Author Topic: [GB] TGR-Jane v2 CE (QC, Shipping) 99% completed  (Read 1506835 times)
Offline frostfiree
Re: [GB] TGR-Jane v2 CE (QC, Shipping)
« Reply #1700 on: Thu, 13 February 2020, 13:04:59 »
Still haven't gotten the invoice  :(
Jane V2 | Jane V2 CE | Thermal | Kei | GSKT-00 | Duck Orion V3 | U80 | Salvation | 378 | HHKB | Cloudline | Bias | TKL One | Kaze | Jane V2 ME
Offline rkarp
    • hypertext.dev
« Reply #1701 on: Thu, 13 February 2020, 13:07:30 »
Just got my tracking number. My shipping invoice was January 6
 :eek: My invoice was also January 6th. Maybe mine is coming soon too.
Just to put this info out there so others can compare, I ordered WK version with multi-colored weight, an extra pcb with alu plate.  Paid my invoice on Oct 27.  Who knows if these are batches or whatever, but that’s my situation.  Of the YouTube videos of the v2 CE that have been posted on YouTube already, I think they are all WKL versions.  This is all circumstantial info, but at least you have some info.  Time to get back to my switches.
Offline Haskel
« Reply #1702 on: Thu, 13 February 2020, 13:12:04 »
Same boat buddy.
Jane V2 CE | Frog TKL | GSKT-00 | TKL One (PC) | RS60
Offline Mr_BeastQuake
    • Reddit
« Reply #1703 on: Thu, 13 February 2020, 14:38:47 »
Same boat buddy.
I've waited for a TGR board before and I'm waiting for this one. I'd recommend just not paying attention, it helps the time pass. Obsessing over each and every step only makes it take longer.
Offline Acereconkeys
  • Happiness = life - expectations
« Reply #1704 on: Thu, 13 February 2020, 16:05:18 »
Same boat buddy.
This man speaks the truth, but at the same time obsessing over it is part of the fun :) I've not seen anyone here be toxic or annoyed with it which is refreshing.
On that note, my tracking number just got updated from a january 7th invoice :)
TMO50 | Jane V2 CE Incoming | Realforce 87u 55g | Aergo
Aergo design and build log: https://geekhack.org/index.php?topic=103681.msg2840918#msg2840918
Offline superdoedoe
  • ( ͡° ͜ʖ ͡°)
« Reply #1705 on: Thu, 13 February 2020, 16:32:48 »
Last batch Gang  :cool:
Offline zekkin
  • my entire life was unlimited zekk works
« Reply #1706 on: Thu, 13 February 2020, 16:40:59 »
we out here, last batch gang!!!
Offline Mousy
  • I <3 tootall
    • IG
« Reply #1707 on: Thu, 13 February 2020, 21:57:55 »
Yes we are
Sent from my SM-A705FN using Tapatalk
- White Kira 60 | Black Kira 60 | TGR Jane v2? -
Offline Emir
  • icon mods
  • Bandit
    • Discord
« Reply #1708 on: Fri, 14 February 2020, 06:07:45 »
Yes we are
last batch gang quote gang
Offline ejewell89
  • 4ever Smol
« Reply #1709 on: Fri, 14 February 2020, 09:59:37 »
Yes we are
 C C C C C C COMBOBREAKER
Offline jortzii
« Reply #1710 on: Fri, 14 February 2020, 20:17:36 »
Yes we are
Last batch gang quote gang train
Volcano660 | Satisfaction75 | Think6.5 | TGR Jane V2 CE | Preonic | IC Kira | Drop ALT
Offline Jae-3soteric
  • https://www.youtube.com/channel/UCAIHiFKJt69HNad6r
    • Jae | Top Clack
« Reply #1711 on: Mon, 17 February 2020, 02:38:55 »
Got a surprise in the post this morning
Sent from my iPhone using Tapatalk Pro
Offline rkarp
    • hypertext.dev
« Reply #1712 on: Mon, 17 February 2020, 05:43:45 »
Mines’ out for delivery as we speak.  :-*  You going to stream your build?
