Author Topic: [IC] GMK Dark - Group Buy beginning Jan 3!!!  (Read 112362 times)
Offline depletedvespene
    • Keyboard-related resources.
Re: [IC] GMK Dark
« Reply #50 on: Tue, 23 April 2019, 09:26:21 »
Bottom Row icons have been split out into a separate kit. yes, i know the Alt icons are upside down, but thats the best you can do
What do you mean, "upside down"? the ⌥ symbol (U+2325), as shown in the picture, is the proper "Alt" icon. It is known.
Offline Prelim
Re: [IC] GMK Dark
« Reply #51 on: Tue, 23 April 2019, 09:38:38 »
caps porn!  :eek: this would be better than old black on black dyesubs
2x GH60 revC - lubed Linjärs 65g / lubed H1s 65g with SPRIT 5mm acrylic plate | Dolch PAC - Cherry housing / Gateron sliders 65g and QMK clips | Raptor K1 G80-1890 stock
Floating on Cherry/GMK caps
Offline xeronu
  • https://0w.nz
    • xero.nu
Re: [IC] GMK Dark
« Reply #52 on: Tue, 23 April 2019, 14:35:08 »
dig it! glad to see icon mods in the kit!
Offline maximize
Re: [IC] GMK Dark
« Reply #53 on: Tue, 23 April 2019, 16:15:32 »
Have you considered splitting the alphas and modifiers? I know for the typical GB, it would be an issue of MOQ. But with this set, where many people will probably only use one or the other, I'm wondering if it would make some sense. MOQ would have to be hit separately for the kits, but it would let people buy in at a lower price point (e.g. $40-50 each kit instead of $100+ for the whole set), so maybe more would actually join the GB? Also, I'm not sure what you'd do with F row and numpad in this theoretical case... It's probably a ****** idea but I'm curious as to what you think.
« Last Edit: Tue, 23 April 2019, 16:18:04 by maximize »
Re: [IC] GMK Dark
« Reply #54 on: Tue, 23 April 2019, 16:30:16 »
splitting them makes it 10% more expensive per kit, not cheaper
it is widely accepted that splitting GMK sets is a bad idea
Offline maximize
Re: [IC] GMK Dark
« Reply #55 on: Tue, 23 April 2019, 16:36:34 »
That's not my point. Let's say the full set sells for $100. If someone only wanted to purchase the alphas for, say, $50, they could do so and save $50. Maybe it would draw slightly more sales overall.
Re: [IC] GMK Dark
« Reply #56 on: Tue, 23 April 2019, 16:38:20 »
and then all the people who want to buy the set have to do it for $150 instead of $130
which will be a majority of the people who buy the set
Offline maximize
Re: [IC] GMK Dark
« Reply #57 on: Tue, 23 April 2019, 16:42:24 »
To keep the numbers the same as my example, it would probably be like $100 for the full set (if split into kits) instead of $90 (if sold as full set).
It's being marketed as a set you can mix and match with other sets. People will probably have a specific match in mind, utilizing either the alphas or mods from Dark. I'm sure I'm not the only one.
Re: [IC] GMK Dark
« Reply #58 on: Tue, 23 April 2019, 17:45:47 »
i'm willing to wager a majority of people buying a set aren't buying it to mix and match
Offline dubious
  • 쏘쿨
Re: [IC] GMK Dark
« Reply #59 on: Tue, 23 April 2019, 18:17:46 »
This is such a simple and amazing design. Very clever for you to think of this!
Offline 8six753o9
Re: [IC] GMK Dark
« Reply #60 on: Tue, 23 April 2019, 18:38:13 »
AFAIK, you can’t really do this with GMK. A perfect example of what pricing might look like is the $65 GMK Waze Kobe kit and $80 GMK Metropolis Midnight mods.  I full kit for this would probably be $100-$120 like GMK Nines.
