Poll
Preferred port
Mini USB
74 (15.6%)
USB C
401 (84.4%)
Total Members Voted: 475
Author Topic: [IC] Rukia (GB form opens Thursday 5/23/19 @9pm PST, confirm your local time)  (Read 147690 times)
Offline ejewell89
  • 4ever Smol
Re: [IC] Rukia
« Reply #250 on: Tue, 14 May 2019, 06:33:54 »
you guys are all over analyzing the screws and PC stripping. I have taken my Poly 910 apart dozens of times and have no issues yet.
I'm no invalid, either. Most who know me are aware I go to the gym regularly.
There is no need to over engineer this project, just dont be an idiot and overtighten screws
Offline Jaxxstatic
  • Haptic Recon
Re: [IC] Rukia
« Reply #251 on: Tue, 14 May 2019, 10:18:07 »
Could you elaborate how different carbon fiber and polycarb plate would be? Sound properties, Which one is more bendable? Etc... is it possible for just a UHMW plate?
Edit: is there a possibility for a half plate?
Just my subjective opinion based off trying them:
Carbon fiber for tactiles. It’s firm almost like aluminum but sounds better imo.
Polycarbonate for linears. Soft and mmm nice.
Offline Jaxxstatic
  • Haptic Recon
Re: [IC] Rukia
« Reply #252 on: Tue, 14 May 2019, 10:21:08 »
That is helpful! I’ll take it into consideration. Especially since inserts wouldn’t look great.
And I have seen videos of this guy deadlift, so I’ll trust his screw turning power
Offline Create_alt_delete
Re: [IC] Rukia
« Reply #253 on: Tue, 14 May 2019, 11:16:49 »
The kit options are just between carbon fiber or polycarbonate plates.
So it seems brass plate from the original UHMW design is out. What about the brass weight?
Really hoping that's staying.
Sent from my SM-G955U using Tapatalk
Offline Jaxxstatic
  • Haptic Recon
Re: [IC] Rukia
« Reply #254 on: Tue, 14 May 2019, 12:11:44 »
Brass on small boards is really meh to me. Sound and feel-wise. On a TKL or larger, brass really shines with cut outs from what I've tried on my Aegis build and heard on other people's Jane v2 builds.
I didn't see enough interest in brass compared to other plate materials, but the files are open source. If people want to put together a brass plate GB, it's relatively cheap to get them made. Even PVD finished.
Sorry it's not included in this GB.
« Last Edit: Tue, 14 May 2019, 12:13:32 by Jaxxstatic »
Re: [IC] Rukia
« Reply #255 on: Tue, 14 May 2019, 12:45:50 »
Specifically wondering about brass weight here, not plate. Sorry for the confusion.
« Last Edit: Tue, 14 May 2019, 14:30:01 by Create_alt_delete »
Offline megaforce
Re: [IC] Rukia
« Reply #256 on: Tue, 14 May 2019, 13:00:57 »
rukia daisuki
Corsair K63 Wireless | Razer Huntsman Elite
Hokusai | Ogre| Yohane | Mc65 | Kaze | RBB
Former: LZ MX | LZ FE | LZ CLS TKL Silver |LZ CLS TKL Gray| LZ St | V.EA | Blackbird | LSV3 | OctagonV2 | Norbatouch | X60 | TX84 | Kyuu | SSK | 268.1| Jane CE | Corsair K95 | X60R | HHKB JP x JS HiPro | 910 CE |Nunu |Nunu FE | Jane V2 CE|Jane V2| RS (TKL)
Offline Jaxxstatic
  • Haptic Recon
Re: [IC] Rukia
« Reply #257 on: Tue, 14 May 2019, 15:17:51 »
Brass weight is there, same as in the renders. External. PVD coated. No engraving.
I toyed with different fonts and drawings for engravings. But I honestly prefer it clean. And it's cheaper this way as well.
Offline KingOfMemes
Re: [IC] Rukia
« Reply #258 on: Tue, 14 May 2019, 15:29:06 »
Amen, brother. Bless up
Offline lolafineday
Re: [IC] Rukia
« Reply #259 on: Tue, 14 May 2019, 15:29:42 »
Projected weight?
Offline Acereconkeys
  • Happiness = life - expectations
Re: [IC] Rukia
« Reply #260 on: Tue, 14 May 2019, 15:32:36 »
Good choice imo.
