Author Topic: [IC] SA Bliss | GB LIVE!  (Read 162873 times)
Offline stuey138
Re: [IC] SA Bliss | 05.07 - Spacebars, Ortho, ISO, Stuwu Kit Updates!
« Reply #100 on: Wed, 08 May 2019, 01:37:27 »
notices new update
ÒwÓ WHAT'S THIS
oh god the memes. I knew what was coming when I saw the 'Stuwu' kit but I didn't think you'd actually go through with it lol. Still a cute kit though. Excited to see what the novelties look like!
stuey basically guiltmailed me into it... I'm personally prioritizing novelties over Stuwu since I spent more time on those and also not memelties but the response seems to be positive so far 😂
I didn't guiltmail you, you had already started the kit anyways and had just given it up.  Helping to build the bliss hype  ;)
Offline Minterly
« Reply #101 on: Wed, 08 May 2019, 01:47:15 »
notices new update
ÒwÓ WHAT'S THIS
OK v1 uwu was absolute trash and nothing even close to current Stuwu 😂
Offline TuCZnak
Re: [IC] SA Bliss
« Reply #102 on: Wed, 08 May 2019, 04:42:01 »
I've decided to add ISO compatibility! Hopefully I've done this right since I'm a simple American pleb with no experience with ISO kits.
I was gonna shout that you need 1,25u shift you plebeian, but since it's in the base already you get a pass :p Maybe consider moving it over? I don't think it gets much use outside of ISO
Offline stuey138
« Reply #103 on: Wed, 08 May 2019, 04:52:22 »
I was gonna shout that you need 1,25u shift you plebeian, but since it's in the base already you get a pass Maybe consider moving it over? I don't think it gets much use outside of ISO
It's used in one of the boards she has rendered so I'd assume it's a preference to keep it in the base kit.
Offline audiosl4ve
  • Just slave
« Reply #104 on: Wed, 08 May 2019, 05:03:58 »
Yeah don't split base anymore and keep 1.75 shift there  :thumb:
Offline vicissitude
« Reply #105 on: Wed, 08 May 2019, 07:24:47 »
Love the stuwu kit.
So cute.
Offline TuCZnak
« Reply #106 on: Wed, 08 May 2019, 09:00:38 »
I mean, sure, but that's a 40% board. Not telling anyone how to run their set, but this base kit is already bigger than some GMK sets. I worry about the price of a kit this large with so many custom legends... Splitting some stuff off or moving it to e.g. the spacebar kit may end up being neccessary.
Offline Bhk1004
« Reply #107 on: Wed, 08 May 2019, 09:09:34 »
Stuwu looks amazing!
Offline Bhk1004
« Reply #108 on: Wed, 08 May 2019, 09:10:40 »
« Last Edit: Wed, 08 May 2019, 11:44:21 by Bhk1004 »
Offline OnceSavedGaming
« Reply #109 on: Wed, 08 May 2019, 09:11:25 »
The issue with moving things like that to kits hardly anyone buys means that needed key for a lot more than just that one use case may not make it or force people like strictly 40% users to buy an iso kit just for a 1.25u shift key which frankly is a little unfair to them. If a dedicated 40% kit was made I would buy that but not a separate kit to steal a key from.
Sent from my VS996 using Tapatalk
Offline jortzii
« Reply #110 on: Wed, 08 May 2019, 12:23:31 »
Big Update: Adding ISO Compatibility! New Stuwu kit! Update to spacebars kit!
There's a brand new kit! Driven by Stuey138, I introduce the Stuwu kit. This is NOT the novelty kit... more like the memelty kit...
I've updated the spacebars kit by removing the 3U key, which seems less popular, and have added 4 blank 1U keys for ortho compatibility.
Oh damn, 100% in for Stuwu. And alpacacorn
Volcano660 | Satisfaction75 | Think6.5 | TGR Jane V2 CE | Preonic | IC Kira | Drop ALT
Offline derznation
Re: [IC] SA Bliss
« Reply #111 on: Wed, 08 May 2019, 13:23:50 »
There's a brand new kit! Driven by Stuey138, I introduce the Stuwu kit. This is NOT the novelty kit... more like the memelty kit... 😂
Sigh *reaches for wallet*
Offline Minterly
Re: [IC] SA Bliss
« Reply #112 on: Wed, 08 May 2019, 13:51:56 »
It's used for 40s! I am big 40s keeb supporter so it's gonna stay put 😉
Offline joelmats3
« Reply #113 on: Wed, 08 May 2019, 15:54:44 »
Super cute! This might be my first SA set.
