Author Topic: Firmware recommendation for total newbie  (Read 5853 times)
Offline Ro-76
« on: Tue, 30 April 2019, 07:37:55 »
I have read this forum and watched numerous videos on the topic of building a custom keyboard, but can't seem to find a simple answer to my problem.
I have built a small custom keypad of 16 keys to control shortcuts on a radiology workstation. I've wired it all up as a matrix of 4 columns and 4 rows wired to a 8 pins on a teensy 2.0 with diodes etc. I've got the teensy communicating properly over usb to teensyduino.
I'm running into a challenge with the firmware build. I don't need any fancy bells or whistles, I just need to program my 16 keys with simple keystrokes like function keys and letters. I may stretch to having 2 keys that do ctrl+c and ctrl+x at most.
Could anyone please suggest a starting point or firmware to begin with. Most firmwares that I have looked at seem much more feature-rich and hence more complicated for a newbie like me.
Many thanks!
Offline Tactile
Re: Firmware recommendation for total newbie
« Reply #1 on: Tue, 30 April 2019, 08:19:59 »
I can't find a drop-in solution for you but have a look here to get started.
REΛLFORCE
Offline xack
    • Make'n'Modify
« Reply #2 on: Tue, 30 April 2019, 09:05:32 »
was about to post the same:
KeypadTutorial
But thats only one part. What you also want is send the key as a keypress to the computer.
For this you also need this:
Keyboard.print()
If you want to do key combos you might also need Keyboard.press() and Keyboard.release()
That should get you started ;)
Offline nevin
« Reply #3 on: Tue, 30 April 2019, 09:45:47 »
was just playing with this for a project another forum member is working on... try this
    (disclaimer.... i've never used the firmware from this site yet, but it's a web configurator for qmk, give it a shot)
go here: https://kbfirmware.com/
dump you layout into the "paste here" spot
Code: [Select]
[{a:7},"","","",""],
- import
- go through the tabs & set it up how you have it wired & what you want the keys to be in the tabs below the layout (ATmega32U4 for teensy 2.0)
- macros (key combinations) also available on there.
    - macro tab, pick a number, record macro, stop recording
    - keymap tab, select a key, configure click "KC_SPC", fn tab, click "M()", then select macro number you just recorded
- when all done, go to compile tab & generate the hex file, upload to teensy with teensy loader
all web based, no coding necessary.
your layout from keyboard layout editor
« Last Edit: Tue, 30 April 2019, 09:48:05 by nevin »
Offline Ro-76
« Reply #4 on: Wed, 01 May 2019, 10:03:01 »
Code: [Select]
- import
Thanks for all the help. This worked really well. I'm now up and running. The only thing I can't perfect is combinations like CTRL+C etc, but I'll keep trying.
Thanks again for all the great advice.
Offline nevin
« Reply #5 on: Wed, 01 May 2019, 10:26:40 »
quick screen grab vid/how-to https://cl.ly/4e15d80bb60c
make sure you set macro key on default layer if you're only using one layer