This boards awesome really hope we can see UMHW more often in the future.
TMO50 | Jane V2 CE Incoming | Realforce 87u 55g | Aergo
Aergo design and build log: https://geekhack.org/index.php?topic=103681.msg2840918#msg2840918
Offline ian13
Re: [IC] Rukia
« Reply #261 on: Tue, 14 May 2019, 20:29:44 »
Will it bring the cost a bit lower if the brass weight will be raw instead of pvd coated? How about sandblasted with clear coat? I'm just wondering, I don't know anything about this, really.
Offline Jaxxstatic
  • Haptic Recon
Re: [IC] Rukia
« Reply #262 on: Tue, 14 May 2019, 21:53:48 »
Negligibly.
Please say that out loud.
Offline bthezebra
Re: [IC] Rukia
« Reply #263 on: Tue, 14 May 2019, 22:02:25 »
Negligibly.
I feel silly...
Offline Esheu2
Re: [IC] Rukia
« Reply #264 on: Tue, 14 May 2019, 22:05:59 »
Any eta on when the drop might happen? Also, any chance you might reconsider including brass plates? Seeing brass through PC is really satisfying.
Ojou
Offline victorpre
Re: [IC] Rukia
« Reply #265 on: Wed, 15 May 2019, 02:08:21 »
Brass!!
Offline ian13
Re: [IC] Rukia
« Reply #266 on: Wed, 15 May 2019, 07:06:04 »
Negligibly.
I don't know what this means. I actually really asked because I don't know anything about the cost of finishing brass or anything about metals.
I apologize if my question seemed sarcastic or anything.
Offline raphaelf
Re: [IC] Rukia
« Reply #267 on: Wed, 15 May 2019, 07:25:13 »
Negligibly.
I think he just meant that "negligibly" (a.k.a. won't change that much) is a funny word.
Offline teamrushpntball
Re: [IC] Rukia
« Reply #268 on: Wed, 15 May 2019, 10:01:40 »
Is this still stepped caps lock only?
Offline Jaxxstatic
  • Haptic Recon
Re: [IC] Rukia
« Reply #269 on: Wed, 15 May 2019, 10:37:22 »
219410-0
stepped and non stepped caps supported.
I apologize for being curt about the brass question.
Costs are only brought down a little bit by going with another brass option besides PVD finish.
And honestly, they’re your keyboards but crappy looking brass will reflect poorly on me long after this GB is ended. I think PVD is the best way to go for corrosion and scratches.
Sorry for the dad joke
Offline Vov
Re: [IC] Rukia
« Reply #270 on: Wed, 15 May 2019, 11:39:32 »
Agreed! Love the PC + brass plate combo aesthetics
1.2 og | 2.0 add | Fallacy | Alpha65 | Ojou | Orion v2.5 | Kei | FMJ Poker | GSKT-00 | Unikorn 2.1
Offline glubazoid
Re: [IC] Rukia
« Reply #271 on: Wed, 15 May 2019, 15:36:23 »
Excited for this, will there be a notification in this thread with a group buy date/ time so we don’t miss out?
Offline Jaxxstatic
  • Haptic Recon
Re: [IC] Rukia
« Reply #272 on: Wed, 15 May 2019, 16:19:18 »
I’m debating how to do this.
Originally it would be FCFS. But I’ve been getting friend requests and pm’s from brand new GH and discord accounts with no history. And people asking to buy multiple for family and friends.
I’m aware of the likeliness of this whole thing just going to flippers. If I was doing a large run, then honestly I wouldn’t even care. Some people read my rant before I edited. I meant what I said.
So I’m considering doing half private and half FCFS.
I will notify in this thread before posting the GB.
Offline jaang
Re: [IC] Rukia
« Reply #273 on: Wed, 15 May 2019, 16:22:17 »
Dang, sucks to see how negatively flippers can affect everything. Hope you figure out what works best for you and also hoping I can get my hands on one!
Offline MagicSauce
Re: [IC] Rukia
« Reply #274 on: Wed, 15 May 2019, 16:22:31 »
Been following this thread but didn’t even realize how much of a pain in the ass that part of this whole process must be...
Offline raphaelf
Re: [IC] Rukia
« Reply #275 on: Wed, 15 May 2019, 16:33:28 »
That sucks. Guess the whole Alice hype has its bad side after all.
