Author Topic: [GB] Think6.5° | 65% Custom Keyboard (completed)  (Read 316385 times)
Offline oldcat
  • 65% is Life
Re: [GB] Think6.5° (Full Brass Raffle 4/13; PC/Aluminum GB starts 4/14)
« Reply #150 on: Mon, 15 April 2019, 21:27:42 »
In for hopefully 1 aluminum and 1 PC!
thanks for the support, Mike!
Offline upintheclouds
Re: [GB] Think6.5° Dupe Order
« Reply #151 on: Mon, 15 April 2019, 21:37:52 »
I accidentally submitted two responses for PC form (lost track of the first one, and wasn't sure if I had hit submit on PC the night before). Please keep line 186, remove line 251. Thanks!
Offline oldcat
  • 65% is Life
« Reply #152 on: Mon, 15 April 2019, 21:40:21 »
Please let's do that during order change window. In case you are sent 2 invoices just pay one of them.
Offline baoduy23
« Reply #153 on: Mon, 15 April 2019, 22:18:30 »
Join for 1 PC :) hope everything will go well
Offline empa
« Reply #154 on: Tue, 16 April 2019, 07:27:02 »
x 1 PC here! contemplating on getting another
Offline oldcat
  • 65% is Life
« Reply #155 on: Tue, 16 April 2019, 13:27:17 »
Many asked about the lighting, the most updated version:
14 RGB LEDs underglow,
4 rgb LEDs on ESC
3 rgb LEDs above badge (only badge version)
No other lighting sources.
Offline quitraging
« Reply #156 on: Tue, 16 April 2019, 17:49:55 »
4 rgb LEDs on ESC
Is this all the same on pc, alu and brass?
Offline oldcat
  • 65% is Life
« Reply #157 on: Tue, 16 April 2019, 17:50:36 »
Dear all: Thanks for all the DMs and PMs.
Invoices for PC and Alu have not been issued yet, and they will be sent out after order check has completed.
So far we are looking at 150 paid orders from China, excluding full brass, leaving a possible 500 slots for the rest of the world.
In the international GB, we are looking at roughly 370 submissions without deleting possible duplicates. Once the rest of the slots are filled or when 4/30 comes (whichever first), we will start order check for 2 days and send out invoices to all.
Hope this is clear! Thanks for all the support. We have started material procurement for both brass, PC, and Alu, in preparation for production.
Offline oldcat
  • 65% is Life
« Reply #158 on: Tue, 16 April 2019, 17:52:35 »
4 rgb LEDs on ESC
4 rgb LEDs above badge (only badge version)
Yes they are all there, with one difference being that on black pc, alu, and brass, the 14 rgb underglows will have no effects as they are under the pcb.
4XRGB and 3 RGB LEDs will always work, please see the demo here for alu version.
« Last Edit: Tue, 16 April 2019, 22:20:36 by oldcat »
Offline BrutalBanana
« Reply #159 on: Tue, 16 April 2019, 22:08:21 »
Just getting into the hobby from lurking for a while and this will be my first GB. Very excited and looking forward to the final product. Really appreciate the detailed info and communication throughout this process.  :thumb:
Offline oldcat
  • 65% is Life
« Reply #160 on: Tue, 16 April 2019, 22:18:36 »
Some asked about the diffuser in the discord, I figure it is worth more explanations, as it will be very dope. Here is the updated model with 4 RGB LEDs above badge under the silicon diffuser, hope the model is clear enough. Thanks for all the suggestions.
217445-0
« Last Edit: Tue, 16 April 2019, 22:59:55 by oldcat »
Offline coffeeshopcoder
« Reply #161 on: Wed, 17 April 2019, 02:31:19 »
just got in for a waves green alu apart from my PC.
What color will the alu prototype be ?
Any chance of seeing a render of nautilus nightmares along with the waves green board ?
Offline booleanjulien
« Reply #162 on: Wed, 17 April 2019, 06:38:37 »
What would be the best way to mod this board to get RBG lighting diffused in the top case too?
Offline davidkoleda
« Reply #163 on: Wed, 17 April 2019, 08:17:01 »
I have an extremely noob question, but I'm not familiar with hotswaps and would like to know the following:
The kaihua socket hotswap PCB included in this are compatible with any switches? Which type? PCB or plate mount?
(I was interested in installing Zealios)
Inviato dal mio SM-G960F utilizzando Tapatalk
Offline phunktional
« Reply #164 on: Wed, 17 April 2019, 08:32:23 »
In for frosted PC and Wavez aluminum. So hyped!
Offline Furikurichemy
« Reply #165 on: Wed, 17 April 2019, 08:36:29 »
Yes, the hotswap PCB will work for any MX style switch (Zealios, kaihl, Gateron, cherry etc). This one is compatible with both plate and pcb mount switches.
In general though, pcb mount switches can be used with any pcb. If the pcb is plate mount only, you just need to cut a couple of the plastic legs on the bottom off, it's a really easy fix.
Offline Hell-es
« Reply #166 on: Wed, 17 April 2019, 10:21:48 »
Hi there,
Some noob questions also from my side...