    • Jae | Top Clack
« Reply #1713 on: Mon, 17 February 2020, 05:44:41 »
Yes - I'll unbox it live on stream on Sunday. will keep it sealed till then
Offline rkarp
    • hypertext.dev
« Reply #1714 on: Mon, 17 February 2020, 06:36:44 »
You are a stronger man than I haha.
Offline rkarp
    • hypertext.dev
« Reply #1715 on: Mon, 17 February 2020, 10:00:55 »
This is my first TGR.  I hope it’s not my last.  Build quality is on a completely different level from everything else out there.  Thank you, Yuktsi, for an awesome board.
I’m going to build this after work.  Still hemming and hawing between my alu plate or CF for my tealios.  Gonna go split backspace and split right-shift.
Offline Auxo
  • Formerly CJD_Anthony
« Reply #1716 on: Mon, 17 February 2020, 10:15:49 »
What are you planning to program your extra keys into?
Offline rkarp
    • hypertext.dev
« Reply #1717 on: Mon, 17 February 2020, 10:44:13 »
I don’t know yet, and I also need to find and figure out the software for the PCB.  I would like to try to macro-them if possible, and maybe the right shift split for the pcb functions if any exist.  Thinking about installing led’s for the switches too.
Offline frostfiree
« Reply #1718 on: Mon, 17 February 2020, 10:52:18 »
Beware of the LEDs. The last Jane PCB did not play well with LEDs, at least with mine and a couple others. I installed LEDs only to find that out and I had to desolder all of them. I'd opt for the Hiney PCB if you want to do that.
Offline rkarp
    • hypertext.dev
« Reply #1719 on: Mon, 17 February 2020, 12:14:30 »
Good to know and thank you tons for that info.  I’ll hold off on the LEDS for now.
Offline rkarp
    • hypertext.dev
« Reply #1720 on: Mon, 17 February 2020, 23:26:38 »
Hardest build I ever did. The carbon fiber plate had very tight tolerances for my switches. I somehow forgot to solder my F5 key. One plate screw was missing from the 6. And 1 of my 2 PCB’s had a diode pop off and another wasn’t soldered correctly (minor fixes). Other than that, very happy with how things turned out. The sound profile is off the chain. Here are some pics with GMK Honeywell. I’ll figure out how to program her tomorrow. I am exhausted.
https://imgur.com/a/mfWoh2Q
Offline yuktsi
  • Colour my life with the chaos of trouble
« Reply #1721 on: Tue, 18 February 2020, 03:17:35 »
Sorry, let me know if you have trouble replacing the diode and the plate screw. The size of the plate screw is m2.5*4mm.
I just tested the plate with tealios, it seems impossible to push it in.
email: yuktsi@ttggrr.cc
My collection
Poker 2 | LZ CE | Leopold FC700R | KMAC 1.2 | EXE | GON NS87 | GON Nerd TKL | Duck Poker | Duck Orion | Realforce 87u 55g | OTD 456GT | LZ B7 | OTD 360C | Ducky G2 Pro | Apple Extended | Apple M0116 | Apple M0116 | Cherry G80-1220HAD | Duck Octagon | HHKB Pro 2 | Duck Unicorn | LZ B8 | LZ RE | ENVKX | OTD 456GT | LZ FE | HHKB Type S | TX1800| Duck Orion V2 | LZ FE | KPad | KMAC Happy | ENVKX | LZ RV | KMAC 2 | Whale | Dolphin | EM7 | TGR Jane | VE.A | DK Saver | Matrix 10xv1.0 | Whale | HHKB BT | Dolphin v2 | EM7 v2 | SSK | SSK (Blue Label) | LZ SQ | Duck Octagon v2 | TX84 | GON Mobik | TX-CP | LZ Ergo2 | KMAC Happy HHKB | TGR 910 | TGR Tris | Matrix 8xv1.2 | KMAC Mini | Mira | Fjell | 356mini | Dolphin GH | EM7 GH | TARO EXENT | Masterkey Pro L Crysta l OTD Koala | Duck Viper | Keycult no.1 | 356mini | 356pad | Matrix 8xv2.0 | 420cl | Matrix 8xv1.0 | Whale Special | Poly Dolphin | Keycult No.2 | FMJ80 | Singa R2 | Whale Poly | 356cl | HBCP | Dolinger | Linger | FMJ80 | KFE
Offline zekkin
« Reply #1722 on: Tue, 18 February 2020, 05:41:11 »
This happens due to the corner radius size on the plate's switch cutouts. Using 1mm doesn't allow for all the material on the switch to come through the plate, but if you use 0.5mm the switch should sort of snap-in cleanly.
