Author Topic: [GB] Satisfaction 75% - GB Ended, Fulfillment Early November  (Read 320182 times)
Offline Sazuke9
Re: [GB] Satisfaction 75% - Knob and OLED Screen, Opens May 6th, 6PM EDT
« Reply #100 on: Sat, 04 May 2019, 19:59:02 »
Is it possible if I can get more than one? Absolutely love them and would love to have 2 different colors for 2 different gmk sets.
Offline Create_alt_delete
« Reply #101 on: Sat, 04 May 2019, 20:04:17 »
The answer is in the post right before this.
Sent from my SM-G955U using Tapatalk
Offline lakeboredom
« Reply #102 on: Sun, 05 May 2019, 05:01:27 »
Where can we find knobs that look like the smooth ones in the renders? Or any alternate knobs too, would be cool. Is there a diameter or mounting type to search for?
I posted the exact part number above.
Guess I'm not good at searching.. Not sure I'm smart enough to search for knobs based on specs from the encoder. Got any hot leads? I understand if you'd rather we figure that out after the GB!
Offline upas
« Reply #103 on: Sun, 05 May 2019, 12:23:44 »
Hey guys,
Some updates - the Group buy will end on Monday May 20th. If stock runs out before then, you won’t be able to buy, but you can still edit your option selection until the 20th.
Everyone who purchases will receive an email to a form to select options - you can edit that as many times as you like, but on May 20th, they will be locked in.
Similarly, you have until the 20th to purchase extras.
The OLED screens works with 0305 Mill max hotswap sockets, so if you want to easily swap them, I highly recommend the sockets!
« Last Edit: Sun, 05 May 2019, 21:11:21 by upas »
Offline upas
« Reply #104 on: Sun, 05 May 2019, 21:12:17 »
Double post so those watching the thread can get this info:
Due to the demand, I will be offering CF plates as an add on as well, during the GB.
They will be $40.
Offline upas
« Reply #105 on: Mon, 06 May 2019, 07:44:31 »
And yet another post -
For the real time clock built in to the keyboard, you will have to source a CR1025 battery.
It’s not a hard requirement, but the battery will allow the clock to persist through power down.
I can’t send CR1025 batteries because they are lithium ion batteries, but they are <$1 each and should last up to 10 years.
Offline thecyangiant
« Reply #106 on: Mon, 06 May 2019, 07:50:36 »
Can the battery be replaced without de-soldering switches?
Sent from my SM-N950U using Tapatalk
Offline rondg
« Reply #107 on: Mon, 06 May 2019, 08:23:29 »
If the images on cannonkeys is the real PCB, we should be able to remove the battery even with switches soldered. It's on the underside of the PCB though
« Reply #108 on: Mon, 06 May 2019, 08:44:46 »
Brilliant, thank you!
Offline alfa147x
« Reply #109 on: Mon, 06 May 2019, 10:18:22 »
I'm very excited about this group buy.
A few simple questions:
  • Is this a fully assembled keyboard? What are the default switch?
  • If not fully assembled - Which switch types are compatible?
Sorry if these were previously answered.
Thanks
Offline Capsy
« Reply #110 on: Mon, 06 May 2019, 10:25:37 »
Thanks
1) Not assembled. It's a do it yourself kit. You'd need to solder in the switches.
2) Any MX style switches are compatible (cherry, gateron, zeal, etc.)
Offline Rumblehotep
« Reply #111 on: Mon, 06 May 2019, 10:25:43 »
RAMA knob, oh gosh
Offline alfa147x
« Reply #112 on: Mon, 06 May 2019, 10:30:14 »
Thanks
Wonderful. Thanks!
Offline upas
« Reply #113 on: Mon, 06 May 2019, 12:51:40 »
This is correct - you can remove it without desoldering (soldering a battery sounds... dangerous), and its on the underside of the PCB.
« Reply #114 on: Mon, 06 May 2019, 13:09:24 »
Yeah! Soldering a battery would be bad news.
My question was really what side of the PCB is the battery housing, and that was answered above.  It is on the other side if the pcb from the switches.
Offline nadayada
« Reply #115 on: Mon, 06 May 2019, 13:38:25 »
Oof excited for this gb!
Offline xondat
  • i'm not a star
« Reply #116 on: Mon, 06 May 2019, 16:02:35 »
Offline lakeboredom
« Reply #117 on: Mon, 06 May 2019, 16:46:07 »
Do Mill-Max sockets fit every pin hole on the pcb?
Offline Slash Emperor
  • Lust for life lost, keyboards acquired.
« Reply #118 on: Mon, 06 May 2019, 17:05:04 »
Got my orders in! Hope everyone gunning for Cloud White gets it!
Offline DukeEsquire
« Reply #119 on: Mon, 06 May 2019, 17:05:20 »
Wow...did all of the white units really sell out in under 2 minutes?!
That's what I get for going to the bathroom right before the GB started.
Offline Kevadu
« Reply #120 on: Mon, 06 May 2019, 17:05:28 »
Ordered, but I noticed there was no option for choosing color when ordering, other than white which costs more.  Where do we specify that?
Offline lakeboredom
« Reply #121 on: Mon, 06 May 2019, 17:06:09 »
Oh, and how many sockets are needed for the oled screen? There's a GB for millmax sockets running right now fyi guys.
Offline lakeboredom
« Reply #122 on: Mon, 06 May 2019, 17:06:49 »
It says clearly multiple times here you will fill out a google form with your options AFTER paying.
Offline trizkut
« Reply #123 on: Mon, 06 May 2019, 17:08:36 »
Didn't manage to snag a Cloud White, rip!
