Author Topic: [GB] GMK Eclipse (CLOSED)  (Read 55877 times)
Offline T0mb3ry
  • https://www.instagram.com/t0mb3ry_gh/
    • Flickr
« on: Wed, 03 April 2019, 14:52:08 »
Here we go again. GMK Eclipse is now available on Massdrop.
TO THE DROP PAGE
The drop will last 27 days.
As the name of this set tells the theme of this keyset is Eclipse. Eclipse is an well known astronomical event (no its not IDE based), thus the keyset has dark appearance. The lighter modifiers do symbolize the typical light on the edge of an astronomical body which takes part in the eclipse event.
For more information see GMK Eclipse interest check.
Sheet with MOQ and pricing (will be updated as soon sheet on the drop page gets it updates.)
Sale charts by Dvorcol.
The previous Accent & Novelty kit was quite expensive and i decided to split this kit in its parts and make it more affordable that way.
Overall this is my attempt to provide more affordable set and if it fruits i will continue similar pattern in my future projects
Thanks for the interest and hopefully support ;)
Some renders by Oblotzky
« Last Edit: Fri, 03 May 2019, 17:52:07 by T0mb3ry »
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
Re: [GB] GMK Eclipse
« Reply #1 on: Fri, 05 April 2019, 07:27:41 »
Approved
Offline mrpetrov
« Reply #2 on: Fri, 05 April 2019, 08:46:07 »
In for the base and two of the accent kits!
Offline nasp
« Reply #3 on: Fri, 05 April 2019, 09:31:33 »
The dark grey is GMK N9 stock color, right? Are the other colors stock or custom?
Offline keebweeb
« Reply #4 on: Fri, 05 April 2019, 09:45:09 »
Getting this for sure considering it has a good price.
If you look at the ICs you can find an answer to this. The light blue seems to be the same as Yuri, the dark blue is custom, the purple is DY, not sure about the orange but probably custom.
Offline T0mb3ry
    • Flickr
« Reply #5 on: Fri, 05 April 2019, 10:20:16 »
Approved
Thanks!  :thumb:
Yes the dark gray is N9 ;)
Indeed the light blue is from Yuri and the dark blue is new custom color. All other colors are stock GMK color palette.
Thanks! I do appreciate your support ;)
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #6 on: Fri, 05 April 2019, 10:24:31 »
In for the base, all three accent kits, & space bar kit. Didn't even know this set was happening, but pretty much insta ordered once I seen it!:thumb:
Offline eksuen
  • Ambassador of explosions.
« Reply #7 on: Fri, 05 April 2019, 13:33:28 »
I'm glad this set is getting a second chance. I drove to Oregon to watch the solar eclipse in August 2017. Totality is one of the coolest things I've ever witnessed. Anyway, I joined as soon as this went live.
Offline oh_chesteroni
« Reply #8 on: Fri, 05 April 2019, 13:55:49 »
Is there a render floating around with the purple accent keys?
Offline T0mb3ry
    • Flickr
« Reply #9 on: Fri, 05 April 2019, 14:02:45 »
Sheet update.
As you can see the numbers are getting up slowly. I did not expected this set to go crazy and one also has to keep in mind all the GMK GB craze going lately. But that i expected is light blue accents doing better than other accents.
I do appreciate you support guys. Thanks!  ^-^
I will get soon one and then i will of course share it here ;)
« Reply #10 on: Fri, 05 April 2019, 14:06:06 »
Thanks Tombery, really stoked that this set is finally running!
Offline Furikurichemy
« Reply #11 on: Fri, 05 April 2019, 22:23:25 »
Order in for base, Numpad, spacebars, and violet/blue accents. Love the colourway!
Offline monkt
« Reply #12 on: Fri, 05 April 2019, 23:04:42 »
Are the legends on the light blue accent kit also N9, matching the dark gray of the base alphas?
Offline T0mb3ry
    • Flickr
« Reply #13 on: Sat, 06 April 2019, 02:17:14 »
Exactly. Thus you can actually use it with other sets with N9 color (depending on if the light blue matches the other set).
