Author Topic: Are Model M SDL-180-degree DIN cables interchangeable with SDL-PS/2 cables?  (Read 3147 times)
Offline Winrar
Hi.
I got this '88 Model M with what I think is a 180-degree DIN plug.
The cable is detachable and the keyboard plug looks like a regular SDL plug:
I have loads of SDL-PS/2 cables around from my other Model Ms (even spare ones) and my motherboard (ASRock Z270 Taichi) has a PS/2 port. I am wondering if using one of those SDL-PS/2 cables on this keyboard would work.
I did not test it because I am afraid of blowing up the controller or the motherboard.
Yes, it should work fine.
- Franklin Roosevelt 1933
Offline Techno Trousers
  • ʘ_ಠ
Yes, an SDL to PS/2 cable will work fine. Or if you can find one, a small DIN to PS/2 passive adapter on that cable will also work.
Offline JP
The important question though...did you pay for Winrar?
About Me | The Collection
Offline Winrar
Thanks to both. I might have a couple of those at home (I work in another place), but they are so cheap in Amazon that I just ordered one.
Sort of. There are licensed Winrar copies installed in the computers in my job. As I usually bring work home, I have also brought the license with me. It's fair, I think.