Offline maximize
Re: [IC] GMK Dark
« Reply #61 on: Tue, 23 April 2019, 20:15:11 »
Ok buddy but literally most of the renders are mixes with other sets.
Offline Hotsauce
Re: [IC] GMK Dark
« Reply #62 on: Tue, 23 April 2019, 20:26:47 »
That’s why they are renders and this is an interest check. I definitely would prefer a base set rather than splitting stuff up.
Offline x86ect
Re: [IC] GMK Dark
« Reply #63 on: Tue, 23 April 2019, 20:29:41 »
Edit: allow me to be blunt - GMK Nines renders seem to be lighter than the renders here. GMK Terminal seems to be lighter than the renders here.  Blind assassin might modify his GMK Night Runner b/c n9 is not "dark enough".  Given the comparisons, it might be useful to look at the response in the GMK Phantom group buy when the final colors didn't match the renders.
Having said that, I have no real life experience with n9; can someone chime in on whether these renders are accurate?
And please forgive the bluntness; I'm part of the crowd that's bitter about GoB, and I badly want this set to be the substitute/savior.
« Last Edit: Tue, 23 April 2019, 21:54:06 by x86ect »
Offline maximize
Re: [IC] GMK Dark
« Reply #64 on: Tue, 23 April 2019, 22:02:01 »
I'm saying that there's a reason the renders were done the way they were. Also, the fact it's an interest check is why I'm bringing this up. :)
Offline svjordan
Re: [IC] GMK Dark
« Reply #65 on: Tue, 23 April 2019, 22:46:53 »
I’m definitely in. This design is sleek. I love it.
Offline IOVERCALLHISTIOCYTES
Re: [IC] GMK Dark
« Reply #66 on: Tue, 23 April 2019, 23:22:59 »
I'm looking at my gmk terminal set now. In low light, the keys looks like the Dark render. In my minds eye, they're about the color of the nines render. The render is mimicking a well lit space, though-the background is white. With bright ambient light, my gmk phantom looks like the renders. In the evening, Phantom looks black.
Someone has GMK Terminal and WoB. Take a photo with both, tell photoshop to swap terminal green for CR black?
Offline roostrc0gburn
  • its just plastic
Re: [IC] GMK Dark
« Reply #67 on: Tue, 23 April 2019, 23:40:04 »
trying to keep an open mind regarding kit design and what people actually want, so i am not completely opposed to splitting out the alphas and mods as some other sets have done in the past. typically, though i would have to agree with puddsy's assessment that this is not common practice with GMK because of pricing.
as i said in my reddit post, at this point i am not considering it because i want to offer a full base kit with as much compatibility while keeping the cost low. however, if enough people want to split up the base kit i will offer them separately, but it will have to be a vast majority requesting this
Offline AlcoholEnthusiast
Re: [IC] GMK Dark
« Reply #68 on: Tue, 23 April 2019, 23:44:07 »
Fwiw I want this as a whole set. And if it was broken into 65$ Alphas and 85$ Mods I probably couldn't justify joining.
  • its just plastic
Re: [IC] GMK Dark
« Reply #69 on: Tue, 23 April 2019, 23:50:45 »
this is a fair point regarding render accuracy, as we have seen in several sets recently. please keep in mind these were just free renders (credit: pngu and kle), so you will need a bit of imagination and some hands-on experience with other GMK sets to have a good intuition for what this will turn out like. terminal, skidata, or sky dolch/ocean dolch are good comparisons for N9 (dark grey) base color. just take a look at google images for these sets in different lighting.
N9 is a dark grey and CR is black. see the colors below
this is a low-contrast set, so lighting will have a dramatic effect on the visibility of the legends. not many existing GMK keysets are low-contrast, so keep that in mind also
« Last Edit: Tue, 23 April 2019, 23:52:26 by roostrc0gburn »
Offline byoliven
Re: [IC] GMK Dark
« Reply #70 on: Tue, 23 April 2019, 23:57:56 »
Would be great if I can skip the numpad keys as I am a >65% keyboard user (seems to be the majority?)