Offline Emir
  • icon mods
  • Bandit
    • Discord
« Reply #14 on: Sat, 06 April 2019, 06:01:39 »
More N9 to the people!  :thumb: Now if there only was an icon mod kit. :(
Offline T0mb3ry
    • Flickr
« Reply #15 on: Sat, 06 April 2019, 06:20:06 »
I got simple rule for when to use icon or icon + word modifiers. Very distinct contrast colors are getting only icon mods. Less contrast colors are getting icon + word modifiers. You can see that rule of mine applied in GMK Carbon R2 drop. Very conrasty Bone has only icon  mods where less contrasty Carbon (orange on gray) has icon + word mods.
In case of Eclipse of course the mods need to be icon + word. For only Icon the mods need to have color Yuri light blue on N9. But thats GMK Skydata.
Offline monkt
« Reply #16 on: Sat, 06 April 2019, 10:07:03 »
This is exactly what I had in mind. Thanks for confirming!
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #17 on: Sun, 07 April 2019, 03:22:13 »
Are the spacebars in the 40s kit modifier-colored or alpha-colored?
Offline T0mb3ry
    • Flickr
« Reply #18 on: Sun, 07 April 2019, 03:53:12 »
The spacebars in 40s kit do have modifiers color.
« Reply #19 on: Sun, 07 April 2019, 04:09:01 »
Thanks. Obviously I missed the IC thread, but that's an unusual decision. Did you just like the look better!
Offline T0mb3ry
    • Flickr
« Reply #20 on: Sun, 07 April 2019, 04:40:22 »
Yes i like this color but its not the reason why i choosed to include it in the 40s kit. I included this color into the 40s kit for variety, because i could not offer both colors for the splitbars in spacebars kit, which would make the spacebar kit huge and more expensive. This way you have already needed split spacebars in 40s kit. But if you (as 40% user) want also gray split spacebars then you can get the spacebar kit additionally.
Also the spacebar kit got the gray split spacebars, because that gray color (N9) is used also in other sets like Dolch or Skidata. Maybe owners of those sets might be interested to get some split spacebars for theirs sets.
There are more strategic thoughts than preferences.
« Reply #21 on: Sun, 07 April 2019, 09:26:13 »
Thanks for all the details, I appreciate all the thought that goes into it.
Offline IOVERCALLHISTIOCYTES
« Reply #22 on: Sun, 07 April 2019, 12:14:35 »
In for base/numpad/light blue accents. Other than GMK Terminal and GMK Nines, what else uses N9 as a base? Had a dream of N9 with stripey color...
« Reply #23 on: Sun, 07 April 2019, 13:01:58 »
Terminal, Skidata, Q:01, and Nines.
Offline T0mb3ry
    • Flickr
« Reply #24 on: Mon, 08 April 2019, 13:22:50 »
MOQ/Pricing sheet has been updated.
Also Oblotzky made some renders with purple accents ;) The keyboard is called Brutal 60.
Look up ;)
And Dolch. Same also for Skydolch and Mintdolch. Not sure but i think there were more sets with N9 color...
Offline nasp
« Reply #25 on: Mon, 08 April 2019, 16:02:41 »
Offline T0mb3ry
    • Flickr
« Reply #26 on: Tue, 09 April 2019, 14:46:37 »
MOQ/Pricing sheet update.
Sale graphics by Dvorcol. Very informative!
« Last Edit: Tue, 09 April 2019, 15:32:32 by T0mb3ry »
Offline T0mb3ry
    • Flickr
« Reply #27 on: Fri, 12 April 2019, 13:02:10 »
Update for MOQ/Pricing sheet
Informative graphs by Dvorcol.
Edit: added graphs.
« Last Edit: Sat, 13 April 2019, 01:50:17 by T0mb3ry »
Offline T0mb3ry
    • Flickr
« Reply #28 on: Sat, 13 April 2019, 13:32:25 »
MOQ/pricing sheet update
Updated graphics by Dvorcol.
Offline T0mb3ry
    • Flickr
« Reply #29 on: Tue, 16 April 2019, 14:24:31 »
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #30 on: Tue, 16 April 2019, 15:19:13 »
Looks like base, pale blue accent, and space bars could hit MOQ by the end of it. I have hope.
Offline nu_types
  • Formerly Iredeus
« Reply #31 on: Tue, 16 April 2019, 16:00:49 »
Also, wouldn't put it past MD to help most of the kits reach MOQ. But yeah, pale blue accents are basically there, and base is looking good. Hopefully this keeps up!