1st) if i order pc und alu - its just 1 shipment cost?
2nd) what kind of stabilizers do i need for the boards - is i‘m a noob i would take hot swap boards, but i think i have to install stabs.
3rd) wanted 1 badge and 2 non badge version, i understand this is just gold ? Wavez alu is not green ? Do i get the extra badge as a paper weight with non-badge board ;) ?
Thanks, bernd
Offline oldcat
  • 65% is Life
« Reply #167 on: Wed, 17 April 2019, 10:57:32 »
We will get a few Alu prototype out next week, including wavez green.
Yes there is a render for nautilus nightmare. Color doesn’t match 100% but still quite close I believe should look great
Offline oldcat
  • 65% is Life
« Reply #168 on: Wed, 17 April 2019, 10:58:36 »
I believe with pc frosted clear top piece will have sufficient light if you keep 4XRGB and the light strip LEDs on
Offline oldcat
  • 65% is Life
« Reply #169 on: Wed, 17 April 2019, 11:03:35 »
Think artisan prototype
217492-0
Offline warmsoda
« Reply #170 on: Wed, 17 April 2019, 11:43:07 »
X 1 Frosted PC here!
What stabs will I need for the build (size, quantity, etc.)
Offline KevlarBear
« Reply #171 on: Wed, 17 April 2019, 11:47:37 »
Depends on your layout. If you get either of the ANSI ones you are going to need a 6.25u and x3 2u stabs
Offline oldcat
  • 65% is Life
« Reply #172 on: Wed, 17 April 2019, 11:49:09 »
Do get the pcb screw-in stabs
Novelkeys have the GMK ones that are really good
Offline oldcat
  • 65% is Life
« Reply #173 on: Wed, 17 April 2019, 12:24:24 »
First 10 invoices for full brass issued, please check form: https://docs.google.com/spreadsheets/d/1IzWqGK3syxxaAd8BGyGFQO61wzPBkRcEKvEAtTnfDG0
Offline oldcat
  • 65% is Life
« Reply #174 on: Wed, 17 April 2019, 16:56:15 »
Hi there,
One shipping, based on weight of the total package.
Just buy GMK Screw in Stablizers from here: https://novelkeys.xyz/collections/miscellaneous/products/cherry-stabilizers
Hmm, I am a bit confused by the first question. Wavez Green is a dark green. Somewhere between the Wavez mod and Wavez Alpha. Again I do not understand your third question.
Thanks, bernd
Offline KevlarBear
« Reply #175 on: Wed, 17 April 2019, 17:08:40 »
So you are getting 3 total Think6.5s?
3rd) i understand this is just gold ?
Yes default badge/weight is gold. If you want other colors you have to add them as extras
3rd)  Wavez alu is not green ?
It is green, see sample anno of a wavez green badge
3rd)  Do i get the extra badge as a paper weight with non-badge board ;) ?
No, non-badge layouts will not include the badge, just the weight
Offline oldcat
  • 65% is Life
« Reply #176 on: Wed, 17 April 2019, 20:58:13 »
Thanks bro!
Offline Hell-es
Re: [GB] Think6.5° (Full brass invoicing starts; PC/Alu GB ends 4/30)
« Reply #177 on: Thu, 18 April 2019, 00:52:21 »
Thanks for fast answers - bad wording, (layout 1 and 2), planing on 1 pc and 1 alu . Will start with pc and then check if camara gear selling works fine ;) - dont wanna miss alu
Ah, one more question ... with badge version, i have to solder the leds above badge, or are they pre-soldered ?
« Last Edit: Thu, 18 April 2019, 01:35:29 by Hell-es »
Offline davidkoleda
« Reply #178 on: Thu, 18 April 2019, 04:52:35 »
Thanks for your reply, very clear!
I have another question regardding shipping. I'd probably choose SF Express as a shipping method to Italy, being cheaper.
Does somebody (most likely oldcat) know if it is possible to get the shipping delivered at the post office (any in my city would be fine), then I'd go to pick it up? I'm not sure which local postal service will handle the shipping locally, so this is kinda of my doubt at the moment.
Do you think DHL, on the contrary, being an international courier, offers this service in case SF Express doesn't?
« Last Edit: Thu, 18 April 2019, 08:30:22 by davidkoleda »
Offline oldcat
  • 65% is Life
« Reply #179 on: Thu, 18 April 2019, 12:08:48 »
PC and Alu spreadsheets have been updated
This is the form of all eligible orders without deleting potential duplicated orders.
if you double ordered, please wait till order change period to request cancellation and let us know which one you keep.
Potter's corporate PayPal account registered with his company has been approved. And we will try to do bulk invoicing for PC/Alu.
« Last Edit: Thu, 18 April 2019, 12:18:40 by oldcat »
« Reply #180 on: Thu, 18 April 2019, 14:56:31 »
I'm not on the list! Was my entry not eligible somehow?
I originally thought it was at 6:30AM instead of PM, so I submitted one in the morning, but then I submitted another one in the evening at like 6:50PM.
These are the two who submitted 30 seconds too early, are you one of them maybe?
Cameleopard
neal_stephenson
No... I submitted as booleanjulien
I was a bit disappointed after I was positive that I entered my form in time, only to not see it on the confirmed list, as I knew I wasn't going to get a great raffle spot if I entered again days later. Well, I did enter again yesterday, and my name is still not on the updated list! This time I'm 100% positive my form was submitted and was valid. Any idea what's going on here?
Offline Hell-es
« Reply #181 on: Thu, 18 April 2019, 15:00:25 »
Any experience with SF express to germany?  Still confused about estimated DHL costs... would prefer DHL but hesitate to send the form...
Offline oldcat
  • 65% is Life
« Reply #182 on: Thu, 18 April 2019, 15:10:56 »
Cameleopard
neal_stephenson
Perhaps a sorting error. Let me take a closer look.
Offline oldcat
  • 65% is Life
« Reply #183 on: Thu, 18 April 2019, 15:14:45 »
Cameleopard
neal_stephenson
Actually I do see your name on the list: https://docs.google.com/spreadsheets/d/1eRy06RRbyuFNVcdk5Yd-Xc9iCeAI8TsEQf0gqE-Ieto/edit?usp=sharing
Row 285
« Reply #184 on: Thu, 18 April 2019, 15:16:34 »
Oh, weird! I just tried checking before with the build-in search and come up with nothing... well, we good then :)
Offline oldcat
  • 65% is Life
« Reply #185 on: Thu, 18 April 2019, 15:20:35 »
I think it is because when you looked at it, I was sorting how many orders there are for each layout :) We get you covered, don't worry buddy.
Offline marCH1LLL
« Reply #186 on: Thu, 18 April 2019, 16:26:18 »
https://de.trustpilot.com/review/sf-express.com
Nimm DHL, dass Paket wird zu 100%(eigene Erfahrung) vom Zoll rausgefischt
Offline marCH1LLL
« Reply #187 on: Thu, 18 April 2019, 16:32:47 »
What is the zip code from where you ship and what is the estimate for weight and size of the package?
Offline oldcat
  • 65% is Life
« Reply #188 on: Thu, 18 April 2019, 17:05:37 »
Guangzhou, China
PC: budget for 2kg package
Alu: budget for 2.5-3kg package
Offline oldcat
  • 65% is Life
« Reply #189 on: Thu, 18 April 2019, 23:21:47 »
Carbon Bone, just in!
217601-0
Offline oldcat
  • 65% is Life
« Reply #190 on: Thu, 18 April 2019, 23:29:38 »
the rest of the brass invoices are being sent, please check your email box for the invoice and we appreciate if full brass invoices can be paid promptly.
Aluminum/PC invoices will come later, after order check.
Offline kucas
« Reply #191 on: Fri, 19 April 2019, 01:31:58 »
brass weight and brass badge
can i choose anoter color? instead gold
Offline cucgach
« Reply #192 on: Fri, 19 April 2019, 05:29:33 »
When is the window time for pc order change? I would like to update my order. Thanks.
Current: Filco TKL Majestouch | TX60 antique brass | NIU40 silver | H360 burgundy | tr.mk wooden 60 | Imperial Hue 60 | Tofu 65 silver | Tofu WKL navy | Gergo Kit: black PCB | Space65 gray/silver | VN66 Black
Future: none
Past: TinaC HHKB gray | TX84Se titan gray | Leopold 660M white | GSX96 R2 purple | Rama M60-A lake | 0.01 Z70 silver | E7-V1 MAO | Rama M6-A | TMO50 green/poly | HB85 black/gray | TX108se titan gray | Typewriter68 ceramic white | Think6.5 frost poly
Offline oldcat
  • 65% is Life
« Reply #193 on: Fri, 19 April 2019, 11:07:24 »
For default, it is 18K gold plated PVD. It cannot be modified.
Offline xkhol
« Reply #194 on: Fri, 19 April 2019, 13:37:51 »
Is it possible to change my order from aluminum to frosted PC? I ordered under /u/xwork from reddit
Offline KevlarBear
« Reply #195 on: Fri, 19 April 2019, 13:41:32 »
I would suggest putting an order in for PC and then cancelling during cancel/alterations phase
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #196 on: Fri, 19 April 2019, 15:00:18 »
Didn't see myself in the list so I put in an order again.
Offline oldcat
  • 65% is Life
« Reply #197 on: Fri, 19 April 2019, 15:40:30 »
Sorry brother the list was up to date till yesterday. Thanks for the support!
Offline oldcat
  • 65% is Life
« Reply #199 on: Sat, 20 April 2019, 00:10:22 »
Currently we are approaching the quantity limit, so it could come sooner than 4/30. My plan was still to show you guys how alu looks and how alu+pc would look like IRL, as more PC and alu prototypes will be shipped to me imminently.
Plan for 5/1-5/2 for order change (I will send a free form for you to write how you want to change/combine/cancel), and 5/3 invoice will go out in a batch.