Furthermore, are there any chance to add a 1.75 backspace in the child kit for minivan users?
Anyways, GMK Dark is a Must Buy for me to match with my Violet Tendencies and DolchReborn.
Re: [IC] GMK Dark
« Reply #71 on: Wed, 24 April 2019, 00:12:07 »
Agreed on splitting numpad.
Offline 8six753o9
Re: [IC] GMK Dark
« Reply #72 on: Wed, 24 April 2019, 00:58:01 »
Someone asked me to take a picture a week or the ago that compares CR (GMK WoB - top), GMK Carbon R2 Gray (middle), and N9 (GMK Terminal R2 -bottom). This picture was taken with an iPhone 6s with kitchen lighting. Sorry I’m no professional photographer.
217862-0
Offline Zylkan
Re: [IC] GMK Dark
« Reply #73 on: Wed, 24 April 2019, 04:18:20 »
I also don't think this is the kind of set you would split.
I'm definitely considering it and if I do get in I'm in for the full set.
Offline x86ect
Re: [IC] GMK Dark
« Reply #74 on: Wed, 24 April 2019, 10:49:29 »
... Someone has GMK Terminal and WoB. Take a photo with both, tell photoshop to swap terminal green for CR black?
... (Attachment Link)
... this is a low-contrast set, so lighting will have a dramatic effect on the visibility of the legends. not many existing GMK keysets are low-contrast, so keep that in mind also
Thank you, kindly!
I'm all in.
Offline elfick
  • Can I get Colemak and a side of fries with that?
Re: [IC] GMK Dark
« Reply #75 on: Wed, 24 April 2019, 12:10:09 »
I'd be in full a full set and icon mods.
Splitting the base set will just make it too expensive IMHO. I'd say combine ISO into base as used to be the standard (I'm not an ISO user, but if you are going to bother offering it, this is the only way it will make MOQ). Personally, I find all the extra space bars that seem to get added to sets more annoying than the ISO keys. In fact, I'd move any keys that aren't the common ANSI/ISO 104 (as shown on http://www.keyboard-layout-editor.com ) into the non-standard set to increase the chance that non-standard makes it and reduce the cost of the base set.
Also, combine icon keys into a single set. I'll go in on it, but sadly it probably won't make MOQ unless you run on MD.
So 3 kits, base, icons, and non-standard.
Offline dubious
  • 쏘쿨
Re: [IC] GMK Dark
« Reply #76 on: Wed, 24 April 2019, 14:59:36 »
this is a good representation of N9 in normal lighting conditions, imho
Offline Laughmaster
Re: [IC] GMK Dark
« Reply #77 on: Tue, 30 April 2019, 12:41:27 »
I'll definitely be joining this when it gets to GB :thumb:
A few things I'd like to see changed with the kits:
  • Add another R4 1.25u Alt cap to the base kit so we aren't forced to use AltGr
  • I see there are barred F/J keys but no dot or barred numpad 5. I'd like to see one of them added (preferably dot 5 :) )
  • Speaking of F/J/5, are the non-barred ones scooped? If not, is there any reason for these keys to be non-homing?
  • Combine icon mods & bottom icons into 1 kit
  • its just plastic
Re: [IC] GMK Dark
« Reply #78 on: Tue, 30 April 2019, 20:37:05 »
thanks for the input, i will consider some of these edits
Offline rooney
Re: [IC] GMK Dark
« Reply #79 on: Wed, 01 May 2019, 03:27:37 »
Keeping an eye on this one, thanks!
Offline Yonben
Re: [IC] GMK Dark
« Reply #80 on: Wed, 01 May 2019, 06:23:29 »
Great set and yeah, those coloured accents make it perfect :o
Re: [IC] GMK Dark
« Reply #81 on: Wed, 01 May 2019, 10:41:21 »
Thank you for the photo. I have carbon and terminal and this looks just like them to me.
