two :D
Offline Wildcard
  • When caffeine isn't enough
Re: business cards
« Reply #128 on: Thu, 23 January 2014, 09:22:36 »
Offline HPE1000
  • Keycap Paparazzo
Re: business cards
« Reply #129 on: Thu, 23 January 2014, 11:00:50 »
I would get one as long as it didn't cost $20 lol
Offline domoaligato
Re: business cards
« Reply #130 on: Thu, 23 January 2014, 12:36:13 »
Think of it as a development board. 20.00 is a good pri e for what you get.
Offline HPE1000
  • Keycap Paparazzo
Re: business cards
« Reply #131 on: Thu, 23 January 2014, 12:46:51 »
I mean the acrylic case, I have the business card in the mail  :thumb:
Offline Laser
Re: business cards
« Reply #132 on: Fri, 24 January 2014, 13:00:02 »
Couple of questions:
1. Are LEDs mandatory? If not, will it work by simply soldering the switches, or do i need to do anything else (on the board, in the source code)
2. What kind of LEDs was the board designed for?
Thanks
Offline reziak
Re: business cards
« Reply #133 on: Fri, 24 January 2014, 13:02:36 »
Group buy?
Oh man, I don't think I have the time for something like that, unfortunately....if I get around to making it and it turns out nice I'd be happy to share the files so that others can make it too.  :)
  • * Moderator
  • techkeys.us
    • TechKeys
Re: business cards
« Reply #134 on: Fri, 24 January 2014, 14:36:11 »
Thanks
LEDs are not mandatory, but will work if installed.  Any standard LED (2v i think) should work, but be sure to get the smaller ones or they wont fit under the keycap.
Re: business cards
« Reply #135 on: Fri, 24 January 2014, 14:38:08 »
Thanks
I put 2x3x4mm LEDs into mine and they fit and worked fine.
Offline Laser
Re: business cards
« Reply #136 on: Fri, 24 January 2014, 16:54:23 »
Thanks for the answers! :)
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
Re: business cards
« Reply #137 on: Sat, 25 January 2014, 12:03:15 »
Thanks
3MM Round headed ones are fine too. :D
Although I have not soldered them in, it looks alright :)
    • Gray Designs
Re: business cards
« Reply #138 on: Sat, 25 January 2014, 12:20:11 »
Those cards sure are amazing.. What talent you have :)
Offline Laser
Re: business cards
« Reply #139 on: Sat, 25 January 2014, 13:49:35 »
Couple of (bad) pics, works a charm :)
52283-0
52285-1
52287-2
Next, reprogramming :D
(starting a gVim session comes to mind)
Re: business cards
« Reply #140 on: Fri, 21 February 2014, 06:58:13 »
55074-0
  • * Moderator
  • techkeys.us
    • TechKeys
Re: business cards
« Reply #141 on: Fri, 21 February 2014, 09:20:42 »
How did you manage to fit 1,000 suns under that Esc key?
Re: business cards
« Reply #142 on: Fri, 21 February 2014, 10:46:32 »
55084-1
here's white although it looks blue  ???
« Last Edit: Fri, 21 February 2014, 11:05:24 by SpAmRaY »
Re: business cards
« Reply #143 on: Thu, 20 March 2014, 22:25:51 »
My newest card, thanks to that recent coupon spur of the moment and a few fellow geekhackers being bros and hoes....err that doesnt' sound right at all......what do we call girl geekhackers?
Anyway I digress....
58153-0
58155-1
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
Re: business cards
« Reply #144 on: Fri, 21 March 2014, 04:55:24 »
Oh dayum. Grey's with clear top  :-X
Offline JayKthnx
Re: business cards
« Reply #145 on: Fri, 21 March 2014, 10:57:07 »
anomalies.
rare.
fairy tales.
etc.
Re: business cards
« Reply #146 on: Fri, 21 March 2014, 11:01:43 »
anomalies.
rare.
fairy tales.
etc.
There are no girls on the internet. I thought you knew.
Re: business cards
« Reply #147 on: Fri, 21 March 2014, 12:56:53 »
what do we call girl bros?
Sis
As in: SUP SIS? I LIKE THAT GMK SET YOU'RE ROCKIN'.
I believe they'd like to be called Geekhackers as well.
  • * Moderator
  • techkeys.us
    • TechKeys
Re: business cards
« Reply #148 on: Wed, 01 October 2014, 23:02:49 »
Some of you who have placed recent orders have seen some of the new ones!
78577-0
Re: business cards
« Reply #149 on: Thu, 02 October 2014, 05:09:23 »
Very nice, sir :)
Something else to collect though!
