Author Topic: [SPRiT] PCB +Case +Parts (NEW Full Alu Case Buy)  (Read 210912 times)
Offline beltet
Re: <SPRiT Edition> 60% PCB + Polycarb Plates + Parts (50 sets - Ordering)
« Reply #400 on: Mon, 18 May 2015, 17:48:20 »
Is other PCB's on the wasy aswell? Thinking of 75%..
Offline flabbergast
« Reply #401 on: Mon, 18 May 2015, 17:54:25 »
Can I still join? I would like to get a PCB + stabs only (ie no plate, no extras). It's a bit confusing on the order form (required fields). Thanks.
Offline cwils0n
  • twiggletwaggle
« Reply #402 on: Tue, 19 May 2015, 08:45:05 »
Just put in an order for 1 PCB, some LEDs, and a set of PCB stabs.  Hopefully we can hit that MOQ.
Offline DanielT
« Reply #403 on: Tue, 19 May 2015, 08:48:42 »
Only 9 more are needed and if you look at SPRiT's last post he said he might cover the last PCB's to reach MOQ  :thumb:
Offline pokkuhlag
« Reply #404 on: Tue, 19 May 2015, 09:54:39 »
I actually had the same dillemma yesterday, but decided to put the order anyway for pcb + stabs + switches.
It is better to order and get cancelled then to miss the gb  ;).
Offline flabbergast
« Reply #405 on: Tue, 19 May 2015, 11:53:35 »
Finally I put in the order. I hope it will work out!
Offline sprit
  •  Post Editing Timeout
  • Location: The Geek Symphosion :::::: Mechanical Engineering ::: Alta Magna Uniforma :::::: 哀吾生之須臾羨長江之無窮 ::
« Reply #406 on: Wed, 20 May 2015, 06:51:48 »
60% PCB + Plate + Parts   :  50 sets  (Production & 2nd Ordering)
-  60% PCB + Polycarbonate / Acrylic Plate   :  each 50 sets.   1st batch Reached the MOQ!    (Under production from 18th May~)
-  All the PCBs are 100% Factory pre-soldered & Tested.    60% PCB = $50    ::)
-  1st  Batch   :  Order 3 weeks (21 April - 17 May),  Invoicing 1 day,  Production 3 weeks (18 May - 5 June),  Ship 2 weeks (June 6 - 21)
-  2nd  Batch  :  Order 2 weeks (May 20-31),  Invoicing 1 day,  Production 3 weeks (June 1-21),  Ship 3 weeks (June 22 - July 13)
-  If there is a serious delay more than 2 weeks, Your payments will be full refunded.   :thumb:
-  Order Form  Mod Note: removed    Thanks!  ;)
Pics :  SPRiT,  rpeterclark,  Defect,  Photoelectic   Thanks!
101230-0  101224-1  101226-2  101228-3
« Last Edit: Tue, 24 January 2017, 17:24:06 by Moderation Team »
Offline DanielT
« Reply #407 on: Wed, 20 May 2015, 08:45:10 »
Invoice received and paid  :thumb:
Offline flabbergast
« Reply #408 on: Wed, 20 May 2015, 08:52:46 »
Me too - so I did squeeze into the first round. Thanks SPRiT!
Offline cwils0n
  • twiggletwaggle
« Reply #409 on: Wed, 20 May 2015, 09:38:19 »
Received and paid invoice as well.
Offline micr0n
« Reply #410 on: Wed, 20 May 2015, 11:57:19 »
Sweet!  Looks like we made MOQ for most of the items except for the switches  :-[  Guess I'll have to source my switches from some where.
Offline Tofubeats
« Reply #411 on: Wed, 20 May 2015, 20:38:49 »
Looks like I barely missed this one :(
Edit: Nvm Sprit is awesome.
« Last Edit: Thu, 21 May 2015, 02:42:01 by Tofubeats »
Offline flabbergast
« Reply #412 on: Fri, 22 May 2015, 04:37:47 »
Question about the plates offered in this group buy: Are the switches and everything PCB mounted, and does the plate just slide on top, or does it work like steel/alu plates, i.e. the switches are firmly placed (effectively mounted) on the plate?
