NEW USERS, READ THIS!
Nice!!!!Any chance of getting just the PCB?
Which type of poker 2 is it? The ones with PBT caps / no LEDs?
Will there be any support/warranty offered on these?
Quote from: Permeability on Mon, 06 May 2013, 10:39:17Which type of poker 2 is it? The ones with PBT caps / no LEDs?It is the no LED version, but it does have LEDs for Space Bar and CapsLockQuote from: ray4jc on Mon, 06 May 2013, 10:40:50Will there be any support/warranty offered on these?If units are DOA they will be replaced if the hardware is faulty. If the firmware is the issue, it can be fixed.
Y U NO BLACKS?
YesProgramming UsagePress PN + Programmed key, ORPress Toggle(FN+Right SHIFT) to light up the spacebar left LED first. Then press the programmed key directly. Ifyou press PN + Programmed key at this moment, it will output the original key code.
Quote from: i3oilermaker on Mon, 06 May 2013, 21:50:13YesProgramming UsagePress PN + Programmed key, ORPress Toggle(FN+Right SHIFT) to light up the spacebar left LED first. Then press the programmed key directly. Ifyou press PN + Programmed key at this moment, it will output the original key code.Do you know if it will be possible to re-assign the Fn and/or Pn keys elsewhere? Specifically I would like to use the bottom right mods as arrow keys, and cannot do that to the Poker because the Fn key cannot even be seen by AutoHotKey or xkeymap.Thanks! - Ron | samwisekoiShow Image
Slightly off topic, but how difficult is it to swap out springs on a poker?Not sure if Reds would be a good choice... but if I can swap in 55g springs fairly easily its a different situation
I really hope so - communication with vortex has been difficult.
Quote from: i3oilermaker on Thu, 06 June 2013, 07:57:45I really hope so - communication with vortex has been difficult.in the mean time i demand new keys to be made available at techkeys
Quote from: BunnyLake on Thu, 06 June 2013, 07:59:28Quote from: i3oilermaker on Thu, 06 June 2013, 07:57:45I really hope so - communication with vortex has been difficult.in the mean time i demand new keys to be made available at techkeysOk
They will have both spacebars
There is one promo left - the next Poker to be purchased ships with a Hapster and Metallic Poker Set
Quote from: i3oilermaker on Thu, 04 July 2013, 16:30:02There is one promo left - the next Poker to be purchased ships with a Hapster and Metallic Poker Set Gah, just bought my Poker 2 from techkeys like two days ago
Quote from: Jason1313 on Thu, 04 July 2013, 18:15:02Quote from: i3oilermaker on Thu, 04 July 2013, 16:30:02There is one promo left - the next Poker to be purchased ships with a Hapster and Metallic Poker Set Gah, just bought my Poker 2 from techkeys like two days ago If you are Jason P then you got one of those slots
Welcome to Geekhack, Jason1313!Nice achievement get with your first post
Quote from: i3oilermaker on Fri, 05 July 2013, 00:24:40Quote from: Jason1313 on Thu, 04 July 2013, 18:15:02Quote from: i3oilermaker on Thu, 04 July 2013, 16:30:02There is one promo left - the next Poker to be purchased ships with a Hapster and Metallic Poker Set Gah, just bought my Poker 2 from techkeys like two days ago If you are Jason P then you got one of those slots Jason W but I hope I still won!Quote from: rowdy on Fri, 05 July 2013, 00:32:47Welcome to Geekhack, Jason1313!Nice achievement get with your first post Yeah, I signed up for the DS $8/$9 groupbuy, but this is pretty sweet too!
