Author Topic: [GB] GMK Triumph Adler. Pics posted...  (Read 360595 times)
Offline strict
  • TKL Zealot
Re: [GB] GMK Triumph Adler
« Reply #50 on: Tue, 24 March 2015, 17:38:05 »
Order submitted (#75)  :)
My wallet is taking a beating today, so far I've bought and installed stainless brake hoses for my car, picked up another Realforce, and now another GMK key set  :O
Offline Fnzzy
« Reply #51 on: Tue, 24 March 2015, 17:42:13 »
Yes! I'm in! Can't wait to compare the alphas to my TA dyesubs, mix and match and... ooh this gonna be good!
I should maybe buy a keyboard for this set so I can actually use it...
Offline njbair
    • nickbair.net
« Reply #52 on: Tue, 24 March 2015, 17:44:40 »
We are all ridiculous. I mean, really.
But at least we're self-aware.
My boards:
Offline Fnzzy
« Reply #53 on: Tue, 24 March 2015, 17:49:47 »
Well I have keyboards that I can use it with, the thing is that I feel like this set should be used by a TKL board or larger to really pop. I also feel like it looks best on beige/silver keyboards.
Now the problem is that I have 2 silver 60% boards and I don't really want to buy another silver keyboard since I want variety.
Not to mention I still have to get a grey/black keyboard to match my GMK Dolch :-X
someone help me
Offline njbair
    • nickbair.net
« Reply #54 on: Tue, 24 March 2015, 17:56:30 »
someone help me
I'm thinking about putting these on a board finished with a hydro-dipped wood grain pattern.
My boards:
« Reply #55 on: Tue, 24 March 2015, 18:19:17 »
I'm just not sure what is the point of fostering negativity at this point. Did my best to make this a flexible set while not letting it get bloated - the #1 killer of s GBs, and my best is all I can do.
I know you did, and really, I'm not trying to foster negativity. I agree that this is not the point to discuss things like profiles. But I never knew about it before today, or I would have brought it up in the interest check.
Offline Prankk
« Reply #56 on: Tue, 24 March 2015, 18:22:03 »
Joined. My wallet is in so much pain. No end in sight. I ain't even mad.
Offline MythicalWagyu
  • Poor Impulse Control
« Reply #57 on: Tue, 24 March 2015, 18:22:25 »
Joined as soon as I saw the email from MD, 58th participant! I have far too many wonderful keysets coming my way in the next 3-4 months and not enough keyboards  :eek:
KEYBOARDS >>
MICE >>
COMPUTER >>
Offline jonathanyu
« Reply #58 on: Tue, 24 March 2015, 18:23:00 »
Will the deadline be extended if it doesn't reach 500 in 11 days?
A little bit off topic, why the led panel on the example board is grey and beige instead of blue and beige?
Committed two btw :thumb:
« Reply #59 on: Tue, 24 March 2015, 18:27:58 »
Gonna skip this one.  GMK is great... but Massdrop... :(
Offline intelli78
« Reply #60 on: Tue, 24 March 2015, 18:28:48 »
Alright man, fair enough though it was in render and I believe also a bullet point in IC. I know it's easy to miss stuff sometimes though,  will try to make this kind of thing clearer in the future. Hope you are still on board.
Offline Bromono
  • Wanabe Cicerone
  • HHKB > Your Opinion
« Reply #61 on: Tue, 24 March 2015, 18:38:44 »
I wants it :( but it would go on my redscarf and after reading about the profile idk if it would be a good fit on a compressed board like mine
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #62 on: Tue, 24 March 2015, 18:39:58 »
Just ordered 3 complete sets because being a GMK fanboy means you gotta go in hard every time  :thumb: .
Thank you for using Massdrop finally someone who knows that this system has a real chance of getting 500 plus world-wide easily.  Word to the worn out and spent here on this forum, you can NEVER have enough GMK perfection hence buy it all up when it presents itself.
Always go into these Group Buys full bore and take no prisoners, this place isn't for the weak or hesitant.  It's a place for extreme zealots that truly believe in a natural and perfect world covered in GMK key-caps  8) .
Offline njbair
    • nickbair.net
« Reply #63 on: Tue, 24 March 2015, 18:46:11 »
I know some folks have concerns about Massdrop messing up orders and such, but this one is basically being run by intelli78 and just facilitated by Massdrop. Even the keys themselves are coming pre-packed and pre-sorted, so there's really nothing to mess up.
Or is your reservation more ideological/philosophical?
My boards:
Offline morpheus
« Reply #64 on: Tue, 24 March 2015, 18:54:35 »
Ordered!
Offline ATXTider
  • I keep it playa while some choose to play it safe
« Reply #65 on: Tue, 24 March 2015, 19:01:52 »
So with all this bottom row profile talk, what does it mean for those of us who would use this set on a board with winkeys?
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
« Reply #66 on: Tue, 24 March 2015, 19:04:04 »
Depends if you are using a tsangan row or standard row. If you are using a 1.25 bottom row, it will look standard, if you are using winkeyless tsangan, it will look fine, but if you are using winkey tsangan it will look raised
Offline intelli78
« Reply #67 on: Tue, 24 March 2015, 19:11:27 »
Yes, these are all pre-sorted in plastic trays by GMK. Also, just from my personal conversations with Massdrop, I can tell you they are not keen to have any more keycap fulfillment issues.
https://farm3.staticflickr.com/2946/15301853109_1a0cc99c7a_h.jpg
See how the arrows and numpad are a little taller than the Ctrl/Alt keys? That's what this set will look like if you're using winkeys. Winkeyless, it'll all be the taller variant. As Hoff said it could be a little clumsy on a layout like winkey Lightsaver, but for a TKL or full size board it will be virtually unnoticeable.
My man.
Offline Jokrik
« Reply #68 on: Tue, 24 March 2015, 19:12:06 »
Ordered!  I'm in so much love with the color...  But... I don't have any keyboard to put it in...
Any thoughts on what's the best case color to go with it? I know the classic beige color goes well...
Offline tmk1207
  • Yêu Màu Tím
    • Vietnam Mechanical Keyboard Club <3
« Reply #69 on: Tue, 24 March 2015, 19:42:46 »
i love triumph but MD don't shipping to Vietnam. I'm fell very sad
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #70 on: Tue, 24 March 2015, 19:46:51 »
I am sure you could find someone to proxy it to you.
Offline Dee1
« Reply #71 on: Tue, 24 March 2015, 19:52:53 »
I've been waiting for this! :)
« Reply #72 on: Tue, 24 March 2015, 19:54:49 »
Finally placed my order for 3 sets.  To any unfortunate soul coming to this thread months too late, PM me and I may have one available for sale at slight markup (interest rate charge).   :thumb:
Offline intelli78
« Reply #73 on: Tue, 24 March 2015, 19:57:40 »
kapitalist scum
« Reply #74 on: Tue, 24 March 2015, 19:58:38 »
kapitalist scum
:rolleyes:   ya, okie.
:P
Offline intelli78
« Reply #75 on: Tue, 24 March 2015, 19:59:56 »
kapitalist scum
:P
Offline ApocalypseMaow
  • Kitteh Overlord
  • Say WHAAT...
« Reply #76 on: Tue, 24 March 2015, 20:01:07 »
kapitalist scum
Well said!!!  :))
Offline shawn24
« Reply #77 on: Tue, 24 March 2015, 20:07:32 »
thx for all who make it happen:)
« Reply #78 on: Tue, 24 March 2015, 20:07:56 »
kapitalist scum
Well said!!!  :))
:|  rude
Offline luckyryan333
  • #There'sNoToolForTyping
« Reply #79 on: Tue, 24 March 2015, 20:19:03 »
Wow! It's about time to dive into TA ocean. Yeah, I'm ready...
No PaiN, No GaiN
How to order from Taobao from outside of China and WITHOUT an Agent
daily driver: C70 w/ Oblivion
on the way: d65_12/gmkblk_3
Offline shower_king
  • Pain is weakness leaving your body
« Reply #80 on: Tue, 24 March 2015, 20:22:34 »
i have joined in ,thank very much
« Reply #81 on: Tue, 24 March 2015, 20:28:57 »
Well, I've already mentioned it before...
https://geekhack.org/index.php?topic=65724.msg1639353#msg1639353
already understood yours... anyway actually still leaves much to be desired...  :(
no other way but for hoping for the next GB for the missing R4 6 keys in B-profile?
No PaiN, No GaiN
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #82 on: Tue, 24 March 2015, 20:43:27 »
but dat massdrop doe
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #83 on: Tue, 24 March 2015, 20:48:06 »
I have personally never had a negative MD experience, but I always seem to see people complain. Have you had a negative experience with them?