Best of luck with whatever you choose. And good luck for me, to hopefully be able to get one.
« Last Edit: Wed, 15 May 2019, 16:51:21 by raphaelf »
Offline Choobies
Re: [IC] Rukia
« Reply #276 on: Wed, 15 May 2019, 16:39:49 »
You could run it FCFS for X units, but only accept the first X people who meet the criteria of being legitimate members of the Reddit/GH mk community?  Users don't have to be like mega-active or whatever, but at least not new accounts, etc.  You hold the rights to sell to whoever you want (and don't want).
Offline sawjai
Re: [IC] Rukia
« Reply #277 on: Wed, 15 May 2019, 16:43:13 »
Registered just to respond to this....
Didn't realize how much of an issue flippers are for this hobby. I'm relatively new to it, only been partaking a bit on Reddit but recently started to come here more after joining on a keycap gb. Have been following this IC from the sidelines because I'm really interested in it. Hopefully everything goes well without flippers being an issue...
Re: [IC] Rukia
« Reply #278 on: Wed, 15 May 2019, 20:31:23 »
You can already see it happening with the Leaf60's as they are being delivered.  Hitting the second hand market at markups.  I understand some markup for having been able to wait out the group buy but it's something else when you have 3 of the same unbuilt kit ready to sell.
Offline darrenph1
Re: [IC] Rukia
« Reply #279 on: Wed, 15 May 2019, 21:08:37 »
That sucks. For that reason alone it should be limited to 1 per buyer. I've never done a GB before but I'm guessing the FCFS list goes quick. Fingers crossed I get in! Please don't let all the bull**** get you down.
Offline Aevyn
Re: [IC] Rukia
« Reply #280 on: Wed, 15 May 2019, 21:11:51 »
Argh, I don't understand why this is even happening. Leaf60 didn't even have unit max. There should be plenty to go around. I'm sure a 100+ were made. Just wait a bit and flippers won't get anything.
Sent from my SM-G950U using Tapatalk
Offline superdoedoe
  • ( ͡° ͜ʖ ͡°)
Re: [IC] Rukia
« Reply #281 on: Wed, 15 May 2019, 21:42:02 »
Not the best pics to show off the brass but it goes great with Poly IMO.
Offline AlcoholEnthusiast
Re: [IC] Rukia
« Reply #282 on: Wed, 15 May 2019, 21:55:22 »
Bummer that GB runners have to even think about ways to distribute to mitigate flippers effect. Hoping most that want one will be able to get one.
Offline p_blaze
Re: [IC] Rukia
« Reply #283 on: Wed, 15 May 2019, 22:29:28 »
So I’ve joined a few Separate Alice/Alice Clones GB lately for just the PCBs.
Will there be an option for just the Case+Plate in the Gb?
If so, will that knock a few Hamilton’s off the Price? Or is the current price estimate for just the Case already?
So the original thing in my head was that this would be a la carte, like if you already had a pcb or plate or case, the new stuff is compatible, so people could pick what they want, and I would just invoice for that. Like a store.
But I can't really offer that, as the case design is really all I did. This GB will just be for a kit. Sorry.
However, it's all compatible. OG Alice plates and PCBs will work. 159's PCBs and plates will work. Maarten's PCB will work.
So along with that, I won't be offering extras. The kit options are just between carbon fiber or polycarbonate plates.
If you need extras, other cloned parts will likely work out.
What I need to know now, honestly, is if people are interested in a case made of stacked carbon fiber layers.
I've got a stack of carbon fiber plates here, and it is.....oof. I want it. I'll make it happen, but if others want it too, I'll run a concurrent buy. Turnaround will likely be even quicker.
What price range are we looking at?