Offline T0mb3ry
    • Flickr
« Reply #32 on: Tue, 16 April 2019, 16:29:15 »
Updated charts by Dvorcol
Yeah the base kit and the pale blue accents will probably hit their MOQ. And yes MD does help keysets to happen but it does not happen for every kit.
« Last Edit: Tue, 16 April 2019, 16:33:23 by T0mb3ry »
Offline mta
« Reply #33 on: Tue, 16 April 2019, 21:46:44 »
Hoping the other accent kits get made :/ (thought the orange and purple looked pretty slick too)
« Reply #34 on: Tue, 16 April 2019, 21:59:38 »
Yeah hoping for violet to get made.
Offline Marutks
« Reply #35 on: Wed, 17 April 2019, 05:01:57 »
joined gb
Offline T0mb3ry
    • Flickr
« Reply #36 on: Wed, 17 April 2019, 13:28:56 »
Updated MOQ/Pricing table.
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #37 on: Wed, 17 April 2019, 13:45:07 »
Updated charts.
Offline T0mb3ry
    • Flickr
« Reply #38 on: Wed, 17 April 2019, 13:57:58 »
Updated charts.
Thanks Dvorcol for the fast charts updates :cool:  :thumb:
Offline T0mb3ry
    • Flickr
« Reply #39 on: Thu, 18 April 2019, 16:34:29 »
New day - new update ;)
Offline vicissitude
« Reply #40 on: Fri, 19 April 2019, 01:39:56 »
hard to believe the number of the novelties...
Offline T0mb3ry
    • Flickr
« Reply #41 on: Tue, 23 April 2019, 15:13:19 »
and of course Dvorcol also updated his charts ;)
Offline sagadoi
« Reply #42 on: Wed, 24 April 2019, 10:37:13 »
Will the three accents kits go through?
Really like three colors
Matrix: 1.0 x10 | 1.2 x8 | 2.0 x20 | 2.2 x3 | 2.0 Ver Xmas x2 | Abel x12 | Abel VD x5 | Abel VC | Cain x2 | Mona x5 | Matrix Ti | ProjectFF
Percent: Canoe x6 | Skog x4 | Canoe FE x4 | Skog Lite x2
EVE: Moon x5 | Mira | Mira SE | Meteor x2
Equalz: Zero x4 | Zero.9 EE x7 | Mountain x5 | One x4 | Zero.9 Ti
FOX: Leaf TKL x2 | Time x2 | Orange TKL x2
TGR: Jane V2 | Jane V2 Ver CE    RAMA: U80A
FMJ TKL x4 | Jer80 x4 | Jermini | Camp C225 x7 | Evil80 x6 |  Evil82 x2 | Mech27 | DolchCR x2 | Triangle x2 | Square x2 | Mars TKL
Offline Marutks
« Reply #43 on: Wed, 24 April 2019, 11:06:32 »
I have never seen some kit not going through on massdrop.
Offline T0mb3ry
    • Flickr
« Reply #44 on: Wed, 24 April 2019, 14:38:58 »
I guess Numpad and the orange accents do have good chance to hit the MOQ or at least get very close to it ;)
Dvorcol also updated his charts.
I can't say for sure but i think the orange accents have a good chance.
« Last Edit: Wed, 24 April 2019, 16:40:36 by T0mb3ry »
Offline spakecdk
  • Browns are best
« Reply #45 on: Thu, 25 April 2019, 05:40:46 »
Damn, I would gladly have joined, if this weren't on massdrop. just EU things...
Offline T0mb3ry
    • Flickr
« Reply #46 on: Thu, 25 April 2019, 13:48:57 »
MOQ and Pricing sheet update
Dvorcol's charts
« Last Edit: Thu, 25 April 2019, 14:19:12 by T0mb3ry »
Offline T0mb3ry
    • Flickr
« Reply #47 on: Fri, 26 April 2019, 14:16:26 »
Dvorcol has also updated his charts
Offline Kevadu
« Reply #48 on: Sun, 28 April 2019, 14:16:07 »
Why no love for purple...it's the best color...
Offline mta
« Reply #49 on: Sun, 28 April 2019, 14:21:30 »
What are the chances of the base + all three accents getting made at this point?