Offline Minterly
« Reply #114 on: Thu, 09 May 2019, 01:16:35 »
Yes! SA R3 elite!
Offline jortzii
« Reply #115 on: Thu, 09 May 2019, 01:28:02 »
Yes! SA R3 elite!
Buying for stuwu and R3. No clue where this set is gonna go...
Offline Jolly_Green_Giant
« Reply #116 on: Fri, 10 May 2019, 10:02:23 »
I'd love for a homing kit be added as an option since it's only 4 and will open it up for a bit more compatability, although since it's uniform R3, I could honestly go without.
Would be nice and since we're at the IC phase, might as well ask!
Offline sandragm
« Reply #117 on: Fri, 10 May 2019, 11:52:32 »
If this is somehow able to make it in PBT then it's a sure buy for me.
Offline Minterly
« Reply #118 on: Fri, 10 May 2019, 15:48:17 »
I've gotten other requests for a homing kit, I'll figure out if it's a good idea to add it!
Unfortunately SP doesn't do reverse dye-sub PBT 😭
Offline Minterly
« Reply #119 on: Fri, 10 May 2019, 19:59:56 »
Update: Pantone Color Chip!
This photo was taking indoors with flash. I'll be filming some videos of the chip in various lightings, as well as the chip of SP's color match once I receive it.
Offline .Udon
« Reply #120 on: Sun, 12 May 2019, 01:13:00 »
Signature Plastics confirmed manu now?
Offline Minterly
« Reply #121 on: Sun, 12 May 2019, 02:01:09 »
Yes, SP confirmed manu 👍🏻
Offline rjchatfield
« Reply #122 on: Sun, 12 May 2019, 02:39:54 »
Double-shot ABS?
And are you planning to do a test run any time soon?
Offline Minterly
« Reply #123 on: Sun, 12 May 2019, 02:42:39 »
Double-shot ABS?
Yep, double-shot ABS! I have ordered a color match so it will take around 3 weeks to arrive. SP doesn't create molds until the order is placed so there won't be a test run since I can't afford to pre-pay for molds 😅
Offline rjchatfield
« Reply #124 on: Sun, 12 May 2019, 02:49:57 »
I can’t stop looking back at this IC.
I have no need for a new set. I recently ordered a big set of Kuro/Shiro (totally different, white cherry-profile with hiragana), and probably won’t even have a board for them until July.
… but these are so pretty. Colours are grand. And your mods are so nice. And the R3 profile is great (I’m looking at an ergo board that would fit it nicely). Maybe I need to find a reason.
Bit of a pity the lettering doesn’t match your mods. And lack of PBT are enough not splurge out.
Offline beekey
« Reply #125 on: Sun, 12 May 2019, 12:26:12 »
SP ABS in R3, yes!!! Too many fully sculptured sets right now. Hope this will be made.  :thumb:
Offline Bhk1004
« Reply #126 on: Sun, 12 May 2019, 12:30:31 »
O it's being made my friend...
Offline stuey138
« Reply #127 on: Sun, 12 May 2019, 12:31:36 »
100 percent for sure
Offline Minterly
« Reply #128 on: Sun, 12 May 2019, 19:22:22 »
I wish I could do same lettering as mods but then this would be a 500$ set that no one will buy 😂 Hopefully soon SP will be able to do reverse dye-sub for PBT but not yet 😢
SA R3 ELITE!!! I like this one. 😘
Offline .Udon
« Reply #129 on: Mon, 13 May 2019, 07:56:48 »
SA R3 gang
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
« Reply #130 on: Mon, 13 May 2019, 10:30:08 »
I just noticed the UWU novelty key...