I'd buy this in my attempt over the years to create N9 handerbeit
Offline Von Steve
Re: [IC] GMK Dark
« Reply #82 on: Thu, 02 May 2019, 23:26:53 »
I wonder what CR caps and N9 lettering would look like in render
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
Re: [IC] GMK Dark
« Reply #83 on: Thu, 02 May 2019, 23:42:38 »
I think this is what GMK Doom was. I think I prefer gray-on-black to black-on-gray.
Offline x86ect
Re: [IC] GMK Dark
« Reply #84 on: Fri, 03 May 2019, 09:38:38 »
« Last Edit: Fri, 03 May 2019, 14:48:27 by x86ect »
Offline metalliccharles
Re: [IC] GMK Dark
« Reply #85 on: Fri, 10 May 2019, 14:50:37 »
I'm in on this set for just the BoB.
Re: [IC] GMK Dark
« Reply #86 on: Fri, 10 May 2019, 15:45:18 »
even more interested now that hineybush has his CR spacebar interest check
Offline dibkib
Re: [IC] GMK Dark
« Reply #87 on: Sun, 12 May 2019, 14:58:25 »
I'd definitely be interested in this kit!
Offline Mcnos
    • GMK Fuyu
Re: [IC] GMK Dark
« Reply #88 on: Mon, 13 May 2019, 19:17:16 »
That's pretty dark.
Offline TheNamesTy45
Re: [IC] GMK Dark
« Reply #89 on: Sat, 08 June 2019, 22:46:34 »
So, does this set still have a pulse or are we dead?
  • its just plastic
Re: [IC] GMK Dark
« Reply #90 on: Sun, 09 June 2019, 00:09:40 »
yeah, still in the works. just been busy, sorry. when i have more time to devote to this i will reboot with banners and such
keep the suggestions coming!
Re: [IC] GMK Dark
« Reply #91 on: Sun, 09 June 2019, 00:32:41 »
Does the icon mods set have a pair of 2.25 2.75 keys that could be VE.A spacebars?
I have a set of SkIIdata bars coming anyways, but for others who like a split space it might be good to have options.
Re: [IC] GMK Dark
« Reply #92 on: Sun, 09 June 2019, 09:16:41 »
No worries. Glad that this is still a thing. It may be the first set I buy more than one of. Between base kit and icons, I got everything I want.
Offline King4477
Re: [IC] GMK Dark
« Reply #93 on: Sun, 09 June 2019, 10:02:34 »
Glad to hear this is still in the works, definitely in.
Offline switchnollie
  • sleever supreme
  • greyhat co-leader
Re: [IC] GMK Dark
« Reply #94 on: Sun, 09 June 2019, 20:56:28 »
+1 for the green alphas, nice contrast :cool:
Offline jaang
Re: [IC] GMK Dark
« Reply #95 on: Sun, 09 June 2019, 22:17:54 »
maybe I’m missing something but why is the R2 backspace in the icon modifiers a different style? would prefer the arrow backspace in an R2 backspace if you prefer to keep both styles though!
Re: [IC] GMK Dark
« Reply #96 on: Mon, 10 June 2019, 06:03:06 »
I have a Planck that this would look great on if I get the keys for it.
Offline jackal
Re: [IC] GMK Dark
« Reply #97 on: Fri, 21 June 2019, 16:36:43 »
100% in. I've been looking for a set just like this.
Offline Shutter_Shock
Re: [IC] GMK Dark
« Reply #98 on: Sat, 22 June 2019, 01:56:58 »
Definitely interested
Offline krey
Re: [IC] GMK Dark
« Reply #99 on: Sat, 29 June 2019, 21:03:46 »
Will be in if the price can be kept ~$100
Kepler FC65 | 7v | Think6.5 v1 | Maja | G60 | TX75v2 | Fjell | Klippe x2 | Acrylic Tofu | CA66 | Norbaforce
