Author Topic: [IC] GMK Flow  (Read 15018 times)
Offline Rafa_n
  • stuffforrectangles.etsy.com
[IC] GMK Flow
« on: Mon, 22 April 2019, 20:49:17 »
Hi,
I'm really bad at writing things about my work, stuff like backstory, inspirations and such are not really my thing, so I'll just get to the point.
This is GMK Flow
Colors:
GMK Flow uses GMK's WS1 for the alphas, and 2 custom colors, the custom colors might change a bit, but this is the general idea
Kits:
I want to keep the set as cheap as possible, while still providing compatibility for most layouts.
The first iteration of the kits is similar to what you might have seen on GMK Minimal.
In addition to the Base kit, and the ISO + Num kit, I would also like to add a spacebar kit in the future.
Base Kit
ISO + Num
Renders:
rama.works M60-A
TGR Alice
idb 60 WKL
ION Xeno
CableCarDesigns Cypher
Thank you for taking a look at my IC, I hope you like my set. Let me know what you think in the comments, feedback is very welcome.
If there is any interest at all for this, I will be posting a google form to gather feedback.
Offline gnhuy91
Re: [IC] GMK Flow
« Reply #1 on: Mon, 22 April 2019, 20:58:19 »
interested!
Offline the_high_5
Re: [IC] GMK Flow
« Reply #2 on: Mon, 22 April 2019, 21:24:27 »
Looks great! Any chance you'd offer a 40s kit?
Offline Kokaloo
  • 🤘(• ω •)🤙
Re: [IC] GMK Flow
« Reply #3 on: Mon, 22 April 2019, 21:33:20 »
Looking a lot like Merlin's set...
https://geekhack.org/index.php?topic=95019.0
Offline dimo
Re: [IC] GMK Flow
« Reply #4 on: Mon, 22 April 2019, 21:48:13 »
Very close to gmk merlin. I get some TA vibes as well
Offline vosechu
Re: [IC] GMK Flow
« Reply #5 on: Mon, 22 April 2019, 22:38:08 »
Cheap and custom colors don’t mix. Also, ISO compatibly seems at odds.
I’m not saying you shouldn’t do those things, I’m saying that cheap may not actually be first core goal of this project, so maybe move it down the page a bit or omit it entirely.
Maybe you’re just going for a kit with your favorite colors and you also like ISO enters. That’s a fine justification. :)
Offline vicissitude
Re: [IC] GMK Flow
« Reply #6 on: Tue, 23 April 2019, 07:53:01 »
Like this colorway.
Let's make it happen.
Offline OracleKev
Re: [IC] GMK Flow
« Reply #7 on: Tue, 23 April 2019, 08:37:28 »
Like it! kind of funky Triumph Adler  :thumb:
Offline merlin64
    • MechMerlin
Re: [IC] GMK Flow
« Reply #8 on: Tue, 23 April 2019, 10:16:29 »
Yeah, GMK Merlin is very much inspired by Triumph Adler and Nautilus
Offline Rafa_n
Re: [IC] GMK Flow
« Reply #9 on: Tue, 23 April 2019, 10:55:17 »
I'll look into it, I never used a 40% so I don't know how many keys would be required.
Offline Rafa_n
Re: [IC] GMK Flow
« Reply #10 on: Tue, 23 April 2019, 11:01:47 »
First Update:
I think it's not very price efficient to split the numpad and ISO compatibility from the base kit, so I will combine both. I will have a Base set and a spacebars set.
The base set still needs some work
Here is the spacebars kit:
In regards to all of the GMK Merlin comparisons, I think the colors are different enough to warrant a different set.
Offline SolidCactus
Re: [IC] GMK Flow
« Reply #11 on: Tue, 23 April 2019, 12:52:51 »
I like this a lot! Colorway looks just like the Seahawks.
I wouldn't want ISO or Numpad in the base though.
Offline pwade3
Re: [IC] GMK Flow
« Reply #12 on: Tue, 23 April 2019, 13:14:44 »
Not to disparage, but the alphas your renders don't feel much like WS1 at all.
I get that they're done with the free render site, just might be worth considering.
Offline Kokaloo
  • 🤘(• ω •)🤙
Re: [IC] GMK Flow
« Reply #13 on: Tue, 23 April 2019, 13:20:20 »
That spacebar green is much more vibrant than the green shown in your previous renders. Is that the kind of color you're actually going for?
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
Re: [IC] GMK Flow
« Reply #14 on: Tue, 23 April 2019, 14:39:59 »
I agree, this looks more like GR1. I've noticed that some colors on there come out looking like they're in shadow.
Offline Rafa_n
Re: [IC] GMK Flow
« Reply #15 on: Tue, 23 April 2019, 14:58:18 »
The colors I am aiming for are the pantones provided in the OP.
The spacebar kit render is just to give the general idea of what I want in terms of keys. Please don't put to much weight on the color accuracy.
Offline maximize
Re: [IC] GMK Flow
« Reply #16 on: Tue, 23 April 2019, 16:23:54 »
Inspiration and backstory is what separates fantastic projects from good ones, though.
Re: [IC] GMK Flow
« Reply #17 on: Tue, 23 April 2019, 16:30:53 »
TA but it has some green in it
Offline Rafa_n
Re: [IC] GMK Flow
« Reply #18 on: Tue, 23 April 2019, 17:37:46 »
If you just follow this philosophy nothing ever gets made.
GMK Cyan is GMK TA
GMK Nines is GMK WoB but beige
GMK Minimal is GMK Stormtrooper
GMk Jamon is Ceresia with burgundy
GMK Terminal is Skidata
and so on and so on.
All of the sets above are great, just because things are similar to something else doesn't mean you should discredit them with comments like that
The only recent GB for a keycap set that I remember being completely original was Yolch, oh wait....
Re: [IC] GMK Flow
« Reply #19 on: Tue, 23 April 2019, 17:46:14 »
GMK Cyan is GMK TA
10605
Offline dubious
  • 쏘쿨
Re: [IC] GMK Flow
« Reply #20 on: Tue, 23 April 2019, 18:09:18 »
GMK Seattle
Offline Possumx
Re: [IC] GMK Flow
« Reply #21 on: Mon, 24 June 2019, 11:30:29 »
Really interested, any chance we get an ISO-DE Kit?
Offline lewisflude
  • Hand Engineering
    • Hand Engineering
Re: [IC] GMK Flow
« Reply #22 on: Mon, 24 June 2019, 11:35:02 »
Could we get UK-ISO (5 more caps) added to ISO+Numpad? Or maybe a full NorDeUk kit?
Offline masterchris_99
Re: [IC] GMK Flow
« Reply #23 on: Thu, 25 July 2019, 03:32:30 »
Could we get UK- (5 more caps) added to +Numpad? Or maybe a full NorDeUk kit?
I can affirm that. Would be interested with german or NorDeUk support
Offline Argyldude
Re: [IC] GMK Flow
« Reply #24 on: Thu, 25 July 2019, 15:07:06 »
Looks great, definitely interested!
Offline x86ect
Re: [IC] GMK Flow
« Reply #25 on: Fri, 26 July 2019, 10:11:30 »
Mihaly Csikszentmihalyi?
Offline bd_slade
Re: [IC] GMK Flow
« Reply #26 on: Sun, 11 August 2019, 13:01:19 »
Very nice colours. I'm interested!
