Author Topic: Good 65 Percent Board?  (Read 3472 times)
Offline Dr.Hades
  • "Trust me"
« on: Wed, 17 April 2019, 20:05:56 »
I'm currently looking for another 65 percent custom as I already have one, the ALT, and am searching for another. I have considered the KBD67 but what else is out there?
Offline XtReeM1337n355
Re: Good 65 Percent Board?
« Reply #1 on: Wed, 17 April 2019, 20:08:22 »
My personal favorites:
Dolphin Dolinger or the TGR 910 CE
Offline Dr.Hades
  • "Trust me"
« Reply #2 on: Wed, 17 April 2019, 20:13:51 »
I should have said this before but unless it's very obvious that it's going to get a second GB can we stick to boards that are consistently available? As much as I'd love to have a TGR product they're more rare than a chance to go to the moon
Offline Kevadu
« Reply #3 on: Wed, 17 April 2019, 22:33:21 »
Can't really go wrong with an aluminum Tada68.  They're not very fancy or anything but they're well-made, easily available, and not too expensive.  You could also get the Tofu65 which uses the same PCB as the Tada68...but I don't really see the point.  I mean it does have a brass weight and those are all the rage these days but it's not like that Tada68 is light or flimsy...it's thick aluminum and surprisingly substantial.
For a bit of a different form factor and more lighting options there's also the Clueboard which is readily available.  I have an acrylic sandwich one which they don't actually make anymore but I like it...the aluminum ones should be nice too.  They're a little pricier though.
Offline dexie
« Reply #4 on: Thu, 18 April 2019, 00:15:33 »
Think65 GB is running right now
ISO Life
Offline Dr.Hades
  • "Trust me"
« Reply #5 on: Thu, 18 April 2019, 01:05:34 »
Thank you all very much for the replies! I'll keep an eye out for all of these Krebs and save accordingly