Offline Auxo
  • Formerly CJD_Anthony
Re: [IC] Rukia
« Reply #284 on: Thu, 16 May 2019, 01:57:06 »
It's not so much as how many units are made to be honest, its just the fact that the hobby is continuously growing and that there will always be people missing out on group buys and hoping to pick up leftovers. GMK Serika & Red Samurai are absolutely absurd and those weren't limited either. TGR Jane V2 hit $3000 before all the units even shipped. This caused a lot of curious newbies to join the recent V2 CE in hopes of getting a "$3000 board" at retail (hopefully not to flip), the day of the group buy was absolutely nuts with 400+ people staring at the group buy page before it started lol
Offline blizzara01
Re: [IC] Rukia
« Reply #285 on: Thu, 16 May 2019, 02:30:03 »
Fcfs or raffle will be a nice choice to run this gb.  :thumb:
Offline Jaxxstatic
  • Haptic Recon
Re: [IC] Rukia
« Reply #286 on: Thu, 16 May 2019, 02:41:20 »
So I understand and agree that brass is mucho sexy looking through polycarb. I really do.
But there wasn't enough interest in the answers from people who filled out the form.
What I'll do is create another form when the GB launches specifically for the brass plate. If enough people fill it out, we'll make them.
Also, overnight shipping is not overnight in to some shipping companies, apparently. So expect the GB to drop on Friday at the EARLIEST.
I will still give notification ahead of time in this thread.
Expect a $390 price tag with plate and PCB. Full kit is the only option. Carbon fiber or polycarbonate plate.
I am doing it half private, half open to FCFS.
And yes, i totally understand it makes me a douche to quote myself in a forum.
Offline jaang
Re: [IC] Rukia
« Reply #287 on: Thu, 16 May 2019, 02:48:39 »
Oof can't wait, hope I can get in, but regardless looking forward to it!
Offline Petch
Re: [IC] Rukia
« Reply #288 on: Thu, 16 May 2019, 03:33:53 »
How will the private GB work?
Offline superdoedoe
  • ( ͡° ͜ʖ ͡°)
Re: [IC] Rukia
« Reply #289 on: Thu, 16 May 2019, 04:04:56 »
I Assume he will reach out to you and ask if you want one.
Offline Jaxxstatic
  • Haptic Recon
Re: [IC] Rukia
« Reply #290 on: Thu, 16 May 2019, 04:15:36 »
or reach out to me. I'm on discord. but i'll get to more pm's in tomorrow. time to pass out for a little bit
Offline stoic-lemon
Re: [IC] Rukia
« Reply #291 on: Thu, 16 May 2019, 04:41:49 »
Phew. I'm glad we're best mates and I'll get the PM inviting me to join the private group buy. Right?!
Offline menuhin
Re: [IC] Rukia
« Reply #292 on: Thu, 16 May 2019, 06:57:26 »
Rukia.
And then next Keeb is Ichigo.
Then there'll be a Hollow series with certain featues in its build or materials.
IBM M13 black
NeXT non-ADB keyboard (AAE)
HHKB Pro 2 HasuBT
Offline Furikurichemy
Re: [IC] Rukia
« Reply #293 on: Thu, 16 May 2019, 07:54:16 »
Rukia.
Need Ichika and Kazui boards too.
Offline SJHL
Re: [IC] Rukia
« Reply #294 on: Thu, 16 May 2019, 10:35:58 »
Lets be friends.
Offline sawjai
Re: [IC] Rukia
« Reply #295 on: Thu, 16 May 2019, 12:26:27 »
I'm ok with popular boards getting more expensive due to it's rarity and collectibility regardless of how rare or collectible it actually is. Half the fun is getting in early and seeing where it goes. What drives me nuts are the flippers who had no interest in the board, or maybe even in the hobby, that buys up whatever they can looking for some easy $$$. They artificially inflate all the prices and ruin it for everyone else in the hobby. Like I said though, I'm still new here so I don't know how much of an extent this problem is here. I just see this in other hobbies I partake in and it's quite annoying...
Offline jhmoon999
Re: [IC] Rukia
« Reply #296 on: Thu, 16 May 2019, 19:26:53 »
Rukia.
The Rukia Alice is made of semi-transparent polycarbonate like ice.
The UHMW Alice actually looks like Hollow mask material.
Offline Jaxxstatic
  • Haptic Recon
Re: [IC] Rukia
« Reply #297 on: Thu, 16 May 2019, 19:58:16 »
Should the UHMW one be called...Ulquiorra?
Offline Villa
  • Bang.
Ulqo-what.
« Reply #298 on: Thu, 16 May 2019, 20:01:45 »
...forgot the name already, B.
Re: [IC] Rukia
« Reply #299 on: Thu, 16 May 2019, 20:14:46 »
nah, Grimmjow or ... Aizen