Offline DanielT
« Reply #413 on: Fri, 22 May 2015, 04:58:45 »
It's like a classic plate, only this thicker (5mm) , it allows switch top removal but you can not slide the plate up. You get a firm fix ;)
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #414 on: Fri, 22 May 2015, 04:59:56 »
If you're using the acrylic plate in this GB, you can choose either plate or pcb mounted switches.
The plate goes on top of the pcb, the acrylic plate however has notches for switch top removal if that's what you're wondering.  :)
Offline flabbergast
« Reply #415 on: Fri, 22 May 2015, 05:18:48 »
Thanks for the info about the plates: that's what I thought originally, but then I saw [this](http://imgur.com/a/9tzsv) build on reddit and it seemed to me that he might have been first soldering the switches to the PCB and only then putting in the plate, which didn't make a lot of sense to me. So I asked ;)
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #416 on: Fri, 22 May 2015, 05:21:54 »
No worries. I'm guessing s/he was just mounting the stabs on the pcb before putting the plate on top.  :)
Offline micr0n
« Reply #417 on: Fri, 22 May 2015, 10:21:34 »
This is good information to know since this will be my first build as well.   :thumb:
Offline sprit
« Reply #418 on: Sun, 24 May 2015, 07:39:27 »
Thanks Guys for the kind answers!  :thumb:
I had lots of vitamins and quite rests, feel much better  :-*
Offline sprit
« Reply #419 on: Sun, 24 May 2015, 08:23:42 »
-  60% PCB + Polycarbonate / Acrylic Plate   :  each 50 sets.    1st batch Reached the MOQ!    2nd  Batch Ordering.
-  1st  Batch   :  Order 3 weeks (21 April - 17 May),  Invoicing 1 day,  Under Production Now  (18 May - 5 June),  Ship 2 weeks (June 6 - 21)
-  Order Form  Mod Note: Removed due to Sprit being MIA.  Order from him at your own risk!   Thanks!  ;)
101591-0  101593-1  101595-2  101597-3
« Last Edit: Tue, 24 January 2017, 17:24:53 by Moderation Team »
Offline DanielT
« Reply #420 on: Sun, 24 May 2015, 09:12:37 »
Glad to hear you are feeling better ;)
Offline sprit
« Reply #421 on: Sun, 24 May 2015, 09:24:28 »
My PCBs  &  3-5mm  Plates are   :
-  OK for both Plate- or PCB-mount Switches     ;)
-  for PCB mount stabs Only (Due to thickness)
-  OK to install the Stabs Before or After the plate assembled
-  So, No Worries for the Stab wire hang-off  (An Improvement)
-  My Plates are 'Stab wire hang-off Protection Designed' (The first, as far as I know)   The Users will answer this.   ;)
« Last Edit: Sun, 24 May 2015, 09:30:40 by sprit »
Offline DanielT
« Reply #422 on: Sun, 24 May 2015, 11:01:38 »
This is very interesting, one thing I hated about plates was that you didn't had access to the stabs, this so cool to be able to mount the stabs any time you want.
Offline sprit
« Reply #423 on: Tue, 26 May 2015, 04:47:14 »
60% PCB + Plate + Parts   :  50 sets  (2nd Ordering)
-  PCBs are 100% Factory pre-soldered & Tested.     60% PCB = GB price  $50  (White, Blue, Black color)
-  1st  Batch   :  Order 3 weeks (21 April - 17 May),  Invoicing 1 day,  Under Production  (18 May - 5 June),  Ship 2 weeks (June 8 - 21)   :   Total  8 weeks
-  2nd  Batch  :  Order 3 weeks (May 31- June 21),  Invoicing 1 day,  Production 2 weeks (June 22-July 12),  Ship 3 weeks (July 13 - July 31)    :   Total  8 weeks
-  Order Form  Mod Note: link removed due to sprit being MIA.  Order from him at your own risk!    Thanks!  ;)
101719-0  101711-1 101713-2  102092-3  102183-4  102086-5
« Last Edit: Tue, 24 January 2017, 17:25:52 by Moderation Team »
Offline sprit
« Reply #424 on: Wed, 27 May 2015, 18:00:41 »
Some Extras from the 1st Batch    ;)
Some Extras due to the Factory MOQs.
Shipping will start from June 8th ~   I got a person to help the shipping.
The Order Form Mod Note: link removed due to sprit being MIA.  Order from him at your own risk!      Thanks!