I highly recommend putting switches through the plate before you try to push all the way through to the PCB. In my experience this has lessened the overall destruction of my thumbs from pushing switches through tight switch cutouts.
Edit: Talking to yuktsi about it, it seems like both Cherry and standard Gateron fit without a problem -- it appears to be isolated to Tealios. According to his measurements, the width of Cherry and Gateron switches are 13.95mm and the Tealios he measured were 14.05. The standard switch cutout size is 14mm so that .05mm seems to be an issue.
« Last Edit: Tue, 18 February 2020, 05:59:25 by zekkin »
    • Reddit
« Reply #1723 on: Tue, 18 February 2020, 08:05:37 »
Tealios are going in my v2 ce ftw
Blacks are going in my v2 ce ftw
Inks maybe? Standard? Idk
Offline MoarCoffeePlzzz
  • Formerly Deeptek
« Reply #1724 on: Tue, 18 February 2020, 10:34:55 »
Gateron Inks are very tight as well.. Was about to get them through but it squeezed the sides so tight that it put pressure on the switch and gave it a tactile feel. I had to go with another set. Now that I think of it these were filmed Inks and I didnt try it without films. Anyone having this issue as well?
Outside of that very happy with my board.. It's quite pretty :)
« Last Edit: Tue, 18 February 2020, 11:02:27 by MoarCoffeePlzzz »
Offline rkarp
    • hypertext.dev
« Reply #1725 on: Tue, 18 February 2020, 10:49:20 »
Hi Yuktsi, no apologies needed.  I am 100% satisfied with my Jane and the experience!  I’ll need to send you some pics after I return home and work on fixing my F5 key - there are some other questions I have regarding flex of the PCB - I’ll explain with detailed pictures at that time because it would be easier.  (I also added a short sound test in my imgur link - I’ll need to upload the full vid, but sound wise, everything sounds great.  The iphone mic doesn’t capture the full sound as it is a much deeper sound in person.  I am also typing the keys very hard in the vid.)  There’s an issue with flex in the PCB towards the center of the board, but that might be due to some alignment of the switches (due to the low tolerances probably) that I discovered that I’ll need to fine-tune.  Also, both the gasket and the plat mounting screws are used as the same time, correct?
There are a few pics of the diode issues - but they are easy and I can fix myself (I think) - this was the PCB that was in the case, so I think it was just due to being shaken up during shipping or whatever against that small foam piece.
https://imgur.com/a/tcN9g4K
In terms of the tolerance of the tealios (I also filmed them, so not sure if that changes the dimensions for fit into the plate) - about 75% of the switches popped in with a click and a little pressure.  The other 25% had to be worked in, but they still fit.  I never felt like I was going to break the plate or “force” the switch in, but with pressure applied evenly, I did get the switches in.  There are a few that need to be seated better - I’ve identified about 5 or 10 from an overhead view that need some fine tuning.
Sorry if this is a big run-on post, but pretty busy in the office this morning and wanted to get this out early.
« Last Edit: Tue, 18 February 2020, 10:51:15 by rkarp »
Offline bball2
« Reply #1726 on: Tue, 18 February 2020, 10:50:02 »
Gateron Inks are very tight as well.. Wasn't able to get them through. Had to use a different switch.
Good to know, I was planning to use gateron inks on my build - but I'll leave those for one of the hiney pcb/plate combos.