Just my thoughts
Offline Minterly
« Reply #131 on: Mon, 13 May 2019, 14:01:03 »
UWU memelty key is what Stuey lives and breathes 😂
Offline stuey138
« Reply #132 on: Mon, 13 May 2019, 15:23:39 »
I love uwu :)
Offline jortzii
« Reply #133 on: Mon, 13 May 2019, 18:00:26 »
We’ll make sure of that
Offline .Udon
« Reply #134 on: Tue, 14 May 2019, 05:04:14 »
Speak it into existence.
Offline Aphidsc
« Reply #135 on: Tue, 14 May 2019, 07:59:57 »
Just filled out the form. Can't wait for this one! I think SA goes well with the cutesy look of this set. Really loving the Stuwu faces <3
Offline Minterly
« Reply #136 on: Tue, 14 May 2019, 15:59:54 »
Yeah! TYSM for the support 💙
Offline Minterly
Re: [IC] SA Bliss
« Reply #137 on: Wed, 15 May 2019, 15:37:27 »
Update: SP manu confirmed! Base kit update! Stuwu x Novelty kit! Latrialum artisan collab!
This set WILL be made by SP in ABS double-shot. Custom match pink order has already been placed.
I've removed the two 1.5U "win" keys and added one 1.75U Ctrl for HHKB. Some icons have also been slightly updated.
Stuwu kit and Novelties kit (never revealed) have been merged due to concerns about two competing novelty kits both reaching MOQ of an affordable price point. Peep Stuwulty kit below.
There's currently a vote going on for which Stuwu face to include in the kit (1.25U wink is up for debate). Vote for your favorite face here!
Meika of Latrialum has agreed to do an artisan collab!
Check out her IG here: @latrialum
Above is just an example of her amazing work. Bliss x Latrialum cap will be in Bliss colors.
« Last Edit: Wed, 15 May 2019, 15:51:59 by Minterly »
« Reply #138 on: Wed, 15 May 2019, 15:39:51 »
Oof big updates! I voted and am also so in for the matching artisan!
Offline .Udon
Re: [IC] SA Bliss
« Reply #139 on: Sun, 19 May 2019, 23:13:57 »
Magical Glittery Alpacacorn Poop artisan or we riot
Offline sevenseacat
Re: [IC] SA Bliss | 05.15 - Base and Novelty Kit Updates! Latrialum Collab!
« Reply #140 on: Mon, 20 May 2019, 00:36:47 »
Can we have homing H/U/N/T keys added to the base kit for super perfect alternate layout compatibility??? :D
Offline jortzii
« Reply #141 on: Mon, 20 May 2019, 01:49:47 »
This set is on par with most GMK kits as far as I've seen. Very few keep to small base kits, and that can be attributed to a small hand full of designers and is certainly not a consistent choice. Also being SA it will likely be cheaper to begin with. Custom legends could add some cost, but I'm confident it will be successful.
Offline voxkey
« Reply #142 on: Mon, 20 May 2019, 08:47:32 »
Any updates? GMK when?
Offline Minterly
« Reply #143 on: Mon, 20 May 2019, 13:09:30 »
tell mekanisk to make it happen
I think most people are used to SA sets either being a monokit or a billion kits, not really GMK style kits. Maybe that's why?
Not enough demand... we don't think it will reach MOQ :(
hush lemme do round 1 first GMK later
Offline jortzii
« Reply #144 on: Mon, 20 May 2019, 13:46:06 »
Wow vox trying to fast lane this set smh
Offline harlekein
Re: [IC] SA Bliss
« Reply #145 on: Tue, 21 May 2019, 05:07:04 »
damn this would have been a dank GMK set
shame its sa
:c
I am happy to see something else than GMK now and then. Getting bored to tears with GMK tbh.
Offline Minterly
Re: [IC] SA Bliss
« Reply #146 on: Tue, 21 May 2019, 12:53:37 »
shame its sa
:c
wew nice
I was gonna do R2 GMK if R1 was successful... but now thinking of something more fun like KAT would be doope
We'll see what happens after R1 is done haha
Offline Ruwey
« Reply #147 on: Tue, 21 May 2019, 13:54:34 »
shame its sa
:c
wew nice
+ 1
Offline Bhk1004
« Reply #148 on: Tue, 21 May 2019, 15:40:16 »
GB When? We been in IC forever.... gonna die waiting...
Offline Minterly
« Reply #149 on: Wed, 22 May 2019, 00:39:44 »
Update tmrw!