-  PCB   -  Snow  White   5 pcs
-  PCB   -  Glossy Black   4 pcs
-  PCB   -  Glossy Blue     3 pcs
-  Plate  -  Clear Trasparent  3pcs,   White matte  3pcs,   Turquoise  3pcs,   Lime Green  2pcs
-  Plate  -  Clear Frosted matte  4pcs,   Red  1pcs,   Orange  2pcs,   Pink  2pcs,   Purple  2pcs,   Charcoal  3pcs
« Last Edit: Tue, 24 January 2017, 17:26:13 by Moderation Team »
Offline Jason_IRL
« Reply #425 on: Fri, 29 May 2015, 20:46:53 »
There will be some extra PCBs & Plates from the 1st Batch  ;)
The Order Form is in the OP  :  Mod Note: link removed due to sprit being MIA.  Order from him at your own risk!       Thanks!
with the pcb/plate fit into a poker II case? and If I were to place an order for one of the above listed, it will start shipping on june 8?
« Last Edit: Tue, 24 January 2017, 17:26:23 by Moderation Team »
Offline sprit
« Reply #426 on: Fri, 29 May 2015, 22:26:54 »
-  Sure!  definitely fits into a Poker 2 case  (The PCB is poker compatible, and proven)
-  Yes!   Extras from the 1st Batch, due to the Factory MOQs.  Will shipped out  from June 8th ~
I got a person to help the shipping (It's a PCB and plate, mostly)    ;)
« Last Edit: Sun, 31 May 2015, 08:30:06 by sprit »
Offline Charger
« Reply #427 on: Mon, 01 June 2015, 09:55:00 »
Oh i was meaning to ask do these PCBs have all the diodes and resistors already installed?
if not what resistors are needed?
Offline sprit
« Reply #428 on: Mon, 01 June 2015, 20:27:34 »
60% PCBs are  100% Factory pre-soldered for All the diodes, resistors and everything,  since Round 2  Last year.
You dont need anything  ;)
102378-0
« Last Edit: Mon, 01 June 2015, 20:31:19 by sprit »
Offline Charger
« Reply #429 on: Mon, 01 June 2015, 21:08:44 »
good to hear. Also I saw the post in the thread long before I noticed the pm lol
Offline sprit
« Reply #430 on: Tue, 02 June 2015, 00:21:24 »
The 1st Batch PCBs are at the Auto SMD soldering Factory now, preparing setting for the SMT soldering process.
When I get it,  will ship it out  from June 8th.    It's a PCB and plate, mostly.
I got a dedicated person for this shipping.    ;)
102470-0  102472-1
« Last Edit: Fri, 05 June 2015, 01:12:59 by sprit »
Offline sprit
« Reply #431 on: Fri, 05 June 2015, 01:09:29 »
-   New batch of  55g,  65g,  68g,  85g  v1.2 produced
A bit late (a week) than expected,  due to the busy season at the factories.     Thanks for the People joined and waited for these.
-    LSS Station is taking Orders for the 2nd Batch
https://geekhack.org/index.php?topic=55888.msg1746597#msg1746597      Order   >   Mod Note: link removed due to sprit being MIA.  Order from him at your own risk!       Ship from June 22th ~   (MOQ 20sets)
-   60% PCBs have produced nicely.
102664-0 102668-1 103256-2
« Last Edit: Tue, 24 January 2017, 17:27:07 by Moderation Team »
Offline DanielT
« Reply #432 on: Fri, 05 June 2015, 01:34:25 »
This is the best looking blue PCB I have ever saw  :thumb:
Offline Tofubeats
« Reply #433 on: Sat, 06 June 2015, 14:57:51 »
If there's ever a pink PCB I'd place another order ;)
Offline Prelim
« Reply #434 on: Wed, 10 June 2015, 19:32:25 »
hi SPRiT,
I haven't read all the thread, so sorry if it's being asked again but I want a plate and need to know this:
what's the difference between acrylic and carbonate plates in terms of feel/resistance/etc?