Offline vtachkov
« Reply #1727 on: Tue, 18 February 2020, 11:24:18 »
I noticed this to be more a problem with the 'boutique' teal-colored tealios with a recent build. I tried to shove them into an OG 910 brass plate and they.would.not.fit. But the normal V2 tealios, while still somewhat tight, were able to get into the plate without pushing so hard my thumb would hurt.
Offline nickheller
  • Cherry ML life
    • hickneller.com
« Reply #1728 on: Tue, 18 February 2020, 12:32:39 »
Put a keycap on the switch while you push it into plate / pcb. Saves your thumbs  :thumb:
Offline Emir
  • icon mods
  • Bandit
    • Discord
« Reply #1729 on: Tue, 18 February 2020, 13:09:51 »
We suspect that last batch gang are up next, but there might as well be several batches to go. :O
Offline tentboy
« Reply #1730 on: Tue, 18 February 2020, 13:38:57 »
I'm in the last batch gang and yesterday Yuktsi confirmed my shipping address change and I was told to expect the shipping invoice "soon"
    • Reddit
« Reply #1731 on: Tue, 18 February 2020, 14:03:43 »
Re-tooled MX Blacks it is then.
Offline rkarp
    • hypertext.dev
« Reply #1732 on: Tue, 18 February 2020, 14:11:15 »
Unfortunately it wasn’t enough. In some cases, I had to work the corners of the switch housing.
I also wonder if that extra pressure in the switch case is going to impact anything long term. Feels great to type on so I don’t know.
I’ll post my additional pics of the build in a few hours. I’m also going to watch Jae build his this weekend on his stream. Curious to see his experiences.
Offline Emir
  • icon mods
  • Bandit
    • Discord
« Reply #1733 on: Tue, 18 February 2020, 16:32:36 »
don't tug on my heartstrings like that man
Offline 1Raku
« Reply #1734 on: Tue, 18 February 2020, 17:36:05 »
My heartstrings are so frayed at this point :(
Sent from my GM1917 using Tapatalk
tgr jane v2 ce | duck unicorn x legend | duck jetfire | HHKB pro 2 | pc singa | tgr alice | iu tkl | kohaku | pc volcano 660 | matrix 8xv 3.0 | matrix 2.0 add | ryujin tkl | dndd | noodle.zip | matrix falcon | noxary evija | tgr 910 me
Offline Mousy
  • I <3 tootall
    • IG
« Reply #1735 on: Tue, 18 February 2020, 17:44:35 »
There is always hope for an invoice!
Offline DukeEsquire
« Reply #1736 on: Tue, 18 February 2020, 18:17:37 »
Last batch crew. Hoping for an address confirmation/invoice/anything.
Offline dugihk
« Reply #1737 on: Tue, 18 February 2020, 20:00:59 »
Got my board yesterday! Can't wait to build it. To everyone waiting, its well worth the wait  :thumb:
Offline Zacharius
« Reply #1738 on: Tue, 18 February 2020, 20:02:04 »
I’ve been hurt before. Please don’t do this.
Offline pr0ximity
« Reply #1739 on: Tue, 18 February 2020, 20:50:11 »
I'm not sure what yuktsi intends but I have mine assembled without the plate mounting screws, like the 356mini or GSKT-00, and it works just fine. Definitely a softer durometer than those boards' o-rings, but it doesn't seem to cause any problems thus far.
Offline rkarp
    • hypertext.dev
« Reply #1740 on: Tue, 18 February 2020, 21:44:46 »
I'm using the ZealPC screw-in stabs, and it's a very tight fit with the o-ring.  I'm also using the plate screws.  Do you notice any chatter or movement at all w/out the plate screws?
I've rectified the other issue with switch / PCB alignment that I was going to post pictures about earlier so my board is pretty much calibrated and good to go at this point.  With the plate screws in (minus the one near the arrow cluster), everything is very stiff - but I'm really liking it.  I kind of wonder 2 things:
  • does the o-ring provide any sound dampening benefit?
