Author Topic: GMK M.A.G.A.  (Read 63298 times)
Offline nathanchere
Re: GMK M.A.G.A.
« Reply #150 on: Fri, 01 November 2019, 08:29:45 »
This would go great with a 🅱️ key and maybe a steel artisan spacebar to represent the southern border wall.
Offline KingOfMemes
Re: GMK M.A.G.A.
« Reply #151 on: Fri, 01 November 2019, 08:31:11 »
I believe you just found endgame
Offline endler3117
Re: GMK M.A.G.A.
« Reply #152 on: Fri, 01 November 2019, 15:18:55 »
tax breaks on this guy?
Offline KingOfMemes
Re: GMK M.A.G.A.
« Reply #153 on: Fri, 01 November 2019, 15:35:10 »
Only if you are a well known designer
Offline sagarsiddhpura
Re: GMK M.A.G.A.
« Reply #154 on: Thu, 30 July 2020, 14:49:41 »
Is GB date decided?
Offline spctr13
Re: GMK M.A.G.A.
« Reply #155 on: Thu, 30 July 2020, 15:01:57 »
Is GB date decided?
Nah it's like the elections. Delayed until some point in the future, but we don't know when.
Sent from my Pixel 3 using Tapatalk
Offline -Jerry-
  • OR '1'='1'
    • Jerry Talks Tech
Re: GMK M.A.G.A.
« Reply #156 on: Thu, 30 July 2020, 15:13:37 »
Is GB date decided?
"Romeo"     "Split75"   "Melody96"     "KBD8X MKII"     "Womier K87"
Offline Tyson
Re: GMK M.A.G.A.
« Reply #157 on: Thu, 30 July 2020, 15:20:10 »
Is GB date decided?
If it get's delayed past Jan 21st, 2021 then  it'll be forced to leave GH and will never run again :)
Offline Anthixious
Re: GMK M.A.G.A.
« Reply #158 on: Thu, 30 July 2020, 19:54:25 »
This set will be 'uge.
Are there any other renders of other kits? Would love to go full-size with this along with other kits that other GBs have.
Offline Jae-3soteric
  • https://www.youtube.com/channel/UCAIHiFKJt69HNad6r
    • Jae | Top Clack
Re: GMK M.A.G.A.
« Reply #159 on: Fri, 31 July 2020, 03:17:55 »
Oh no.... I thought we had let this die....
Even my plan to turn this into an Americana themed set instead is no longer appropriate
Sent from my iPhone using Tapatalk Pro
Offline Anthixious
Re: GMK M.A.G.A.
« Reply #160 on: Fri, 31 July 2020, 03:29:26 »
LMAO
Offline Emir
  • icon mods
  • Bandit
    • Discord
Re: GMK M.A.G.A.
« Reply #161 on: Fri, 31 July 2020, 03:37:08 »
no longer appropriate  :eek:
Offline -Jerry-
  • OR '1'='1'
    • Jerry Talks Tech
Re: GMK M.A.G.A.
« Reply #162 on: Fri, 31 July 2020, 03:45:56 »
What is dank can never die! :P
Offline kajahtaa
Re: GMK M.A.G.A.
« Reply #163 on: Fri, 31 July 2020, 11:57:11 »
I'd be down for ePBT PRC
Also I'm half White and this still makes me laugh.
Offline Bitmxp
  • I’ll take 12
    • Bitmap Studios
Re: GMK M.A.G.A.
« Reply #164 on: Sun, 02 August 2020, 19:26:50 »
I mean I would get it, if it was from a cheaper brand. :D
Offline Avijit
Re: GMK M.A.G.A.
« Reply #165 on: Mon, 03 August 2020, 23:16:15 »
What about a cheese burger, a bottle of ketchup as novelties
Offline solomonshv
Re: GMK M.A.G.A.
« Reply #166 on: Tue, 04 August 2020, 03:45:19 »
needs hamberder and cofefe novelties. space bar should have orange stains. set also needs to be ironically made in china.
Keebs::: Bok.CP - Antique Copper | Keycult No.2/65 Black/Brass | Keycult No.2 Rev 1 Grey/Brass | Jane V2 CE - Black/Multicolor | J-01 Rev1 - Blue | Haus - Silver | Kohaku - Red | OwLab Jelly Epoch - Ruby SE & Popcorn | KBD8X MKII WKL - Black PC | Ayleen WKL - Gin
Caps::: GMK Modo, GMK Jamon, GMK Olive, GMK Mizu, GMK Olivia++, GMK Bingsu, GMK Analog Dreams, GMK Botanical, GMK Moondust, GMK Taro R2, GMK Hennessey, GMK Serika R2, GMK Birch, GMK Tuzi, GMK Red Alert, GMK Zooted, GMK Hazakura, GMK Cyrillic Beige, GMK Lavender, GMK Daifuku, GMK November Fog, GMK Villanelle, GMK Blossom, DCS 9009 WYSE Alps
On order: GMK Tiramisu, GMK Maroon, GMK Bordeaux, GMK Taiga
Offline HoodrowThrillson
Re: GMK M.A.G.A.
« Reply #167 on: Thu, 10 December 2020, 23:33:52 »
But for real though, when is this running
[Mostly] Retired from Keyboards
Typing on: TKL One - Zealios v1 - 55g TX Springs, TX Films, Lubed with 205g0 - Xiami Beige Cadet + RGB
Collection: IDB60 (gone), Austere (gone), Matrix 1.2og (gone), Matrix 2.0add (gone), RS (so lit), Infinitum (gone), THRILL Proto (destroyed), Matrix 2.0add xmas Starry Night (gone), RS60 (traded), MC65 (traded), Jane v1 CE (gone), GSKT-00 (gone), TKL One Poly (returned), TKL One, RS60, Serenity Proto, Boulevard Proto
Offline Masticccc
Re: GMK M.A.G.A.
« Reply #168 on: Fri, 11 December 2020, 00:08:49 »
When somehow Trump makes a reverse-card against Biden to stay at WH next year lol.
Offline Shiba1337
Re: GMK M.A.G.A.
« Reply #169 on: Fri, 11 December 2020, 00:41:11 »
Putin 2020
Offline manaorme
Re: GMK M.A.G.A.
« Reply #170 on: Fri, 11 December 2020, 03:48:35 »
You're fired
« Last Edit: Fri, 11 December 2020, 18:19:02 by manaorme »
Offline Havattack
Re: GMK M.A.G.A.
« Reply #171 on: Fri, 11 December 2020, 11:32:02 »
Nioce! Should be called  "GMK Oompaloompa" or "GMK Treason" or   "GMK The Best Keyset you've ever met in your life"   or ...."GMK Lying Coward"
Offline Ella
  • Why is it called an oven
Re: GMK M.A.G.A.
« Reply #172 on: Wed, 20 January 2021, 05:05:55 »
make this happen