2x GH60 revC - lubed Linjärs 65g / lubed H1s 65g with SPRIT 5mm acrylic plate | Dolch PAC - Cherry housing / Gateron sliders 65g and QMK clips | Raptor K1 G80-1890 stock
Floating on Cherry/GMK caps - White on Black, Classic Beige, Dolch, Olivetti, Alcatel MMK, Hellgrau
Offline sprit
« Reply #435 on: Thu, 11 June 2015, 10:54:06 »
hi SPRiT,
Hello!   Prelim!   ;)
As we feel the Polycarbonate cups, Acrylic panels daily life,
If the both are same thick, Acrylic is a bit softer,  Polycarbonate tends a little bit stiff generally, afaic.
But most of the Acrylic plates introduced are 1.5mm thick -  It's too Fragile,  I don't like them, I'd prefer the 5mm thick Acrylic Plate for it is strong, soft and quiet enough.
The most of the Korean Polycarb plates introduced are 1.5mm thick  -  It's flexible and strong, but usually the designs are focused on the soft feels side, for the 50g - 62g light pressure lovers in Korea.  Personally I prefer 3mm-5mm thick Polycarb plates.
« Last Edit: Thu, 11 June 2015, 12:03:41 by sprit »
Offline Prelim
« Reply #436 on: Thu, 11 June 2015, 11:21:13 »
thanks,
so would you say acrylic is more quieter and soft than polycarbonate?
Offline sprit
« Reply #437 on: Thu, 11 June 2015, 11:36:27 »
thanks,
I'd say the Acrylic is a little bit softer and quieter than Polycarbonate in general.
But the Polycarbonate plate needs CNC machining, so the cost is 2-3 times higher than the Laser cut Acrylic, and more cutting error wastes.
If You cut the Acrylic by CNC machining, the cost will be almost same.  The raw material prices differ less than 30%.
103727-0 103731-1 103733-2 103737-3  pics :  rpeterclark    https://geekhack.org/index.php?topic=53618.msg1771544#msg1771544
« Last Edit: Thu, 18 June 2015, 10:58:36 by sprit »
Offline flabbergast
« Reply #438 on: Thu, 11 June 2015, 13:59:10 »
Hi SPRiT,
I hope you're feeling better, please don't work so hard!
Question: do you still have/offer the HHKB-style plates and/or cases - I mean the ones that have bottom row 1-1.5-7-1.5-1 with 1.5 space on both sides - like seen on some of the photos?
Offline pepsi
« Reply #439 on: Sat, 13 June 2015, 07:26:47 »
Is there any left of these extra PCBs?
« Last Edit: Tue, 24 January 2017, 17:27:29 by Moderation Team »
Offline Tofubeats
« Reply #440 on: Mon, 15 June 2015, 13:59:14 »
I know you've been sick and all, but I'm just curious on the status of the shipment of Group 1 orders. Mostly because I need mine relatively soon.
Offline Mr.P.Kay
« Reply #441 on: Sat, 20 June 2015, 16:18:49 »
Hey SPRiT, I currently have a V60 KB Paradise with an acrylic case of yours, but it doesn't sit flush, I was wondering if you had a top piece that I could get to make it sit flush with the plate.
I have pictures of what it looks like atm.
http://imgur.com/a/bz3gV
Offline sprit
« Reply #442 on: Sat, 20 June 2015, 19:15:19 »
Hello!   :)
Yes!  It's $15  since September Last year.  But Some has Not ordered the Extra Top to flush.
Please send me Your Info.    >  Mod Note: link removed due to sprit being MIA.  Order from him at your own risk!
« Last Edit: Tue, 24 January 2017, 17:28:07 by Moderation Team »
Offline sprit
« Reply #443 on: Sat, 20 June 2015, 19:19:33 »
60% PCB + Plate  -  1st Batch
The Orders for a PCB and Plate are under packing and shipping.
Thanks For Your wait !   ;)
Offline Mr.P.Kay
« Reply #444 on: Sat, 20 June 2015, 21:12:36 »
Alrighty, sent you the info of what I need.
Thanks Sprit.
Offline micr0n
Awesome!  Kind of excited.
Offline Tofubeats
« Reply #446 on: Mon, 22 June 2015, 00:25:09 »
Super excited to get mine in :)
Offline Jason_IRL
« Reply #447 on: Thu, 25 June 2015, 08:14:15 »
Hope you're feeling better sprit!
Offline Jason_IRL
« Reply #448 on: Thu, 02 July 2015, 13:49:18 »
any news on shipping?
Offline Tofubeats
« Reply #449 on: Thu, 09 July 2015, 10:11:42 »
