Author Topic: Discover Joy-New Smile Profile Keycaps!  (Read 1851 times)
Offline KeyTok
« on: Fri, 12 April 2024, 03:34:42 »
Design inspiration: This keycap set draws inspiration from the film cameras of the 1990s, Whose landscape orientation outputs can be best imitated on phones by turning them 90 degrees.
Additionally, the overall color composition mainly uses blocks and straight lines as a tribute to the color composition method of the 1990s, even with some characters rotated exactly 90 degrees.
The Smile profile: It’s the CHERRY profile(so you don’t need to spend any time getting used to it) with some ergonomic adjustments. The lower edges of the keycaps are made more rounded, and the rounded corners are enlarged for smoother contact. Moreover, The curvatures of the top edge and the contact with the pulp are also adjusted to give off a more neutral look and comfortable tapping. Beneath the surface we have optimized the internal chamber accordingly: chamber walls are bent to better concentrate the sound, which leads to less noise and hollow sound, a crisper and firmer bottoming out, and less ‘leaky’ noise. In addition, a new material composition is adopted to improve the friction and grip of the surface.
Material: PBT
Process: Five-sided Dye Sublimation
Full Keycaps: 162
Adaptation: 61 / 67 / 68 / 75 / 84 / 87 / 98 / 108
😄Embrace positivity as your fingers dance across the keys with a smile!
Offline ItIsWritten
Re: Discover Joy-New Smile Profile Keycaps!
« Reply #1 on: Fri, 12 April 2024, 10:03:37 »
Is that a real keyboard?
Verstuurd vanaf mijn SM-G986B met Tapatalk
Offline KeyTok
« Reply #2 on: Tue, 23 April 2024, 04:34:45 »
The first picture is not a real keyboard, it's a figment of our designers' imagination :cool:
