Author Topic: [IC] Modernized OTD PCBs and reproduction plates  (Read 62037 times)
Re: [IC] Modernized OTD PCBs and reproduction plates
« Reply #50 on: Mon, 13 May 2019, 15:59:32 »
Are these compatible with TGR Jane v1s? I wasn't sure since TGR is better than OTD anyway.
no
Offline yicaoyimu
« Reply #51 on: Mon, 13 May 2019, 15:59:53 »
Doesn't TGR use regular Leeku PCBs? If so then these won't be compatible.
Offline HPE1000
  • Keycap Paparazzo
« Reply #52 on: Tue, 14 May 2019, 15:52:41 »
someone make a separate "do you regret buying your OTD"/"are OTD really worth it?" thread please.
i am hoping to get new PCBs + plates for my janky 360c.
What is up with your corsa? Mine hasn't ever really caused me problems over the years outside of the frustration with having to use the blue box ps2 to usb converter. Windows 10 doesnt recognize the keyboard with the blue box unless I have 2 keyboards plugged in and press the caps lock on the other keyboard, then the corsa starts working, but im going to assume that is an issue with the blue box and not the keyboard.
Will for sure be happy to have some extra pcbs for this though. Would use this board a lot more if it was USB and programmable. Basically a deal breaker for me if my keyboard doesn't have media controls programmed into it.
Offline sl70309
« Reply #53 on: Tue, 21 May 2019, 11:44:15 »
Any date for GB? I just got 360C recently..
Offline XtReeM1337n355
« Reply #54 on: Tue, 28 May 2019, 01:07:34 »
Any updates? I’m lowkey going to buy 10 plates and 10 pcbs.
Offline kawasaki161
« Reply #55 on: Tue, 28 May 2019, 03:38:49 »
No concrete updates yet, I'm still figuring ot the plate situation right now, I should have more concrete information next week.
Offline sl70309
« Reply #56 on: Mon, 03 June 2019, 16:04:36 »
Please make this happen !!!!
Offline sl70309
« Reply #57 on: Fri, 07 June 2019, 18:14:29 »
any update? this week is about to end  ;D
« Reply #58 on: Thu, 20 June 2019, 17:25:25 »
Hey, any new updates? I just got my hands on some skcm neon greens and I'm dying to put them into my board!
Offline Full
« Reply #59 on: Sun, 23 June 2019, 17:48:39 »
Oh wow, I really need this! :) Filled out the IC.
Hi!
Offline kawasaki161
« Reply #60 on: Sun, 30 June 2019, 04:22:58 »
Sorry guys, was pretty busy irl.
The last test plate failed QC sadly, next update will be once I have the plates figured out (give it 2 more weeks or so).
Offline stolenweapon
« Reply #61 on: Tue, 02 July 2019, 21:54:07 »
OTD 356CL Black | 2x OTD 356CL Gunmetal | OTD 356.2 Factory Gray Ano 1/2 | 2x OTD 356.2 Blue Grey | 2x OTD 356mini Military Green | 5x OTD 356mini Red | OTD 356mini Black | 9x OTD 360C Apple Silver | 2x OTD 360C Hyper Grey | OTD 356L | 2x OTD 356N MKII Black | OTD 456GT Pink & Black | 3x OTD 356 Pad (2x Black, 1x Military Green) | 2x OTD Koala WKL Silver & Black | OTD Koala WK Silver & Black
TGR Jane V2 Pink Prototype 1/1 | TGR Jane V2 1/2 Brushed Toblerone Weight | 8x TGR Jane V2 | 6x TGR Jane CE V2 | TGR 910RE | TGR 910 VKC | TGR Alice Purple 1/5 | TGR Alice Red | TGR-03 | TGR Tris
LZ-SE | 3x LZ-RE | LZ-CP | LZ-MP SE
Keycult No.2 Stainless Steel | 2x KMAC Happy | 2x DK Saver MX & Alps
Offline kawasaki161
« Reply #62 on: Sun, 14 July 2019, 07:52:30 »
Guess I started the IC too early. Either way PCBs were finalized from the get go, if I only wanted to offer PCBs this could've been launched in may and delivered in june.
Whole factory woes blah blah blah you heard it 10 times in 9 GBs, just glad this happened before I launched the GB.
A delayed GB will be eventually good, but a rushed one will be bad forever.... or something like that. I'm doing everything I can to make the GB run smooth and to keep unexpected surprises to a minimum, hope you understand.
Offline sl70309
« Reply #63 on: Sun, 14 July 2019, 09:30:27 »
what is the progress on plate now?
Offline kawasaki161
« Reply #64 on: Sun, 14 July 2019, 09:35:56 »
Should work out now, but it also should've worked out the last time so, not gonna give a date until I'm 10000000% certain.
Offline sl70309
« Reply #65 on: Sun, 14 July 2019, 11:07:03 »
cool. i will buy 10 pcb and 10 plates if price is nice :)
« Reply #66 on: Sun, 14 July 2019, 11:45:08 »
weird flex but ok
Offline sl70309
« Reply #67 on: Fri, 19 July 2019, 22:29:44 »
I come to this thread everyday just to see if there is GB date...
« Reply #68 on: Sun, 21 July 2019, 16:41:24 »
you'll be here a while
Offline sl70309
« Reply #69 on: Fri, 26 July 2019, 15:07:35 »
waiting !!!!
Offline sl70309
« Reply #70 on: Sun, 28 July 2019, 21:13:45 »
waiting is painful  :(
Offline sl70309
« Reply #71 on: Thu, 08 August 2019, 16:46:47 »
Dear OP,
Expecting an update from you.  ;D
Offline futurecrime
  • Get Zooted
« Reply #72 on: Thu, 08 August 2019, 16:56:58 »
Dear OP,
You should turn on notifications for this thread then you wouldn’t have to keep checking back here when there’s nothing to see.
Offline sl70309
« Reply #73 on: Thu, 08 August 2019, 18:06:22 »
Dear OP,
thank you, just aware of this feature.
« Reply #74 on: Mon, 09 September 2019, 20:46:16 »
Is this still going to happen? I have a spare 360c pcb + plate and I’m considering making my own.
Offline sl70309
« Reply #75 on: Mon, 09 September 2019, 22:10:07 »
i have been waiting for OP to open GB for ages..
Offline keyboardcircle
« Reply #76 on: Sun, 13 October 2019, 15:28:13 »
Are you still planning to run this GB? long wait.
Offline pr0ximity
« Reply #77 on: Sun, 13 October 2019, 17:24:56 »
You should do it  :thumb:
Offline Atlantic
« Reply #78 on: Sat, 19 October 2019, 12:42:58 »
no news?
« Reply #79 on: Sat, 19 October 2019, 13:12:32 »
no news?
OP is online now, hopefully he will respond...
Offline kawasaki161
« Reply #80 on: Sat, 19 October 2019, 17:06:19 »
Okay, guess I should post an update.
Right when I thought I was able to start the GB, I found a compatibility problem I thought I checked for but apparently didn't, or at least not well enough, which delayed everything a bit further.
That delay would've meant if I started the GB right away after fixing that I would start the GB and then go right on a vacation I've been planning since the beginning of the year.
Right now I'm back at home, but very busy with my university studies. A friend offered to run the GB for me. I hope he'll post about it soon as everything should be set up by now.
On the bright side, we have now confirmed that it perfectly fits into the boards, matching the weird keyspacing that's somewhere between 19mm and 19.05mm. We also got nice cables that are the same thickness as the one we found on a 360c.
I wonder why it showed me being online a few hours ago, as I wasn't even on my computer then.
Offline pr0ximity
« Reply #81 on: Sat, 19 October 2019, 21:34:31 »
I'd be interested to hear more about the keyspacing issue. Have you produced a prototype that you've confirmed works? I wasn't aware that other OTD boards aside from the 356 Mini had non-standard keyspacing.
« Reply #82 on: Sun, 20 October 2019, 01:52:08 »
they all do, it's part of why a.87 type pcbs won't work with it in the first place
other than the static cable, of course
Offline Atlantic
« Reply #83 on: Sun, 20 October 2019, 09:27:40 »
Great to hear, I'm very excited!
Offline mech0nly
« Reply #84 on: Wed, 23 October 2019, 01:01:04 »
Nice updates and looking forward for it.
356mini | 360C | G81-3000SAT | G81-3000SAU | G80-3000LPCXY-2 | G80-3485LWNUS-2
Diamond Polished Cherry Switches!
« Reply #85 on: Thu, 24 October 2019, 17:04:16 »
waiting for your friend to post and run the GB for you.
Offline alisonica
« Reply #86 on: Wed, 30 October 2019, 22:01:20 »
Hello guys,
Sorry for the very very very long delay. Long story short, have other stuff to do.
I'm operating this from Germany, however the factories are in China.
The idea: Upgrade OTDs
Your upgrade options:
1) RED KOREAN JESUS CEM-3 QMK Programmable PCB with MX/ALPs compatibility (with all possible Caps lock position)
2) BLACK matt OG coiled cables with USB A/C headers (because glossy sucks)
3) RED Aluminum plates/half plates (with MOQ and lead time so if there's not many orders OP can release the plate design and you cut your own baby!)
4) RED Sorbothane
Current Situation: Halloween 2019
I already have the PCBs made, there are 200 pieces of V1 and 100 pieces of V2.
V1 PCB: 200 pieces, had a problem with the spacing for Cherry MX, however this will fit ALPS builds.
(Will update the specifics, will probably be sold at a super low price)
V2 PCB: 100 pieces, MX/ALPs fits perfectly fine
Both PCBS are QMK
Cables: 200 pieces, matt Black OG coiled cables with USB-A/C headers
(Will confirm the specific number of A and C headers)
Plates: You can either use the original plate, we will also have plates too but there will be MOQ on each type.
Sorbothane: will be larger than the OTD, you need to cut it yourself, it's also very heavy and will affect shipping prices.
GB soon, Any unsold PCBs and OG cables will be put up for sale online until stock runs out.
Will update pictures and pricing soon.
« Reply #87 on: Wed, 30 October 2019, 22:59:29 »
Hello guys,
4) RED Sorbothane
Both PCBS are QMK
oh my god !!  :thumb:
Offline HPE1000
  • Keycap Paparazzo
« Reply #88 on: Thu, 31 October 2019, 17:53:55 »
This is fantastic, definitely interested in a plate or two as well.  :)
Offline Atlantic
« Reply #89 on: Fri, 01 November 2019, 17:33:06 »
Great to hear, definitely in for a couple of pcbs and plates! Shame about no beige cables or glossy black ones though. Very excited nonetheless.
Offline mech0nly
« Reply #90 on: Sat, 02 November 2019, 20:24:16 »
Hello guys,
4) RED Sorbothane
Both PCBS are QMK
I'm ready!
« Reply #91 on: Tue, 12 November 2019, 12:36:08 »
any update on gb date?
Offline adxlk
« Reply #92 on: Tue, 12 November 2019, 23:11:10 »
Hello guys,
4) RED Sorbothane
Both PCBS are QMK
So will this be like an In Stock GB or? Because you are saying X and Y amounts for PCB and Cables
Offline alisonica
« Reply #93 on: Wed, 13 November 2019, 05:50:25 »
I already have them in stock except the plates. It will be a simple buy except for the plates. Shipping will be from China. I'll be doing this after 25th november, it will be shipped upon payment (except for plates). Won't be costly :)
Offline adxlk
« Reply #94 on: Wed, 13 November 2019, 09:09:40 »
Thank you  :thumb:
Offline adxlk
« Reply #95 on: Sat, 16 November 2019, 16:39:37 »
This might be late but any chance of beige cables?
« Reply #96 on: Tue, 26 November 2019, 09:36:21 »
any update?
Offline alisonica
« Reply #97 on: Wed, 27 November 2019, 17:55:20 »
I can probably make a custom batch of beige cables in the future if there's demand for it, those with Gunmetal CL, .2 and Military Minis might want this.
Here's some pictures of the 200 cables (previous ones were molded like crap), I will announce the price soon.
230881-0230883-1230885-2230887-3
Sorry for the project being so slow, it's our first time at this and I will probably sell it through e-mail and paypal invoicing (don't know how to do automated shipping costs).
« Last Edit: Wed, 27 November 2019, 17:58:51 by alisonica »
Offline pr0ximity
« Reply #98 on: Thu, 28 November 2019, 07:18:45 »
Only those with Gunmetal CL, .2 and Military Minis need apply 👌
Offline adxlk
« Reply #99 on: Thu, 28 November 2019, 08:37:29 »
(Attachment Link) (Attachment Link) (Attachment Link) (Attachment Link)
you can put up a poll to ask for it