Offline cfiggis
« Reply #124 on: Mon, 06 May 2019, 17:08:57 »
If we want a pearlescent knob, is that one of the options in the form, or do we need to go back and order it separately?
Offline jaang
« Reply #125 on: Mon, 06 May 2019, 17:10:23 »
Should be an extra that you add to your cart, not one of the options in the form.
Offline upas
« Reply #126 on: Mon, 06 May 2019, 17:12:30 »
Hey everyone,
Super amazed at the demand! The cloud white addon sold out within 3 minutes.
If your cart did not have the cloud white addon, it means it was sold out when you purchased.
If you did checkout and wanted white, but placed your purchase after the addon ran out, please let me know if you want to cancel your order.
Thanks,
Upas
« Reply #127 on: Mon, 06 May 2019, 17:13:08 »
Damn, that fast? Makes me wonder how soon all 200 slots will fill, then.
Offline jaang
« Reply #128 on: Mon, 06 May 2019, 17:15:07 »
Hey everyone,
Thanks,
Upas
If in our order history, the white addon is there, it should be fine correct?
Offline DuellM
  • Keyboard Fatty
« Reply #129 on: Mon, 06 May 2019, 17:23:16 »
Oh No I missed out on the cloud white version cause the purchase tripped my cards fraud alert during checkout at 6PM, got the regular version so I'm still happy  :cool:
Offline japancakes
« Reply #130 on: Mon, 06 May 2019, 17:27:13 »
I need to go cool off a bit... so ****ing pissed at the Shopify SMS confirmation.
Had Cloud White in cart in the first 2 seconds and missed it as a result. Stormy Grey it is (unless someone wants to trade!)
PM me about any Cloud White cancellations or refunds plz.
« Last Edit: Mon, 06 May 2019, 17:38:35 by japancakes »
Offline upas
« Reply #131 on: Mon, 06 May 2019, 17:38:27 »
Hey everyone,
Thanks,
Upas
Yep - it should be an actual line item with a $20 charge.
If there is no additional $20 charge, it means you tried to get it but it sold out.
Offline eyedrop
« Reply #132 on: Mon, 06 May 2019, 17:45:04 »
Do you have a picture comparing the white and blue OLED screen?
Offline Clo_0lD
« Reply #133 on: Mon, 06 May 2019, 17:49:31 »
There are pictures of them on the OLED product page on CannonKeys.
Offline eyedrop
« Reply #134 on: Mon, 06 May 2019, 17:57:54 »
Thanks, I guess that'll do for now.   :)
Offline eyedrop
« Reply #135 on: Mon, 06 May 2019, 17:59:01 »
Better than 2 seconds.   :p
What color did you end up picking instead?
Offline lakeboredom
« Reply #136 on: Mon, 06 May 2019, 18:02:59 »
Lol, what else were you hoping for? You wanted pics, there are pics. You guess thats okay? Exactly what you wanted? lol..
Offline eyedrop
« Reply #137 on: Mon, 06 May 2019, 18:09:08 »
I was hoping upas has renders of the different screen on different color board.  Since I didn't get navy, I want to see how they pair with other color board.  That's all.
Offline rondg
« Reply #138 on: Mon, 06 May 2019, 18:15:20 »
It's early in the morning here in my area and having my order confirmed is a good way to start my day! I am really excited for my blue board. Congrats to everyone who got the white!  ;D
« Reply #139 on: Mon, 06 May 2019, 18:19:43 »
Got the cloud white! I feel (slightly) less upset about missing Jane by a few seconds now.
Offline mrpetrov
« Reply #140 on: Mon, 06 May 2019, 20:06:31 »
My dude I got the Stormy Grey by choice over the cloud white! You have made the right long term decision, don't worry. Super compatible and easy on the eyes for long sessions. Team Stormy!
Offline Keebmeupscotty
« Reply #141 on: Mon, 06 May 2019, 20:30:16 »
Team Stormy +1
Offline crowKAKAWWW
« Reply #142 on: Tue, 07 May 2019, 00:08:28 »
+1 for stormy gang
I wonder how many spots are left  ;D
RAMA M60A
KBDFans Frosted Tofu
Cannon Keys Satisfaction 75
Desk Candy Modern M0110
ALF x Scott G60
Offline cynnoh
« Reply #143 on: Tue, 07 May 2019, 01:45:37 »
Not sure how many spots are left, but at 6:40pm EST (40 mins after the gb started), upas said in the cannonkeys discord that more than 100 orders have been made already!  Slots are going fast.
Offline bj
« Reply #144 on: Tue, 07 May 2019, 02:18:48 »
Yup, missed white too (RIP GMK Minimal plans), went with blue instead.
Offline celta
« Reply #145 on: Tue, 07 May 2019, 04:06:29 »
So I've purchased a kit, but asides from the white add on there weren't any other options for colors. Do we get to pick these later or did I miss something somewhere?
Offline Clo_0lD
« Reply #146 on: Tue, 07 May 2019, 04:11:24 »
Look for an email from CannonKeys. There will be a link to a google form that asks for your order info and lets you choose the color of the case, OLED, and knob.
« Reply #147 on: Tue, 07 May 2019, 07:09:55 »
I wonder what the total number of sold units will be at the 24-hour mark?
Offline xondat
  • i'm not a star
« Reply #148 on: Tue, 07 May 2019, 07:20:57 »
34 left right now... Might make 180 total?
« Reply #149 on: Tue, 07 May 2019, 07:36:35 »
Wow, that's a hell of a start. I'm really happy for upas on such a successful start to this GB.
I'm glad I got my orders in when I did, I'd be real mad at myself if I slept on this. Time to start picking out my extra knobs/plates/PCBs.