Offline monotagary
  • Keycaps > Rent
« Reply #84 on: Tue, 24 March 2015, 20:52:47 »
They hijacked his Gateron GB.
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #85 on: Tue, 24 March 2015, 20:55:50 »
It's only $15 guys. Don't commit, just buy.
To most people it probably makes more sense to them to commit if the MOQ is 500 anyways.
I don't know why they put the price tiers if it's 500 sets or nothing.
Some of Ye ole  Keyboards -->
OTD Koala:  62g Old MX-Blacks   |   LZ-GH V2:  MX-?62g   |   KMAC2:   62g Tactile MX-Greys   |   LZ CLS s:   62g Vintage MX-Blacks   |   X60:   62g Vintage MX-Blacks   |   GON NerD 60:  62g Old MX-Clears   |   Filco MJ2 (Beige) TKL's:  62g MX-Clears  &   62g Vintage MX-Blacks   |   IBM '91 SSK
WTB/WTS/WTT ---->
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #86 on: Tue, 24 March 2015, 20:56:23 »
Completely forgot about that, which is justifiable
Offline monotagary
  • Keycaps > Rent
« Reply #87 on: Tue, 24 March 2015, 20:58:26 »
MD is just weird like that.
Offline Nai_Calus
  • CLACK
« Reply #88 on: Tue, 24 March 2015, 20:59:34 »
I was asleep when this went live so I was the lame position 103rd to join after a quick check of finances since I just bought a couple of artisans recently and an expensive keyboard, but as soon as I saw I had enough, boom.
I've been eyeing this and passed on the Hyperfuse GMK buy because I knew this was coming.
HYPE. I love blues. Until someone makes a doubleshot sky blue and metallic silver set this will be pretty much the ultimate.
- IBM 4704 Model F 107-key "Bertha"
Other boards: Kinesis Essential, Infinity(G.Clears), Ergodox(MX Blues), Monoprice 9433
Eternally searching for Celestial Blue BS V2 and blue/purple Bros.
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #89 on: Tue, 24 March 2015, 21:01:51 »
You can always sell those artisans :P That what I did to fund my Miami Twice purchase. I only committed right now.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #90 on: Tue, 24 March 2015, 21:08:05 »
I mean, I've also been in two buys where the shipping time was absolutely horrendous, and the savings never seem to balance out the shipping time
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #91 on: Tue, 24 March 2015, 21:11:16 »
Yeah, I could have spent like 50 more cents to get a chiton sleeve in 2 days, rather than waiting 2 weeks. But I have gotten the tex acrylic case and the poker 2 w/; clears from there last november, so I can't really complain, since they were exclusives.
Offline swimmingbird
  • keyset hoarder
« Reply #92 on: Tue, 24 March 2015, 21:23:18 »
I'm a bit disappointed about the extras in this buy compared to hyperfuse - I'd rather pay more and get extra keys but what the hell.
Down for 2 sets.
Offline GSimon
« Reply #93 on: Tue, 24 March 2015, 21:32:21 »
Down for 2 sets.
Well there are 3 custom colors also with this buy, so although the price is about the same as Hyperfuse (at its lowest tier) you're getting added value from that as well.
Offline pr0ximity
« Reply #94 on: Tue, 24 March 2015, 21:38:36 »
I'm surprised that nowhere on the page does it mention we need 500 for the set to be produced.
| Flickr | KMAC 1.2 | Koala | GSKT-00-Z | GSKT-00-AEK | GON NerD60 | Jane V2 CE | Whale | J80S | Ibis | Pro2 | Pro1 | 356mini | 356CL DGE | G80-5000 HAMDE | IBM 1390120 | IBM F AT | IBM F122 | IBM 3101 | Zenith Z-150
« Reply #95 on: Tue, 24 March 2015, 21:40:20 »
This is probably the fastest I've ever spent $120.
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #96 on: Tue, 24 March 2015, 21:41:01 »
Not eating sandwiches?
Offline shawn o
« Reply #97 on: Tue, 24 March 2015, 21:41:56 »
So with this set the bottom row look and feel odd on a modern keyboard such as a Filco?
Offline Touch_It
« Reply #98 on: Tue, 24 March 2015, 21:44:23 »
I may have to buy this set and a keyboard to match :d.  If I can find a way to justify spending the money.
Offline shawn o
« Reply #99 on: Tue, 24 March 2015, 21:44:40 »
Why is the profile different from every other GMK set made so far?
« Last Edit: Tue, 24 March 2015, 21:47:23 by shawn o »