  • I wonder if I used the o-ring with my aluminum plate w/ out screws if that would be fine (assuming you're having success w/ the CF plate
For my F13, and the split space key immediately underneath, I set those to vol up and vol down respectively for the time being.  For split right shift, I've got it set to mute until I get more creative.  Don't really need any layer setup for now.  TKL is starting to become my favorite layout thanks to this experience.  I'm going to swap out GMK Honeywell for GMK Laser now and see how that looks.
Thoughts and prayers to the last batch crew.  Respect.
Offline Xerpocalypse
« Reply #1741 on: Tue, 18 February 2020, 22:25:53 »
This does make me a bit wary for the Gateron Ink switches that I planned on using for this build; I don't have a board yet but once I receive it I'll definitely check how they fit. The inks I have are from the original run on Novelkeys before the leaf issues and 'retooled' bottom housings.
Luckily I do have some cream switches with UHMW stems as a backup, they're awesome when lubed with a thin layer of 205g0.
Offline pr0ximity
« Reply #1742 on: Wed, 19 February 2020, 21:29:19 »
Movement, a little. Chatter, none. I recommend trying it, not much to lose.
Offline rkarp
    • hypertext.dev
« Reply #1743 on: Wed, 19 February 2020, 22:14:27 »
What stabs are you using?  The ZealPC stabs have a standoff that pretty much prevents the gasket from fitting "naturally".  When I put the plate in the case, I use a plastic spreader from my tech toolkit to 'fit' the gasket in.  It's not the tightest fit, but I already worry that it's putting too much pressure on the top half of the case already.  I've just spent the past 2 nights getting all the switch seating issues resolved because of the tight tolerances with the plate that we've been discussing, so replacing the stabs is out of the question at this point for this particular plate/pcb combo.
Offline rkarp
    • hypertext.dev
« Reply #1744 on: Wed, 19 February 2020, 22:34:36 »
I just took out the plate mounting screws and it's interesting how different the experience is.  Typing doesn't feel as tight (and with the screws in I felt a crispness to it), but I also wouldn't say that it feels soft...luxurious is too cheesy of a word, but it's in that vein for me.
Where I notice the flex this most is on the left hand side of the board, and in particular the bottom left hand side, but that makes sense considering it's a TKL layout.  Do you have the same experience?
Offline ejewell89
  • 4ever Smol
« Reply #1745 on: Thu, 20 February 2020, 10:02:41 »
I had one diode on one of my PCBs compromised as well. I took one off the other one (that I ****ed up and lifted a pad on 100% me) to build my current build.
I put Gat Silent Black Inks in my build as well. it was an absolute nightmare, I soldered in the mod keys with stabs only to realize there was no way i was getting all those switches in the plate. That's when I lifted the pad (for backspace) trying to get those few switches out.
If you have tight switches and are building the CF plate, I ended up pushing every single switch through the plate (for my Gat Inks) then sandwiched everything very carefully double and triple checking the pins all lined up.
Super satisfying that they did, too. After that it was smooth sailing on soldering.
The CF pattern makes me want to switch all my lifestyle accessories to carbon fiber. carbon fiber phone case, carbon fiber minimalist wallet, carbon fiber laptop shell. lol. and somehow integrate into my keys too. but i'm holding out so far.
That said, a few of you probably know I'm selling stuff. Point: I'm trying with all my ability to not sell this Jane. It's amazing. I'm also hoping to hold onto my Alice.
I did have to drop a spot i had for the keycult 1/65 rev 1, too. That hurt.
Offline BAS1C
« Reply #1746 on: Thu, 20 February 2020, 11:50:28 »
Curious what the plate thickness is, is it 2mm?
Offline rkarp
    • hypertext.dev
« Reply #1747 on: Thu, 20 February 2020, 12:34:54 »
Pretty much my same experience.
Offline hineybush
  • student of error
    • hineybush keyboards
« Reply #1748 on: Thu, 20 February 2020, 13:30:47 »
should be 1.5-1.6mm per cherry spec
Offline pr0ximity
« Reply #1749 on: Thu, 20 February 2020, 19:11:30 »
Vintage Cherry clip-in stabs, toothpick modded. Gotta pull out all of the 2012 keyboard modding stops for this kind of board.
